Old 02-14-2017, 12:25 AM   #27371
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Cole View Post
It's like a gun. I'd rather have it and need it, than not have one and not need it.
Hmmmmm.... That's not how the cabinet is designed to operate. They may not look like it but cabinets and internal components are laid out specifically with airflow in mind. You don't want to blow cold air in. Always pull hot air out.
Ultramaroon is offline
Old 02-14-2017, 12:32 AM   #27372
Ultramaroon
not playing cards
Originally Posted by Andrew025
Helps it slide better
I can't quote your unicode emoji.
Oh, and...
Old 02-14-2017, 02:00 AM   #27373
humfrz
Dang, Cole, you sure did butcher that saying .......
humfrz
humfrz is offline
Old 02-14-2017, 02:36 AM   #27374
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
If only that were so. I've tinkered with puters since Commodore had a bright future. Laptops, desktops, workstations, servers, rack blades. I've built many of them from parts. And the component manufacturers' lack of a holistic approach to airflow has bewildered me since the beginning. It looks like the need for heat dissipation comes as a surprise, every time.
In a typical gaming PC the CPU has a fan, the graphics card(s) has a fan (each), the power supply has a fan, and the cabinet needs to provide cold air to all of those in addition to cooling the chipset, the RAM and the drives.
My general advice to gamers wanting to build their own computer:
- Don't go for liquid cooling unless you absolutely have to. It's expensive, hard to get right, and usually unnecessary.
- Get a big tower with lots of empty bays and lots of air ducts.
- Replace puny boxed CPU fan with big heavy duty fan.
- At least 3 cabinet fans, as large as you can fit. Suck in front and side, blow out back and top.
- Invest in a programmable fan controller with at least 2 sensors, one of them for mounting under the CPU heatsink. This will keep the fans running on low RPM with low noise under "normal" operation conditions.
Sarlacc is offline
Old 02-14-2017, 07:16 AM   #27375
Ashikabi
Ashikabi's Avatar
You can get closed loop liquid systems that aren't that costly and many motherboards offer advanced fan controls.
Ashikabi is offline
Old 02-14-2017, 07:51 AM   #27376
Cole
Not a troll
Cole's Avatar
humfrz
You Americans don't get to watch much Trailer Park Boys, huh?
Cole is offline
Old 02-14-2017, 08:16 AM   #27377
Ashikabi
Ashikabi's Avatar
It only recently got popular because of Netflix
Ashikabi is offline
Old 02-14-2017, 08:55 AM   #27378
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I know :-)
I just don't recommend inexperienced builders fiddling with liquid cooling systems. These advices are mostly for them, after all. The advanced guys don't need nor ask for my opinion.
The on-board fan controllers I've worked with have two problems in common:
- They can not control all of the cabinet fans in addition to the CPU fan.
-They rely on control software that hogs CPU and only works with Windows. (I encourage people to try Linux in a dual boot configuration. Having all the fans blasting at full throttle all the time kind of ruins the experience.)
Sarlacc is offline
Old 02-14-2017, 09:02 AM   #27379
Ashikabi
Ashikabi's Avatar
I know :-)
Pretty sure my last Mobo had a controller for case fans. You can get external controllers too. Pretty sure Corsair makes one. It might have a physical knob/switch though. I'd have to look it up
Ashikabi is offline
Old 02-14-2017, 09:14 AM   #27380
Ashikabi
Ashikabi's Avatar
I know :-)
http://www.corsair.com/en-us/corsair-commander-mini
Ashikabi is offline
Old 02-14-2017, 09:33 AM   #27381
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Yeah, that's a programmable fan controller, like I was talking about :-)
Except that one is internal and only compatible with Windows, it seems.
I like the flashy external ones like this:
https://www.newegg.com/Product/Produ...82E16811992005
Sarlacc is offline
Old 02-14-2017, 09:34 AM   #27382
p1l0t
p1l0t's Avatar
I gotta build a new tower it's been YEARS!
p1l0t is offline
Old 02-14-2017, 09:41 AM   #27383
Ashikabi
Ashikabi's Avatar
I've never looked into them. Just saw the Corsair in an email like a year ago. Before that I didn't know they existed. My 1500$ computer isn't nearly beef enough to need something like that though. I have a big ass closed loop cooler for my CPU anyways so most of my heat is getting dumped anyways. I could see it being important for multiple video cards where they are jammed so close together with poor airflow
Ashikabi is offline
Old 02-14-2017, 10:05 AM   #27384
humfrz
Nope ...... never heard of it, but, I looked it up. Looks to be funny .....
humfrz
humfrz is offline
