Old 02-12-2016, 07:18 PM   #15
enivid
enivid's Avatar
Drives: WRB JR BRZED
Originally Posted by ka-t_240 View Post
How will that impact you classing/points wise? And where did you loose the 150lbs from?
I have FI. I was in TTB but now will be in TT3. I just removed some of the interior, deleted the AC and put in a lighter battery.
enivid is offline   Reply With Quote
Old 02-13-2016, 03:11 AM   #16
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Originally Posted by ja1217 View Post
Getting your comp weight down to 2800 isn't very hard. That's about where I was last year (my comp weight was 2885 and I was running 70lbs. of ballast and I weight in at around 210-215lbs with all my race gear on, leaving my car around 2600lbs with about 1/2 tank of gas).
I was able to get my car (not including me) down to around 2600lbs while leaving the interior completely stock. My lightweight mods include:
Removing trunk junk - about 40lbs.
Lighter wheels (Enkei RPF-1) - about 16lbs
Essex Sprint BBK - about 20lbs.
Driveshaft Shop Carbon Fiber DS - around 13lbs.
ACT Pro-lite Clutch and flywheel - around 12 lbs.
Shorai 5lbs. battery - around 20lbs.
So that's about 120lbs right there from the car and you can get another 20 pretty easily by moving to a lighter cat back from the stock one.
When you want to remove even more than that, take a look at @Anthony build thread:
http://www.ft86club.com/forums/showthread.php?t=42284
Did you actually weigh your car? I'm not saying it is impossible, but I have a very hard time believing the car dropped to 2600 lbs without gutting the car.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 02-13-2016, 03:14 AM   #17
zdr93523
zdr93523's Avatar
I compete with @enivid and we have similar setups. I will be weighing mine in the coming weeks and will see if I need to add ballast or not.
www.makesmodels.com
www.camautomag.com
Old 02-13-2016, 12:13 PM   #18
ja1217
Drives: 2004 Toyota RAV-4 5M
My car gets weighed at pretty much every event. Last year at nationals I got weighed after every session. Car always came in around 2890-2900 with about 1/2 a tank of gas. If the car got much lower than 1/2 a tank I would have been under my weight limit of 2885.
So, 2900 - 70lbs of ballast - 215 for driver and gear = 2615lbs for the car at around 1/2 a tank of gas.
You can see in my videos that I still have the full stock interior (well, I guess you can't see the back, but its all there too).
[ame="https://www.youtube.com/watch?v=IBAxIFB4Gww"]Fastest Lap @ East Coast Championships - 2:12.605 - YouTube[/ame]
ja1217 is offline   Reply With Quote
The Following User Says Thank You to ja1217 For This Useful Post:
zdr93523 (02-14-2016)
Old 02-14-2016, 02:30 AM   #19
zdr93523
zdr93523's Avatar
Nice! I guess I forget how much the supercharger kit, intercooler, extra oil coolers, larger radiator, and harness bar weigh. I was at 2950 with 1/2 tank of gas, I weigh 215lbs, and I do have the JRSC, lightweight battery, AP Racing Sprint BBK, aluminum driveshaft, full exhaust system, and aero with full interior.
This year will be very different though and I may need ballast to hit my power to weight limit for TT3.
www.makesmodels.com
www.camautomag.com
Old 02-14-2016, 11:00 AM   #20
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Mine was weighed at two different tracks with two different organizers at 2610 with similiar mods
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 02-14-2016, 10:02 PM   #21
zdr93523
zdr93523's Avatar
Cool! I'll be able to post a weight in the next few weeks when I get around to corner balancing the car.
www.makesmodels.com
www.camautomag.com
Old 02-14-2016, 10:35 PM   #22
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
My name is Faber - 2013 BRZ Limited - NASA Central.
Car currently has too many points, would be in TTC.... debating how much money or time I want to spend to make it back to TTD before this season. This will be my first NASA season.
