Old 11-17-2015, 09:19 PM   #2759
Racecomp Engineering
Originally Posted by baorz View Post
I'm going with option 2, RCE Yellow springs and OEM camber bolts with the same purpose as Agent 86 (DD, no racing, no autocross).
From what I've read, I should opt for ~-1.4 degrees of camber on the fronts. What should the the rear be at?
Thanks!
For the front just asked for it to be maxed out. You probably won't get quite -1.4 camber with the OEM bolts (but you could ask them to aim for that). For the rear, there is no camber adjustment without buying parts.
- Andrew
Old 11-17-2015, 10:01 PM   #2760
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Thanks for the quick response Andrew! Won't there be some natural camber from lowering?
There will be natural negative camber from lowering. I am at -1.4 degrees on the left rear, and -1.8 on the right rear. Car is on factor springs and dampers (not lowered).
LOLS2K is offline   Reply With Quote
Old 11-18-2015, 01:32 PM   #2761
Yes just a little in front and a little more in the rear.
- Andrew
Old 12-03-2015, 01:10 PM   #2762
ChrisSC300
Drives: 2014 SWP BRZ
Alignment question: Taking the car in next week to have my wheels/tires mounted & initial alignment. Current setup: Bilstein B8's, RCE Tarmac Springs, OEM camber bolts up front, 17x9 +35 wheels with 245/40 rubber. Going for max negative camber up front (-1 to -1.2 hopefully), whatever comes naturally with my 20mm drop out back.
What should my request be for toe? Car is my daliy with approx 6 autocross/ 1-2 track days per year. Thanks.
ChrisSC300 is offline   Reply With Quote
Old 12-03-2015, 01:58 PM   #2763
0 toe front, tiny bit of rear toe-in for stability (like 1/16th or 1/8th)
Old 12-03-2015, 02:16 PM   #2764
ChrisSC300
Perfect, Thank you.
Old 12-04-2015, 05:12 PM   #2765
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
Hi, i want to ask if i want to get KW V3 for BRZ, do i must have adjustable top hats? or just camber bolts if fine? i m DD my car for most time and once per month for track, want to get 2-2.5 degree is fine, thanks
ZHoward is offline   Reply With Quote
Old 12-04-2015, 09:22 PM   #2766
brillo
Drives: 2013 Firestorm FR-S
Is bump steer an issue with the RCE yellow springs on an other wise stock suspension ? I wouldn't think so with such a modest drop but I have noticed it from time to time on uneven roads.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 12-04-2015, 10:23 PM   #2767
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
You sure that is not just a consequence of increased camber?
FrX is offline   Reply With Quote
Old 12-04-2015, 11:26 PM   #2768
brillo
Certainly possible, which is why I asked.
Old 12-14-2015, 07:05 PM   #2769
ajh88
I bought some track wheels in 17x9+42 and will get some ~200 treadwear tires for the track in 235/40 or 245/40. I plan to keep stock height, springs, and struts. What suspension bits will I need to get the most out of the wider tires at stock height? Camber plates? LCAs?
Thanks
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 12-15-2015, 01:56 AM   #2770
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Thanks
CSG and RCE probably have better recommendations, but since you're planning on staying at stock suspension (which will be your limiting factor), I think you maybe OK with what you mentioned: camber plates up front and LCAs in the rear. Depending on how much grip your tires will have, you may have to compensate with your alignment settings (stickier=more aggressive?). You can also play with your front/rear balance with anti rollbars, but again, your tire choice would dictate that ie square or staggered setup (I would stay with square )
Old 12-15-2015, 05:13 PM   #2771
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Your 17x9+42 wheels will not clear stock springs. At least mine didn't. I needed to use a 1/4" spacer.
Lunatic is offline   Reply With Quote
Old 12-15-2015, 05:17 PM   #2772
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Depends on the size of the tire.
Originally Posted by humfrz
I'm old and lazy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
