01-23-2013, 11:01 AM | #15 |
Driving Coach
I found the bumper cover to be really flexible and I had enough clearance lifting it up (helps to have a buddy do this for you) to remove the stock snorkel and slip that out by the passenger headlight. Then I slipped the CAI pipe in through the engine bay side by rotating it to clear the tab for the bolt, and then finally slipped in the filter by again lifting up on the bumper cover on the passenger side by the headlight, and fitted it and tightened the hose clamp down.
01-23-2013, 11:41 AM | #16 |
Drives: 2013 Asphalt FR-S
Looks great!
Anyone know if you can use the perrin inlet tube with this Perrin True CAI??? I would assume so but it never hurts to confirm... |
01-23-2013, 11:45 AM | #17 | ||||
Drives: 2013 Subaru BRZ MT Limited
As I said before, removing the bumper is required due to the size of the pipe, you must remove it in order to get the pipe past the radiator support header. I have never heard of a VMS intake for the BRZ or FR-S please provide me with a link for comparison. The hole next to the radiator support is not very large, this is definitely the biggest pipe they could fit in there without cutting. The filter is also placed dead center in the bumper. I will agree the design is NOT the easiest to install, but I am pretty sure you can replace the filter by just unbolting the top of the bumper and popping the filter off. I don't know, I have not tried it yet. We'll find out soon enough with how much I drive, my BRZ already has 12,000 miles on it.
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
01-23-2013, 11:46 AM | #18 |
You can, they were made as a set.
01-23-2013, 11:47 AM | #19 | |
Driving Coach
01-23-2013, 12:24 PM | #20 |
01-23-2013, 01:28 PM | #21 |
01-23-2013, 04:29 PM | #22 |
I'm one of the few people who actually likes having a sound generator, don't ask me why, I just like it. Perrin doesn't have an option to keep the SG on their intake duct so I didn't buy it, I may purchase the AVO later but I'm not in a huge rush.
01-23-2013, 04:32 PM | #23 | |
01-23-2013, 06:04 PM | #24 | |
Drives: Corolla
A little work for peace of mind knowing your intake gets cool air vs sucking in hot air in the engine with little to no gain. IMO if you want a good intake youll need to do that. Whether its an intake duct or CAI. Its honestly not that big of a deal. You get good gains with it and imagine with a silicone tube from Perrin. Gains would be even better and smoothed out vs using the stock orchodion tube its basically made to be used with it. People in another thread were complaining of a drop in whp saying it was 5 whp when it wasnt even true. Their was no gap in the dyno at that 3500 rpms like at the peak when you see 4 whp. The silicone tube IMO will smooth out the airflow and compliment your other mods. If you have their header back Perrin noted that they saw as high as 4 whp just from adding the tube to the CAI/Header back. for 300 bucks you get the CAI and 140 more for good gains versus other intakes on the market which dont even do anything at all besides give you some sound. For what the others cost you might as well just get a drop in and silicone tube than getting those intakes. Most of those intakes either lose power or gain 3 whp while Perrins CAI which is priced competitively gains 5 whp already without the silicone tube. |
The Following User Says Thank You to ChaChas345 For This Useful Post: | crank (01-25-2013) |
01-23-2013, 06:09 PM | #25 |
Driving Coach
Yep, and I'd recommend anyone installing any CAI to go ahead and take the bumper off if they have the time. It's much easier to install AFTER you get the bumper off, but taking it off and putting it back on is kinda tedious. I'll be taking my bumper off sooner or later for other mods, but I'd like to do it as infrequently as possible.
01-23-2013, 06:18 PM | #26 |
You pretty much have to remove the stock bumper at least one time to get the OEM tube out. Some are just prying and bending the bumper to slide it out which works too, but it can be risky. The only downside I see to this system is having to re-oil / clean the filter. Once you start removing the bumper though, it goes quick. Just be careful with those pop screws... just picked up 4 extras from the dealer today because I messed mine up pretty bad.
01-23-2013, 08:37 PM | #27 |
I am wondering if its worth it to switch from aFe(not installed yet) to the Perrin CAI. But I want to get rid of the noise generator which means I need the silicone tube as well which together will be like 400$ Yikes!
01-23-2013, 08:41 PM | #28 |
Driving Coach
$453 before tax and shipping
Similar Threads | ||||
PERRIN Silicone Intake Duct Review | JoeBoxer | Engine, Exhaust, Transmission | 287 | 01-24-2018 10:01 PM |
Perrin Catback Exhaust Installation and Review! | Sony | Engine, Exhaust, Transmission | 316 | 01-24-2016 01:01 PM |
cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
cold air intake? | carbonBLUE | Engine, Exhaust, Transmission | 72 | 09-30-2013 12:56 PM |
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley | draggin_az | Engine, Exhaust, Transmission | 21 | 04-29-2013 04:58 PM |
