Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-12-2021, 04:24 PM | #15 |
pessimistic skeptic
Perrin is selling that little rubber hose for the price of a complete tire. And it makes no difference in performance. Save your money!
The Following User Says Thank You to mrg666 For This Useful Post: | gpvecchi (02-13-2021) |
02-12-2021, 05:04 PM | #16 |
Barred
Drives: My18 wrxsti My19 brzts
Wish I could get a good tire for $160AUD
Wait until my Flex capacitor hits 88
02-12-2021, 06:29 PM | #17 |
02-12-2021, 08:59 PM | #18 |
Drives: 2014 GT86
Perrin's tube due different diameter probably needs MAF sensor rescaling. Hmm .. i guess that would be also reason for me to consider stock sized ones instead. Obviously, ecu tune can be retuned to account also that, but still why, if one can avoid extra hassle.
The Following User Says Thank You to churchx For This Useful Post: | gpvecchi (02-13-2021) |
02-12-2021, 09:21 PM | #19 |
pessimistic skeptic
02-12-2021, 11:12 PM | #20 | |
Drives: JRSC BRZ SOLD
The tube after the MAF section or their CAI? The MAF doesn't care about the section after the air has passed it.. |
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | x808drifter (02-13-2021) |
02-13-2021, 07:20 AM | #21 |
Drives: 2017 Toyota 86 (860 SE)
02-13-2021, 09:35 AM | #22 |
02-13-2021, 10:47 AM | #23 | |
Drives: 2014 GT86
Which is of different diameter then stock intake, so i predict that more then possible that changes MAF readings as per same reading now different air volume passes in. |
02-13-2021, 10:48 AM | #24 |
Drives: 17 Asphalt 86
I required minor MAF rescaling with the inlet hose, header+OP. It was relatively minor adjust from my understanding. Tomm.brz did my tuning.
Inlet hose is said to he worth 2-4whp. Pretty worthless number but not bad considering most intakes are at best 5whp and cost 3x the price. |
02-13-2021, 11:36 AM | #25 | |
02-13-2021, 04:00 PM | #26 |
I try argumenting why I'm looking for the same stock shape for hose explaining the theory after the MAF.
MAF sensor works measuring a fraction (let's say 10%) of the quantity of the air passing by its duct; more cold air with more pressure (so more dense) is good. So, making mods BEFORE sensor to reduce pressure loss (i.e. filter and intake ducts) are good and doesn't need MAF scaling (measure is still 10% of more air). Mods on MAF housing absolutely need rescaling (if I double the pipe where the MAF sits, it will not still measure 10%, but 5%). Mods after MAF should THEORICALLY not need rescaling: try thinking of you drinking a coke with a straw that has a MAF sensor on the tip. The quantity of coke that enters the straw is the same that exits in your mouth. Using a larger straw with rescaled MAF is the same (but with less effort); using a longer straw is the same (but with more effort). Using a smooth silicone straw with less bends is the same (but with less effort). This SHOULD not need rescaling. Using a longer straw made with metal that passes inside an engine bay, will probably makes you drink hot coke. As MAF is calibrated on temperature shift too, this probably needs rescaling. The function of the resonator on the hose is not really clear, Subaru says it's for noise, my butt dyno for low torque. Probably both, and to prevent back pressure waves hit MAF sensor. That's why I would like to keep stock shape, to have the bigger, shorter and straightest hose possible, but smooth and retaining the resonator. |
02-13-2021, 04:23 PM | #27 |
I get what you're saying, I just think you're over-thinking the difference between the stock tube and the Perrin. The difference in flow isn't zero, of course, but it's well within the margins of the stock MAF and tables to compensate. Like I said, the logs I pulled after I dropped the Perrin in there didn't show anything on the trims that would indicate the need for a MAF rescale. I might do it anyway at some point just to play around, but it won't net me anything really, in terms of performance or efficiency.
02-13-2021, 05:37 PM | #28 |
+1 On the over think. These cars have been out for 8 years now and the tubes have been out for around the same amount of time and not once has MAF rescale for one came up. Stock, Perrin, custom 3.25", I ran and logged them all. The MAF doesn't care. FWIW I'd stick with a stock MY17+ setup as it has a very gentle bend compared to most aftermarket tubes, is already slightly larger than the MY13-16 intake and aesthetically looks better.
Similar Threads | ||||
NEW HPS post-MAF Silicone Intake Hose W/ Hardware | Laz84 | Engine, Exhaust, Bolt-Ons | 7 | 07-15-2018 10:55 AM |
Silicone Air Intake Hose $40.00 !!!! | Depo Racing | Engine, Exhaust, Bolt-Ons | 163 | 08-23-2016 02:08 PM |
Perrin Cold Air Intake and Silicone Inlet Hose | digital_assassin | Engine, Exhaust, Bolt-Ons | 5 | 10-31-2013 11:54 AM |
WTB Perrin Silicone Intake Hose (Black) | 2013GTRNate | Engine, Exhaust, Bolt-Ons | 0 | 09-26-2013 12:33 AM |
Perrin silicone intake hose, sound gen del. | Teknian_Culprate13 | Engine, Exhaust, Bolt-Ons | 11 | 08-24-2013 09:05 PM |
