Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-11-2012, 12:07 PM | #15 |
Drives: BRZ DGM
sweet thanks for the info
10-25-2012, 04:26 PM | #16 |
Drives: 2013 Subaru BRZ
I'm currently running the stock struts with RCE yellows, and adjusting camber up front with the OEM crash bolts. I'm running 18x8.5 +44's, and the clearance is real tight. On one side the crash bolt is maxed out, but on the other side, if the bolt slips, I could have a real problem. I'm thinking maybe I should put the fixed bolts back in (to gain a bit more clearance and stability) and adjust camber with a top plate. Are there any good camber plates that will work with the stock struts? Thanks for the help.
10-25-2012, 04:43 PM | #17 | |
Drives: CBS BRZ Limited
10-25-2012, 05:12 PM | #18 |
I got my Vorshlags from Vivid Racing, now im just waiting on my wheels and tires, oh and my control arms. Thanks for all the help VR and especially Sean for dealing with my pestering. This is Gerden btw.
10-25-2012, 05:27 PM | #19 | |
Drives: '13 DGM BRZ Limited
10-26-2012, 04:55 PM | #20 |
Drives: Toyota 86 GT
How about some with camber and caster adjustment? They're made by KMac.
10-26-2012, 05:55 PM | #21 |
I am realizing now that some of these plates will increase ride height in front if used with the stock struts. Are there any out there that won't?
10-29-2012, 06:25 PM | #22 | |
Drives: Ft86
By mounting above the sheetmetal, we are able to let the strut shaft come up through the inner fender, instead of stopping short. In fact, in this picture we had to use a spacer to move the GC camber/caster plate upward, simulating the extra suspension travel, to illustrate the relationship. (note: you may see one or two pics here, as we tweak our FT86 photo file sharing and hotlinking) Last edited by GC86; 10-29-2012 at 07:03 PM. |
The Following 4 Users Say Thank You to GC86 For This Useful Post: |
11-01-2012, 10:47 PM | #23 |
So do these plates actually lower ride height? If so, by how much? Link to more pics/info/price please.
I can't really tell from the pic, but how can these work with the stock struts...where's the top spring perch? |
11-02-2012, 02:01 PM | #24 |
I am running coil-over setup with adjustable camber plates. I know the Vorshlag added a degree of caster which you cannot adjust, how's the car feel ? Did it improve reducing understeer ? How's the tire wear at the fronts ?
Thanks in advance ! |
11-02-2012, 02:23 PM | #25 |
Between this plate and KW3 and the GC setup...leaning towards GC.
school me, I dont know squat about camber plates |
11-02-2012, 03:56 PM | #26 |
Drives: 2013 Whiteout Scion FRS
I am running the ones that came on my Tein Flex.
11-02-2012, 04:43 PM | #27 |
Track Junkie
Drives: Faster than the Stig!
Tire wear is great, im gonna end up running -2.5 in the front though since the wear is getting close to the sidewall. Overall the car feels great with the addition of the camber plates. Vorshlag makes a sweet product.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
11-02-2012, 04:59 PM | #28 | |
Drives: '08 Impreza, 03 SV1000S
Our plates will work with OE struts, but not OE springs. However we are exploring oe spring mounting options. |
Similar Threads | ||||
Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
Camber plates | Captain Snooze | AUSTRALIA | 7 | 07-02-2012 06:51 PM |
Camber arms? | skoodge | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 06-24-2012 10:09 PM |
Excessive negative camber? | MTeator | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-22-2012 10:30 AM |
CUSTOM PLATES OR REGUALR PLATES? | Koomoo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 05-21-2012 09:38 PM |
