Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
#15 |
The condensation on the milk would be enough to trigger it honestly....
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: | ermax (10-01-2018), Ultramaroon (10-01-2018) |
#16 | |
Well tech stream you have you buy a usb to OBD2 cable off ebay from $14-$20, and you just pirate the software Carista has changed their policies around so much I think it's $20+ for all modification unlocked permanently and $20 for their adapter which works better than the other elm327 dongles I've had. And it works on multiple cars other than toyota. Regardless they are both well worth it.
#17 |
Only users lose drugs.
Drives: All the time
I can confirm that three spaghetti squash were enough to trigger the alarm. lol
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#18 |
You can get a Techstream compatible cable on Amazon for $18. Everyone should have Techstream in their tool box.
The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (10-01-2018) |
#19 | |
chicken tonight
A wet towel will trigger it.
#20 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Dake (10-01-2018) |
#21 | |
![]() The picture you showed is a capacitive pressure sensor. If enough of the pad is depressed, it reduces the resistance to a point to trigger the system as thinking someone is in the seat. Here's a simple description of how it works. Just thinking logically, a "moisture sensor" would be a pretty strange way to measure occupancy. If you get dressed in the morning and put on a fresh pair of clean jeans and walk out the door, there is not enough time for your body's "natural moisture" to seep through the jeans and through the seat fabric. Are you suggesting the car won't think someone's in the seat for however long this transfer takes place? I'm not saying moisture doesn't interfere with the system in some way and cause a false signal (probably by also reducing resistance). Similarly our cell phone's signals interfere as well. But primarily it relies on a certain pre-programmed amount of weight. This is intentional because it was learned long ago that an airbag deployment with a small person can do more harm than good. Remember when we had manual buttons, switches, or even a key hole to turn off the airbag if a child was in the front seat? That child would still generate "moisture" today, yet the airbag does not turn on if it doesn't meet the threshold. |
#22 |
This sensor very literally does NOT measure weight (in the physical sense). Period. That dumbbell is made out of medal which is conductive therefore you can induce it with electricity and then measure the capacitance of it. The sensor however was designed and tuned to measure the mass of a human body based on it's capacitance. Anything else placed on the seat will not be accurately measured. For example a cell phone, charging cable, wet towel, ect ect. Actually even an underweight child with wet pants on will cause it to think it's an adult because the water causes the electricity to conduct better throwing off the calculation. If you spill a drink on the seat it will think someone is sitting in the seat too.
This is also explained in the owner's manual BTW. Also, the sensor you linked to is NOT what is used on our car. What you linked to was the older style with two layers which short together when a specific weight is applied to it. We have a capacitive system in our car. It's purely electric. Think of the two styles similar to how you would think about a resistive touch screen vs a capacitive touch screen. A resistive touch screen uses two layers of film that short together when being pressed. They work great in industrial applications where people have on dry gloves. Then you have capacitive touch screens which can't be used with gloves on (unless you have special conductive gloves). I believe they went with a capacitive system because they are more durable. The old resistive types become inaccurate after weight and heat has been applied to them for years. The layers lose their rigidity and collapse too easily. Last edited by ermax; 10-03-2018 at 12:06 PM. |
The Following User Says Thank You to ermax For This Useful Post: | Tcoat (10-03-2018) |
#23 |
Ah gotcha. So it's more about conductivity than "moisture".
Knowing is half the battle. |
The Following User Says Thank You to Dake For This Useful Post: | ermax (10-03-2018) |
#24 | ||
This ^ All of this. Quote:
That was why I picked dry or wet bricks not metal dumbbells for the example.
Passenger Seat Belt Warning Chime goes on even though there's no passenger. | idreamofdrifting | Issues | Warranty | Recalls / TSB | 58 | 10-11-2017 10:31 AM |
Seat belt sensor? passenger side | tigermack | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-17-2014 02:12 PM |
Sensitive Passenger seat??? | Trmx2 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-07-2014 07:35 PM |
Passenger seat belt warning when I put phone on seat!??? | Kayzer Soze | BRZ First-Gen (2012+) -- General Topics | 20 | 09-13-2013 11:29 AM |
Passenger side seat belt | frs-guy | Issues | Warranty | Recalls / TSB | 1 | 10-11-2012 12:39 AM |
