#2759 |
I did a track day a couple weeks ago and suddenly after I can hear the supercharger whine, whereas before it was almost silent. I've been running daily for almost 2 years now. Any thoughts?
#2760 |
Drives: Toyota 86 2017 TRD Modded
So found out that most likely symptom for my situation of how I somehow lost power down to 235whp / 195wtq when I have:
- Edelbrock SC (3.00" Pulley) - JDL 4-1 EL Header - JDL 2.5" Overpipe - Stock Front Pipe - TRD CatBack - DW 700cc Port Fuel Injectors - Delicious Tune Is because my cams are inactive when doing pulls. Is this a mechanical problem or can this be fixed with a tune? Cuz I did a couple 0-60 times and these are my results. I'd say that 234whp / 195wtq on an AT, this sounds about right. ![]() ![]() Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
#2761 |
Drives: 2017 BRZ Premium
Out of curiosity, how do your cams know they are on a dyno?
Sent from my SM-N950U using Tapatalk |
#2762 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
It's hard to make an assessment since it can be anywhere from nothing to bearing failure. http://www.thehighspeedlab.com/super...diagnosis.html |
#2763 | |
That being said, your dyno curve does not reflect that of a car without cam phasing. Got a log? |
#2764 | |
#2765 |
Wes
So am I understanding this right.. if I already have ecutek on my car, I need to buy the version of the kit without the tune?
Instagram: @gt86ws
#2766 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
If you're going to a custom tune other than the CARB tune, then you'd buy the kit without the tune. Your current tune wouldn't be the right one to use I'm assuming, so you'll have to get a new one for the Edelbrock - either from them or someone else.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
| The Following User Says Thank You to shiumai For This Useful Post: | StraightOuttaCanadaEh (04-05-2018) |
#2767 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | StraightOuttaCanadaEh (04-06-2018), taiguy (04-06-2018) |
#2768 |
Drives: 2017 Toyota 86
Are there any updates regarding the release of the kit for the 2017+? I remember reading in this thread sometime last year that a kit for the 2017 cars was coming soon.
It's just that I will be in CA in a couple months or so near some of the reputable dealers/installers and I was hoping I could have the kit installed for the warranty...After that I probably won't be near any of the installers in the foreseeable future and I'd probably have to either do it myself or take it to a dealership or ASE tech who probably have less experience with superchargers than the installers. |
#2769 | |
Drives: 2017 BRZ
#2770 |
We are still only being told "soon".
#2771 | |
Drives: 2013 FRS
Also that TRD exhaust will limit your power. It has a 2" section with a neck down to 1 3/4". Designed for a stock engine. I just replaced mine and was surprised how small it gets... Now I have full 2 1/2" all the way out. You will need at least full 2 1/2" to to maximize the supercharger and the extra boost. Spend a little more and finish the exhaust... Send delicious a data log to make sure every thing is cool.
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
#2772 | |
Drives: 2013 Black BRZ Limited
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 11:09 PM |
