Old 06-29-2012, 03:28 PM   #15
Juan@aePerformance
Juan@aePerformance's Avatar
Drives: Raven Scion FRS
Originally Posted by Slartibartfast View Post
I'm interested in seeing this. Will you do a DIY?
out of laziness probably not, but if it comes out sweet I'll post pics.
Juan@aePerformance is offline   Reply With Quote
The Following User Says Thank You to Juan@aePerformance For This Useful Post:
Slartibartfast (06-30-2012)
Old 07-11-2012, 08:50 AM   #16
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Is this how tint shops get the third brake light out of the way to tint the rear window?
Grimlock is offline   Reply With Quote
Old 07-13-2012, 10:50 AM   #17
sirus
86 Owner
sirus's Avatar
Drives: White GTS 86
Wow... that took less than 10 minutes. I can see that puting everything back may take a bit longer though.
Just FYI: To remove the air bag cover panels push down on the center tab (top and bottom alternatively) of the blue "hangers". This will get them out of your way. Not sure about anyone else but they were in my way and just a general pain in the @ss.
Thanks again for the DIY!
On the road. Check your mirrors!
sirus is offline   Reply With Quote
Old 07-13-2012, 10:56 AM   #18
sirus
86 Owner
sirus's Avatar
Originally Posted by TrickyFrenchman View Post
And not to hijack this thread, but how are "tinters" dealing with the automatic windows when opening the door if one is to not roll down your windows for several days?
Apparently the guy doing mine says he has to use a heat gun or something to help cure the tint so opening and closing the door doesn't affect the tinting and cause bubbles. I can let you know how mine goes tomorrow
Old 08-02-2012, 11:21 AM   #19
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Draco-REX View Post
I just tugged it out from the sides.
BUT! It looks like this method exposes the bolts for the rear seatbelt reels. I was thinking I'd have to remove the rear seats to get those panels free. Good to know!
Originally Posted by DarrenDriven View Post
I ended up just removing the top section of the third brake light and that was enough room to allow the tinters to do their job.
So the top of the brake light just pops off, as in clips on? Tinting is in the future for me, and I was wondering how to deal with this without tearing apart the whole deck.
Getting mine tinted tomorrow, would love some more detail on how to get the 3rd brake light out of the way easily without removing the entire decklid and all the associated interior panels. Specifically, how to remove just the top section as DarrenDriven did, that should give my tinter enough room to do his job.
Old 08-02-2012, 11:34 AM   #20
ATL BRZ
ATL BRZ's Avatar
Nevermind... Found the method in another thread.
Originally Posted by Kwaziekeller View Post
It's pretty easy to pop the top portion of the 3rd brake light assembly off, so if you're bored and want to see if your LED's are burned out too, it should only take a few seconds...
Disconnect the 3rd brake light plug in the trunk.
Push up on one of the corners of the assembly, just above the "seam" of the 2 plastic pieces on the "front" (towards the front of the car). There are 2 snaps (one in each corner) that will pop apart.
Once you pop one corner, pop the other.
You'll have to lift the "front" portion slightly and pull it towards the front of the car, being careful with the wires etc.
The "rear" part of the top half of the assembly has two tabs that slide into the bottom half, so putting it back together can be a little tricky, but just reverse the steps.
From another forum:
the 3rd brake light can come apart in 2 pieces. at the seam push up and then slide back and unplug. when putting it back on put the front end down first as there are 2 tabs it has to slide under to fit right
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
Fakk (05-19-2015), Kwaziekeller (08-03-2012), RMStringer (01-23-2013)
Old 12-15-2012, 11:16 AM   #21
g0lden
Drives: 2013 Scion FR-S Argento
i lost a clip on each side :-(
g0lden is offline   Reply With Quote
Old 01-08-2013, 12:41 AM   #22
captain_jack
captain_jack's Avatar
Tinters are just pulling out the door pin switch to stop them from going down while door is open. Its a negative trigger door pin. Removing it solves the moving issue while its being tinted.
Old 06-13-2013, 03:44 AM   #23
tm86
Drives: 2013 Dark Grey 86B
Thank you @Moshpit37, your guide helped me remove my parcel shelf
I managed to skip a few steps by not removing the smaller triangle shaped panel. I removed the 10mm bolt but not the white panel clips. With the bolt removed there is just enough leeway to wiggle the parcel shelf out.
tm86 is offline   Reply With Quote
Old 06-14-2013, 07:41 AM   #24
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
I tried to get my rear deck out when my car was getting tinted, and I lost TWO plastic "popits" in the interior of the car somewhere. I was furious! Luckily, I was a block from a Toyota dealer and they had some near-exact matches at the parts desk.
Great writeup, I am adding it to the DIY Directory right now...
http://www.ft86club.com/forums/showthread.php?t=7365
How do you just remove the top section of brake light?
Chinadian is offline   Reply With Quote
Old 08-02-2013, 05:57 AM   #25
GTS 86
Drives: Tornado Grey 86 GTS AT
Help, trim clips fell down as per your warning (didn't know what you meant at first) and are out of my reach inside the chassis, how do I get them out (
GTS 86 is offline   Reply With Quote
Old 08-12-2013, 08:45 PM   #26
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Not my video but it looks like it belongs here.
[ame="http://www.youtube.com/watch?v=OHwhM5UWpZU"]How to remove third brake light Subaru BRZ 2012 - YouTube[/ame]
jimmillion is offline   Reply With Quote
The Following 2 Users Say Thank You to jimmillion For This Useful Post:
FyeaFRS (11-06-2013), JPxM0Dz (08-13-2013)
Old 08-13-2013, 12:14 PM   #27
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Awesome video! Thank you! I am going to remove the third break light and put some dynamat inside there and see if it will stop some rattling on the rear window
AG3NT_5CARFAC3 is offline   Reply With Quote
The Following User Says Thank You to AG3NT_5CARFAC3 For This Useful Post:
DNAPoPo (08-25-2013)
Old 08-13-2013, 12:23 PM   #28
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Good to know
2URGSE
JPxM0Dz is offline   Reply With Quote
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 03:23 PM
How to remove third brake light (to tint back window) 96z2 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-07-2012 04:14 AM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 07:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
