10-10-2012, 12:08 PM | #15 | |
Drives: Scion Fr-s
"CulbyJack" |
10-10-2012, 12:13 PM | #16 |
Drives: really slow...
The Following User Says Thank You to RYU For This Useful Post: | chanomatik (12-16-2013) |
10-10-2012, 12:14 PM | #17 |
Drives: Scion Fr-s
10-10-2012, 12:29 PM | #18 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Wheel clearance issues for big brakes like brembos is nothing new though. Just need the right offset and width
10-10-2012, 12:33 PM | #19 |
Turbo FR-S
So I need 08+ rear brembos to do the rear brakes?
10-10-2012, 12:41 PM | #20 |
Drives: SWP BRZ LTD
No idea, but these are going to be arguably worse performing than stock considering they were designed for a different car.
Thats why david was recommending going with a kit designed for this car. |
10-10-2012, 12:57 PM | #21 | |
Turbo FR-S
I'm going to attempt the rear tonight with the 04s I have and see what happens.
10-10-2012, 01:03 PM | #22 | |
Site Moderator
Drives: Stuff
Depends on your goals. BTW did you switch the bleeders or are the calipers installed wrong? (differential bored calipers...) As for the rears, they will be a lot harder because of the parking brake stuff I'd guess but I haven't done it.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
10-10-2012, 01:04 PM | #23 |
Site Moderator
Drives: Stuff
Where? I never found any cheap ones on ebay so that info will help others for sure!
-Dave
10-10-2012, 01:10 PM | #24 | |
Site Moderator
Drives: Stuff
Haven't done it though so who knows. I'm going with the Essex kit since it gives me a lot more cooling and heat handling up front and keeps the balance.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles Last edited by Dave-ROR; 10-10-2012 at 01:42 PM. |
The Following User Says Thank You to Dave-ROR For This Useful Post: | chanomatik (12-16-2013) |
10-10-2012, 04:49 PM | #25 |
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
If you install the whole front and rear STi Brembos, I would think that if you upgrade the master cylinder that it'd be much better as opposed to stock master cylinder. After all, you've got 12 pistons total to move on the Brembos as opposed to 4 pistons total on the stock calipers. Yes, the pistons are smaller on the Brembos, but still they have a lot more volume overall with the added pistons. I wonder if the STi brake master cylinder bolts on? Has anyone tried?
The Following 2 Users Say Thank You to Mark Slide Squad For This Useful Post: | @Art_Mighty (10-15-2012), gmookher (10-10-2012) |
10-10-2012, 05:45 PM | #26 |
Vtec Jesus
Is there a difference in the calipers from the current STI or the last STI?
10-10-2012, 07:19 PM | #27 | |
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
The BRZ has a massive master cylinder for its size. I have a feeling it may be as big, if not perhaps even bigger than the STI. I wish someone can led me their STI to compare and measure.
ps. I'm in the process of rebuilding a set of Brembos (have front and rear), etc. Quote:
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC 15 WRX Sport - ISM 6spd - Ordered May 3, 2014 |
The Following User Says Thank You to SonnyBRZ For This Useful Post: | chanomatik (12-16-2013) |
10-10-2012, 11:57 PM | #28 |
Drives: 2013 WRB Subaru brz
The front brakes literally bolts right up no questions asked. . . . I did the install personally and all I can say from experience is that this is by far the most painless thing I've ever done. I've taken dumps that were Harder to do then this swap... we haven't had a chance to do the rears yet but if it's anything like the fronts, outs should be a quick swap. We test drove the car after the swap and from a 70-0 under hard breaking the abs kicked in and worked great and we came to a very quick halt.
The only real concern's are these. 1.) clearance due to the size of the brembos. Do boys offset was Damn near perfect in the front and has plenty of room in the back. 2.) switching the calipers to make sure the bleeder screw is pointing up so you can bleed the system. On the sti the calipers are on the back of the rotor while the frs/brz are facing the front. So you have to take the right side brembo off the sti and put it on the left side of your frs/brz. |
The Following 2 Users Say Thank You to yo$hi For This Useful Post: | chanomatik (12-16-2013), Surok (10-31-2012) |
Similar Threads | ||||
will the sti brembos fit fr-s/brz? | driver01 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 04-12-2014 02:25 PM |
Those Brembos, fixed caliper? Or not? [Patent inside!] | madfast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 155 | 12-08-2011 02:06 PM |