Plans for Spring:
4.56 Final Drive swap
Maybe 4 Point Roll bar w/ seat/harness/hans
Maybe 17x8 w/ R Comps
Current Parts Combo:
(Finish while I am not at work)
In Central it seems like you would have more fun shooting for TTB, there is a much bigger competiton range.
I'll be competing in NASA Central TT3 (pending new dyno classing)
crazyfrenchbiker is offline   Reply With Quote
Old 02-18-2016, 01:22 AM   #23
zdr93523
zdr93523's Avatar
Plans for Spring:
Unless you are on a very low speed track, I think you will find that the Final Drive will make zero difference. The exception to that is if you are constantly finding yourself in between gears or feel that the gearing is too tall but I think the cost will be far more than the benefit.
www.makesmodels.com
www.camautomag.com
Old 02-18-2016, 01:39 PM   #24
ka-t_240
I spend way to much time in the 6500-7000rpm range in 3rd at the two tracks I use the most. Hoping the FD will make 4th more inviting. If I can find my self more comfortable in 4th thru most corners it will cut out a lot of shifting.
ka-t_240 is offline   Reply With Quote
Old 02-18-2016, 01:44 PM   #25
ka-t_240
I know we have 2 FRS from MN that will be in TTD this season, and then my BRZ. If I play in TTB, I think ill be way off pace to ever get any contingencies or be competitive with out spending a lot of money, can a NA car compete in B?
The new HP rules for TT3 look to have distinct advantages for some platforms. I know my buddy is dropping from TT2 to TT3 in his Civic cause of them, he is very excited.
Old 02-21-2016, 11:10 PM   #26
Uplink
Uplink's Avatar
Drives: anything you let me
Plans for Spring:
Depending on the tracks you run, FD might really help. On Thompson and NJMP - Thunderbolt with the stock gearing I find there's a few spots where you either have to back off a little and hold 7krpm for more than is comfortable or shift up to 4th for not much distance then back down for braking. Both are not ideal for running the fastest times.
Uplink is offline   Reply With Quote
Old 02-21-2016, 11:30 PM   #27
Uplink
Uplink's Avatar
Honestly, it's VERY easy. Mine weighs in at 2643.38lbs with a full tank of gas and I still have basically full interior (Shrader Rear Seat Delete Kit saved 19.375lbs) and my 245 Direzza's on 17x8 RPF1's actually added .8lbs. It's my daily and most people don't know there's anything not stock about it other than a bit of exhaust volume. Non-twin people have actually asked if it came from the factory with only 2 seats.
Remove spare tire/tools/manual, lightweight pulleys, rear seat delete, inlet tube & filter swap w/ noise tube delete, aluminum driveshaft (won't do CF, blew 2 on my Vette), lightweight battery, Perrin OP, HKS FP and Spec-L catback, remove rear bumper beam.
Can still replace the front beam with Beatrush, AP Sprint, HKS Header, and SPEC flywheel/clutch and shed an estimated 42.4lbs more to bring it down to 2,601. Remember that's on a full tank of gas (@6.3lbs/gal). Leave out 4gal and you're below 2,580. YMMV.
@Anthony has put together an exceptional thread on component weights here. Pick and choose what you're willing to lose and what your competition ruleset allows.
The Following User Says Thank You to Uplink For This Useful Post:
Anthony (02-22-2016)
Old 02-21-2016, 11:45 PM   #28
Uplink
Uplink's Avatar
Yep, that'll do it. Not only the larger oil cooler and radiator but the extra fluid you're adding too. I think even the Edelbrock SC kit adds in the neighborhood of 80lbs with all associated hardware and that has less 'plumbing'.
NASA TT - how do you do it celica73 Tracking / Autocross / HPDE / Drifting 3 09-11-2014 10:14 PM
Joining the NASA cjsporl1996 Tracking / Autocross / HPDE / Drifting 33 12-26-2013 05:51 PM
NASA made me do it robispec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 04-05-2013 12:48 AM
NASA-x at MIR with video about350 Tracking / Autocross / HPDE / Drifting 2 08-11-2012 11:42 AM
