, dpfarr
Old 03-25-2018, 03:17 PM   #2745
JoeS
Drives: 2016 BRZ Hyper.Blue
Originally Posted by taiguy View Post
Nothing in the OBD port. Tried resetting codes with a reader and they immediately show up again. CEL never goes off.
I looked up the codes online. I would check all the connections to the MAF and MAP sensors (part of the same wire bundle). Look for loose wires, possible shorts, etc... If I had to make a bet, it's right there. Make sure to look way up under the supercharger on the driver's side. If all else fails, call Edelbrock. They have been very helpful to me in the past. Or, your installer....
Sent from my XT1650 using Tapatalk
JoeS is offline   Reply With Quote
Old 03-25-2018, 03:56 PM   #2746
taiguy
Drives: 2013 Black BRZ Limited
Just re-connected most of the wiring harness connection points. Didn't seem like there was anything loose. It's been tough to find support since most local shops don't want to touch anything that's non-stock. Then I've got the Delicious box in the mix which replaces one of the wiring harnesses from Edelbrock.
taiguy is offline   Reply With Quote
Old 03-29-2018, 02:18 PM   #2747
taiguy
Shop is saying the extension harness from Edelbrock is no good and needs to be replaced, and/or the throttle body itself. Edelbrock is sending a replacement harness; we'll see what happens.
Old 03-31-2018, 12:50 AM   #2748
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
Hey guys, I recently installed: JDL header, JDL over pipe, 3.00" supercharger pulley, Deatschwerks 700cc fuel injectors, and was tuned by Zach @ Delicious Tuning.
I hooked up my car to my local shops dyno and to my disbelief, I LOST 20hp all across the powerband. My car was fully tuned with no issues and now it says that I'm at 235whp vs the 257whp that I had before the install.
Can anyone explain why there's a loss of power when everything done was proven by many others to increase power?
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 03-31-2018, 01:18 AM   #2749
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
Same dyno? Same weather?
PhyrraM is offline   Reply With Quote
Old 03-31-2018, 01:55 AM   #2750
ThatAsianBradah
Same dyno and same weather.. let me post up the dyno sheets.
1st pic is the dyno from last year. The only performance/engine mode I had was the Edelbrock SC kit tuned by Delicious on 92 octane. Literally everything else was stock.
2nd pic is the dyno from today. Got the JDL EL header, JDL overpipe, 3.00" boost pulley, and DW 700cc FI.
Minimal gains is one thing... But for me to apparently LOSE power compared to stock exhaust no FI and CARB pulley upgrade on a Delicious Tune is SILLY.
I want to say that there was something wrong with the dyno. I absolutely feel faster than before.. but I need verification about what's going on.
Also in the 2nd pic, the blue line is a cross reference to the dyno from last year hence the claimed loss of near 20hp in most areas of the power band.
Old 03-31-2018, 03:14 AM   #2751
That torque graph is a bit funky. Seems something is up with their dyno.
ThatAsianBradah (03-31-2018)
Old 03-31-2018, 03:23 AM   #2752
ThatAsianBradah
Thank you! That was the 1st thing I pointed out. Also the torque from their reference to my original pull from last year in comparison to how it is now shows different numbers.
I'm starting to think my shops dyno needs calibration.
I'm 100% sure Zach made sure to tune the car as much as possible for optimum power:safety which should be much more than what was reported now.
I'm trying a dynojet in a different shop later, but at the very least I know for various reasons I've improved compared to "Stock Edelbrock" power
Old 03-31-2018, 02:51 PM   #2753
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Please keep us updated. My car threw a p2135 about 4 times now over 4-6 months. I had the same issue. Limp mode, stopped car, turned off for 5 minutes and then car started no issue but gauge read p2135. Out of the state but taking it to the shop once I’m back.
Silverfox is offline   Reply With Quote
Old 03-31-2018, 08:23 PM   #2754
Proseph
Drives: Supercharged 2016 CBS BRZ
There seems to be a fuel leak from what I can tell after 1 week of having my kit installed. Today when I turned the car on it was shaky at start. At idle the car trebled and both the traction control and check engine lights were on. One more thing to note is that there was white smoke coming out of the exhaust or somewhere beneath the car. The reason I believe it's a fuel leak is because after the problem arose, I tried diagnosing it 20 minutes later (after having the car shut off) and the car would no longer turn on. This leads me to believe it is no longer able to get sufficient gas to turn on. Any ideas of what this can be other than a possible fuel leak? Could this have been caused by something improperly installed with the Edelbrock kit? Please help.
Proseph is offline   Reply With Quote
Old 03-31-2018, 08:56 PM   #2755
I would recommend taking it to the shop that installed your kit, especially if youre running the edelbrock supplied tune, which is proven.
A fuel leak would smell like fuel.
tracktion + CEL = limp mode.
Proseph (03-31-2018)
Old 03-31-2018, 09:12 PM   #2756
Proseph
Thanks Mike. I’m scheduled to have it towed to the shop Tuesday. Do you know if it’s normal for the car to go into limo mode if a fuel leak is present? Also, do you know if this happens with these kits commonly? I took it to a very reputable shop so not sure what could have happened if this isn’t an issue with the kit itself. The car is like new in the sense that it’s never been modified, 2016 BRZ.
Old 03-31-2018, 09:35 PM   #2757
It depends on the nature of the fuel leak, so I can't say. You'll be in the best hands getting a diagnosis from them, since they did your work.
Did you smell fuel?
Proseph (04-01-2018)
Old 04-02-2018, 04:07 PM   #2758
Proseph
Did you smell fuel?
I did smell fuel
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
