Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-06-2022, 01:24 AM | #15 |
extra what?
The kit uses a larger bearing with an ID to fit the sleeve. I'm looking forward to installing mine someday.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soundman98 (11-06-2022), Spuds (11-06-2022) |
11-06-2022, 08:27 AM | #16 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | soundman98 (11-06-2022), Spuds (11-06-2022) |
11-06-2022, 10:51 AM | #17 | |
The Dictater
Drives: '13 Red Scion FRS
I wonder why nobody makes a machined retainer cover out of a harder material... [CoughVerusCough]
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (11-06-2022) |
11-06-2022, 11:11 AM | #18 |
ProCrastinationConsultant
lol, well someone does. pdm. they're offering a solution, but they're also attempting to corner the market with rebranding oem toyota parts for the bearing. which is the part that i really don't like, and would spend extra with a different company willing to be more open on the situation just selling the sleeve and stating which bearing works with it.
if pdm sold just the sleeve for the $150 with a note about which bearing, or even included an oem-packaged bearing, i'd already have ordered it. it's the sneaky 'buy our bearing' thing and it's an oem part with sandpaper marks and someone hand-etching the part number in it that really gets under my skin.
The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (11-06-2022) |
11-06-2022, 11:34 AM | #19 | |
The Dictater
That is my hesitation as well.
The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (11-06-2022) |
11-06-2022, 12:06 PM | #20 | ||
I would have no qualms using this product but then I have no delusions that all products need to be or are specially made.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (11-06-2022) |
11-06-2022, 02:10 PM | #21 |
extra what?
It's a modified version of this unit. The original part number is still etched to the case. Blocks are welded to the inboard sides of the ears to close the gap. That's all.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (11-06-2022) |
11-06-2022, 07:49 PM | #22 |
The Dictater
Ordered the tsk1. Verus clutch bits will be ordered as soon as I can decide what color LCA to get. (Yes, I am stuck on what color a part that no one sees will be).
It's reasonable to order a friction plate, pressure plate, and pilot bearing while I'm at it right? I'll report back when I get stuff installed.
11-06-2022, 09:19 PM | #23 | |
extra what?
Personally, I've never had trouble massaging a disc into place with those plastic tools. It just takes some feel and patience.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
11-06-2022, 09:22 PM | #24 |
Chicken bucket
Drives: '15 ultramarine
Now I whistle every time I press the clutch.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
11-06-2022, 09:29 PM | #25 |
extra what?
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Sapphireho (11-06-2022), soundman98 (11-06-2022) |
11-06-2022, 09:45 PM | #26 |
Chicken bucket
The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | soundman98 (11-06-2022), Ultramaroon (11-06-2022) |
12-22-2022, 09:12 PM | #27 |
The Dictater
Well, I can say for certain the PDM TSK1 will NOT work with the Verus clutch fork. The clip types are different. The OEM fork would probably work, as the clips on the TSK slide into the backside of the arms. The Verus fork, being solid, does not have any place for the clip to go. Note that the holes in the back of the Verus are not aligned to allow this clip to work, even if the arms were thin enough. See attached image.
Now I need to pick which to keep. TSK1 is the more practical choice as I can just reuse the oem fork right now. But I like the Verus fork, and I am second guessing not ordering/installing a new clutch while I have the transmission off so that will give me an excuse to wait for it.
12-22-2022, 11:27 PM | #28 |
extra what?
I'm not suggesting "do it this way." I'm just sharing, FWIW. If a verus fork dropped into my lap, here's how I'd play it.
There are two critical flaws in the factory design. 1. The main pivot begins to creak - a violent event given the forces involved - when the socket wears into the flat face of the ball deeply enough. No amount of lube prevents that. 2. The center bushing of the TOB and that quill are a shit combination. When the fretting gets deep enough, they bind. If the verus ball is fully spherical, I'd modify the verus fork to fit the tsk bearing. Otherwise, I'd modify the old fork the same way I did the last time I had mine apart. I used a dremel to grind out enough of the center of the socket so none of it ever comes into contact with the flat part of the ball. It has cured the creak.
Similar Threads | ||||
Clicking sound when Pressing Clutch Pedal | Archetyp3 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 01-03-2020 11:57 AM |
Whining noise when pressing clutch? | cupcake917 | Issues | Warranty | Recalls / TSB | 14 | 03-12-2019 01:49 PM |
RPM goes up to 1.5k when pressing the clutch while slowing down | pcuerpo | Issues | Warranty | Recalls / TSB | 13 | 02-28-2018 01:37 AM |
Is it bad to have my ankle fully extended forward when pressing the clutch? | cat94 | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 11-24-2016 04:10 PM |
Upgraded Clutch now seems like TOB is pressing on pressure plate when not depressed. | Rybot | Issues | Warranty | Recalls / TSB | 35 | 03-06-2016 08:23 PM |
