Old 01-30-2016, 06:05 PM   #15
carczar87
Perpetually Sideways
carczar87's Avatar
Drives: '14 DGM BRZ, '94 Volvo 940 Turbo
LOL. You came here to settle an argument?
I disagree with those that say you are draining a battery when the car is running. If everything is working properly then as soon as you start the car you are running on the power from the alternator not the battery. The battery just completes the circuit and receives a charge once running.
Good call on that one @Tcoat, last time I ever come here to settle an argument
Originally Posted by justatroll View Post
It is a little more complex than the arguments above.
When you crank the engine to start, the battery provides a lot of wattage for a few seconds.
Up to 100 Amps of cranking current @ 12V (12V*100A = 1200VA or ~1.2 kW). (disclaimer numbers are WAG - wild ass guesses)
If it takes 3 seconds to crank, then that is 3.6kWs of energy or 3600 Joules.
Of course the alternator carries the entire car's electrical load once the car is started AND recharges the battery.
But the battery will not accept a charge in 3 seconds like it took to discharge it, it has a charge current that depends on a lot of things like input voltage, temperature, and age of battery.
What is the charge rate of the battery right after starting? , but if it is 10 amps, then it should only take 36 seconds to recharge.
1 Amp of charge would need 360 seconds or 6 minutes.
Turning on all of the car's systems lowers the system voltage which will reduce the battery charge current, which would take longer than leaving all systems off.
This only has a small effect IF the alt. is running under capacity as the output will remain in regulation.
So - it depends.
My BRZ definitely did not like taking lots of short trips and it WOULD eventually drain the battery and not start. It was worse during the winter (cold battery = slower charge?).
I had to replace the POS OEM battery at 35k miles.
So your dad is right - Lots of very short trips means you are slowly draining the battery by not letting it fully recharge each time.
What is the length of time it takes to get the battery back up?
But turning on all of the car'e electrical systems right after starting COULD mean it will take longer to fully recharge.
Thanks for the very in-depth info. As I mentioned, I do think that there are enough longer drives sprinkled in with my driving habits that it shouldn't be a huge issue for me. Generally speaking, I'll drive the 5 minutes to and from the train station during the work week and then on the weekends I'll usually have at least a couple drives of about an hour or more. I do actually have a battery charger around, as my '94 Volvo has needed it a few times (though it still has its factory battery ), so I can always use that if it ever got to that point...
carczar87 is offline   Reply With Quote
had a small argument about the BRZ with my gf yesterday. spicyricecake BRZ First-Gen (2012+) — General Topics 94 08-18-2023 10:58 AM
I had an argument today over some body damage. revil Scion FR-S / Toyota 86 GT86 General Forum 10 05-28-2014 11:51 AM
Argument from Ignorance. Asterisked Accolade Off-Topic Lounge [WARNING: NO POLITICS] 10 07-06-2012 06:14 PM
No winning argument ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 22 08-10-2011 02:01 AM
The Endless Argument: EFI or CARBURETION Axel Other Vehicles & General Automotive Discussions 2 02-13-2010 08:33 PM
