MisterSheep
Old 01-25-2016, 08:32 PM   #15
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Okay thanks, I heard the rattle almost the day after I had changed the trans oil to Motul. People were telling me it's normal to hear it and it's being worn..
Just to clarify, whoever told you that is wrong. The throwout bearing never interacts with the transmission oil. The TOB is located outside the transmission case, and separate from it. It has its own grease.
Originally Posted by fumanchu1 View Post
Alaska, Canada's tail, or asshole, whichever you prefer
I always thought of it as the bearded head on the body of Canada. Quebec is obviously the assh*le.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 01-25-2016, 08:33 PM   #16
Spartarus
...Just add nauseum
Spartarus's Avatar
Those RayBan aviators on the left, are knockoffs. Just sayin.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
go_a_way1 (01-25-2016)
Old 01-25-2016, 09:07 PM   #17
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I see you have many points in perception
Spartarus (01-25-2016)
Old 01-25-2016, 10:23 PM   #18
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Funny this thread should be at the top today, as I came here to ask a related question:
Has anyone here experienced a failure of the input shaft bearing?
I'm by no means an expert on transmission issues, or parts in general, but over the past month or two I started noticing a distinct whine while accelerating in gear, that appeared to be tied to engine RPMs. At first I thought maybe I was imagining things, or that - this being a light-weight sports car with minimal sound deadening - I was just hearing standard transmission whine and it was normal for this car.
However, this weekend I noticed it even more than normal. The noise is a very distinct whine. It goes away when I PUSH IN the clutch, and comes back when I release it, and I can definitely hear the whine "spin up" when I release the clutch. It as if I can hear exactly what the input shaft is doing. I hear it in neutral, and I hear it in every gear. The whine is even loud enough that I can hear the input shaft drastically slow down when I move the shifter from 1st to 2nd while driving, for example.
I looked up input shaft noise videos on YouTube, but they all have HORRIBLE mechanical sounds as if the transmission has grenaded. Mine is just a very smooth whine that is present, but not particularly loud. Only loud enough to be heard. It also comes and goes, though it is mostly always audible, but it isn't particularly alarming. I bet almost nobody who wasn't a car person would even have noticed the sound yet.
Is this a common issue? I've seen some posts on other forums for other vehicles where entire transmissions were replaced when this part went bad. Is it a complex job to repair? I can't seem to find ANYONE with this issue on the FT86 forums. Only throw-out bearing issues.
I'm running AMSOIL in the transmission, by the way, and have been for about 6 months now.
Stang70Fastback is offline   Reply With Quote
Old 01-25-2016, 11:39 PM   #19
humfrz
I've seen some posts on other forums for other vehicles where entire transmissions were replaced when this part went bad. Is it a complex job to repair? ............
From my experience, a failed transmission input shaft bearing is a relatively rare happening.
It usually goes bad if something else went haywire in the transmission first.
Yes, it's a bugger to replace; it seems that when they build a MT, they start with that bearing and build the rest of the transmission around it .....
Unless it's totally shot, about the only way to tell if it's bad, is to totally dissemble the transmission.
humfrz
Stang70Fastback (01-26-2016), Ultramaroon (01-26-2016)
Old 01-26-2016, 10:12 AM   #20
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
This is a in depth reasoning to what is happening to my car as well.
Instagram: trevor.parque
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
Old 01-26-2016, 03:31 PM   #21
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'm hearing exactly the same thing. Started getting it maybe a month ago. It's not my imagination. I'm kind of torn about how to proceed. Coming up on 22K miles. How many for you?
Old 01-26-2016, 03:34 PM   #22
MisterSheep
Killed Scion
I have 34k
Old 01-26-2016, 04:00 PM   #23
humfrz
I'm hearing exactly the same thing. Started getting it maybe a month ago. It's not my imagination. I'm kind of torn about how to proceed. Coming up on 22K miles. .........
OK, @Ultramaroon this is timely (for me).
Since my car is about 15,000 miles and your car is with 22,000 miles ...... I suggest the following.
You drop your transmission and completely dissemble it. Buy a new transmission and dissemble it.
Compare the two part by part, by visual inspection and measurements.
(take lots of pictures)
Take all the worn parts from the old transmission and stick them into the case of the new transmission. Return the "new" transmission to the dealer and tell them it didn't fit ..... you didn't realize you had an auto.
Your observations will be of great service to this forum ........ and I will know when to expect to trade my car in.
What do you think, gang ??.......
humfrz
DJCarbine (01-26-2016), Tcoat (01-26-2016)
Old 01-26-2016, 04:07 PM   #24
MisterSheep
Killed Scion
humfrz
If only it would be that easy.
Old 01-26-2016, 05:04 PM   #25
Stang70Fastback
A.K.A. Starlord
I am just shy of 25,000 miles... so seems like we're kinda-sorta-ish in the same ballpark.
Old 01-26-2016, 05:38 PM   #26
Ultramaroon
not playing cards
Hey, how about we completely disassemble and inspect both your and my transmissions. Then we can compare differences.
Old 01-26-2016, 06:36 PM   #27
HachiRo
Drives: 2013 White-Out FRS
I also hear a very faint whine, but very faint. My exhaust is loud so that makes it harder to hear haha. However, I'm at 54k miles and my throwout bearing is loud as f**k. Took it to the dealer last month and of course I couldn't replicate it to them :| But it squeaks everytime I step on the clutch lol.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 01-26-2016, 07:06 PM   #28
Spartarus
...Just add nauseum
Spartarus's Avatar
However, this weekend I noticed it even more than normal. The noise is a very distinct whine. It goes away when I PUSH IN the clutch, and comes back when I release it, and I can definitely hear the whine "spin up" when I release the clutch..
If you are rolling in gear, the input shaft will be moving at the same speed, regardless of whether the clutch is in or out.
from neutral to in-gear, there will be a spin-up noise if you have bearing or synchro issues. The only time the input shaft will "spin up" is going from an extended roll in neutral to being in-gear, or rolling from a dead stop. Otherwise, it will always be spinning.
If there is a "spin up" noise from clutch-in to clutch-out regardless of whether you are in gear, I can explain that phenomenon based on a nearly seized throwout bearing, as it begins to spin in relation to the clutch fingers, dragging against them because the minimal preload is insufficient to keep a dying bearing spinning, but the preload is sufficient to create noise against the clutch fingers. That theory can be confirmed easily; pull the trans and look at the TOB.
Otherwise, gear whine under load is usually not bearing related. It is usually related to gear alignment. If you have worn out some of the tolerances in the transmission under hard driving, whining will start to emerge. It is not necessarily a bad thing, as it doesn't necessarily indicate harm being done, just an increase in gear lash, or decrease in bearing preload. Problems of helical gears. Internal bearings going bad in a transmission don't whine. They sound like a blender full of nails.
-Spartarus
Trans insert and block whine reduction Jake_86 Engine, Exhaust, Transmission 18 10-21-2021 10:49 PM
why do some people whine? Eighty 6 Scion FR-S / Toyota 86 GT86 General Forum 116 01-25-2016 06:22 PM
2013 FR-S A/T whine.... Tromatic Engine, Exhaust, Transmission 6 01-20-2014 12:57 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
AT trans whine? Anyone else? Hardrock4445 Engine, Exhaust, Transmission 1 05-30-2013 06:46 PM
