Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#15 | |
Automotive Enthusiast
"Horsepower sells cars, torque wins races." Enzo Ferrari |
#16 | |
Drives: '06 AM V8V Coupe
![]() Right, short stroke is the key, although it doesn't have to be that short. The F20C had an 84mm stroke, 90mm bore. The 2ZZ-GE was 85mm stroke, 82mm bore. If Honda does a square 81mm V6, that would land them at 2.34L displacement. The F20C lost a lot of torque above its power peak, I'm guessing because the stroke was pushing the mean piston speeds to the limit, so with 81mm stroke it could make slightly better power over 8000rpm. With direct injection, 3 stage vtec, 12.5-13.0 compression ratio, Honda should be able to get 290hp out of such a monster. Their new multiple speed oil and water pumps (long overdue in the automotive world really) should gain back the horses lost to emissions equipment. In an ultralight car, it could definitely be competitive, if they can maintain original NSX weight it'll be almost as fast as a Cayman S. If they can't drop the curb weight down, there's always the option of increasing the bore a bit to get more power. I'm just describing my dream car toned down a little ![]() Last edited by serialk11r; 11-07-2012 at 12:10 PM. |
#17 | |
The description is spot-on (as far as V6 ideas go). I would expand on your idea and urge Honda to borrow some from Ford's Ecoboost division. I small twin-turbo setup will really pump out the horsepower, keep torque in the respectable range throughout the power curve, and allow for some epic gas mileage. From the sounds of it, you are proposing some great ideas. |
#18 |
Boost is definitely a good idea, I just wonder what Honda is thinking because they are very reluctant to use boost. Toyota is similar but they at least have special editions of cars with superchargers and stuff. I suppose it does cost more money to boost an engine. Boost allows a "dual efficiency band" so the gears can be longer for the street.
Maybe they'll give us a pleasant surprise with a variable drive supercharger ![]() |
The Following User Says Thank You to serialk11r For This Useful Post: | Wes B. (11-07-2012) |
#19 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
#20 | |
I understand what you mean though. I do think the VQ37VHR is a great engine for what it is, it's got a great powerband thanks to the VVEL, and more manufacturers need to get off their asses and work harder. However I think that chasing torque via high displacement is for trucks and SUVs and vans, not sports cars. When Nissan makes a VQ25VHR with VVEL let me know. My car turns 3600rpm at 65mph, so I understand why "passing power" is appealing. It's sometimes nice to just mash the throttle and go, and never shift on the highway. Maybe the novelty hasn't worn off yet, but I've been driving it for about 3 months and I still feel that shifting gears is an important part of the driving experience. You can never have enough torque, there is always less power in top gear than the next gear down. Some of the older 4 bangers like the 4ag, 3s, etc. have crappy powerbands, but 2ZZs and K20s and F20Cs with lift have great specific torque everywhere, how much power you have is dictated by how many gears you drop down. On a torquey engine that loses a huge chunk of its torque by redline, your power output increases more slowly with the revs because the torque drops. Where's the fun in that? EDIT: I will concede that boost for torque is a good thing, because you can only put so many gears into the car, and boost essentially gives you an extra set of gears. But gigantic displacement naturally aspirated engines that make low specific power by virtue of lack of technological features are sin. By the way, 2.4L is not even that bad for torque, a base Cayman is only 2.65L or something. I understand that 2L in a 26-2700lb car might be a little anemic if you're not winding it out, but 2.4L is not that bad in a light car. Last edited by serialk11r; 11-07-2012 at 01:31 PM. |
#21 |
2 wheel member
Drives: JZA80, 997.1, Taco
Honda did make a V8 a long time ago.
![]() I honestly believe Honda can make a much better (fun sports) car to the likes of the GTR and even the LFA but don't seem too motivated. ![]() http://www.mulsannescorner.com/mugenv8.html http://www.vtec.net/news/news-item?news_item_id=319284
The Following User Says Thank You to RRnold For This Useful Post: | M-17 (11-07-2012) |
#22 | |
#23 | |
Drives: -
http://honda-tech.com/showthread.php?t=2986167 |
#24 | |
At these price levels, I think most people want to buy something special with emotional appeal, and wouldn't mind paying more for that. Affordable is already out of the question. Why buy a Honda with a J35 when you can get a Porsche Cayman that happily hits 8000rpm? (okay the new Cayman hasn't been announced yet but the new Boxster does 7800rpm) And why buy a Honda with a J35 at 30k when there's a 370Z with pretty much exactly the same specs at that price point already? The VQ37 is more rev happy than the J35 can hope to be anyways. Honda has done some crazy stuff before. F20C and C30A/C32B were very limited run engines, and the cars they came in commanded a premium for that. Better to charge more for something different than make something that is essentially a copy of a competitor. If Hyundai can spit out new engines every year, I think Honda or Toyota can spare the cash to do a couple of new engines, but my anti-profit-maximization thinking would get me shot if I worked for them :P Last edited by serialk11r; 11-07-2012 at 02:53 PM. |
#25 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
#26 | |
86 Member
#27 |
Drives: -
haha this^ . for example, very similar versions of Kia's/hyundai's lambda 3.8 v6 were/are thrown into about 10 different vehicles so it wasnt a small production run. i think they used the same block with the same stroke in their 3.5 lambda (with a smaller bore obviously) so there is potential for lots of the same parts to be made
#28 | |
1st86 Driver!
I disagree. I like it. I'm assuming that the production version would be toned down a bit. For example, it would probably lose a little if its wide hips there in the back.
Yea, 'cause that makes all the difference. Surprised its not $75K with an Acura tag on it.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
My Mini FR-S | Supermassive | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 08-23-2012 01:53 PM |
Marin Mini Meet 6/20 | 86_ZN6 | Southern California | 4 | 07-12-2012 02:31 AM |
VS MINI Hardtop S | Alias | FR-S / BRZ vs.... | 34 | 05-30-2012 10:24 PM |
What about that 1.5L Mini FT? | LexusFman | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 04-10-2011 09:54 PM |
