Old 05-13-2016, 11:22 PM   #15
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by choiboie View Post
Culprit was the cable. Should have the new unit and cable by tomorrow!!!
Sent from my SM-G920V using Tapatalk
could you tell me how you found out it was the cable? my oft worked fine the last time I used it, (close to a year ago), but i wanted to do a checkup and got the same "operation failed" message for diagnostic. I haven't unplugged the battery yet, but I did notice that when I lightly tug the cable side to side, the OFT looses power then restarts.. not sure how to tell if it's the cable or the connector in the OFT.
Old 05-13-2016, 11:29 PM   #16
choiboie
Drives: 2013 Fr-S UltraMarine
I had to send my unit back in.and shiv found the problem. I didnt have another twin to check locally so I had to wait.
choiboie is offline   Reply With Quote
Old 05-13-2016, 11:30 PM   #17
choiboie
If you have a friend that has the same car. Try to see if it works on theirs. Also I went to autozone and had them check my ecu and they were able to read my ecu. So I figured it was the cable.then shipped and shiv confirmed
Old 05-14-2016, 03:46 AM   #18
Target70
Target70's Avatar
Alright, thank you.
I don't have any friends with the same car. I'll go check the with autozone before I do anything else.
If they will sell a new cable that might be the best way for me to go. I'll just grab a multi meter and ohm out the cable, and maybe try to tweak the pins for better contact with the OFT first though.
Unable to find auto dimming mirror connector 1040 Cosmetic Modification (Interior/Exterior/Lighting) 2 12-28-2015 10:52 AM
EcuTek Unable to Increase Load Limits Skorov Software Tuning 35 06-25-2014 12:56 PM
Unable to loosen crank pulley, even with 6 foot break bar! tbertran Engine, Exhaust, Transmission 36 05-20-2014 01:34 PM
Unable to program TPMS if you have Ecuteck? EL7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-04-2013 04:20 PM
Unable to hold idle. CSG Mike Issues | Warranty | Recalls / TSB 22 05-20-2013 06:00 PM
