Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#15 |
Drives: Rocket Bunny V3
Even if you buff it off, it will come back within the next 6 months. I'd suggest just replacing that headlight assembly as a whole.
#16 |
Drives: 2015 FRS Asphalt
ceramic coated with either cquartz finest or optimum opticoat pro.
#17 | |
Drives: frs
#18 |
Country Boy 4 Life
That is what you would suggest, huh? Do you buy a new car when yours needs washed?
I LIKE TIRES! |
The Following 3 Users Say Thank You to Leonardo For This Useful Post: |
#19 |
I have considered this!
#20 |
The Gunshine State
Drives: '14 BRZ Limited
My buddy owned a paint booth at the time so he re-cleared my headlights for me on my Speed3 and they did not develop any hazing after that. It's all in the prep; make sure you do a good job sanding and restoring them first.
![]() Current DD: M235i |
#21 |
Drives: 14 BSP Edelbrock BRZ
If that is what is needed the best solution for most people would be to grab a can of SprayMax 2k clear. It is the only two part epoxy clear that comes in a can. You push a tab in to burst an internally-stored container of activator, shake or two minutes and have a 24 hour pot life. One can should do both headlights.
The Following User Says Thank You to toast For This Useful Post: | Tcoat (02-09-2018) |
#22 | |
Thanks.
#23 |
They also make a fantastic filler primer for small projects where you don't want to get all your spray equipment set up (or don't own spray equipment in the first place).
The clear is quite fantastic and gives exceptional results with proper prep. |
#24 |
#25 |
Drives: Crapcan
#26 | |
Drives: 2013 Subaru BRZ Limited (Black)
One note: this product REQUIRES a respirator. You WILL die if you use this in a closed space ![]() |
#27 |
Any two part epoxy will have the same inhalation dangers. I don't use a respirator, but I do small parts and then leave the garage for the ten minutes of flash time between coats.
#28 |
Drives: 2005 Toyota Camry
hmmm... perhaps you can say OP's headlights are.... toast?
The Following User Says Thank You to mav1178 For This Useful Post: | Tcoat (02-10-2018) |
changing from 2015 jdm gt86 headlights to frs headlights | 420zn6 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 12-16-2016 04:18 PM |
WTT: Trading my blacked out OEM headlights for your stock chrome headlights | DCStorm | Exterior Parts (Aero, Lighting, Etc.) | 7 | 06-28-2015 11:01 AM |
NJ FT:Black BRZ headlights for Stock BRZ headlights | Jive Turkey | Exterior Parts (Aero, Lighting, Etc.) | 11 | 05-30-2015 09:53 AM |
GT86 headlights vs. Maserati Ghibli Headlights | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-29-2014 08:39 AM |
