Old 09-16-2015, 12:41 PM   #2703
jvincent
jvincent's Avatar
The RS-R Sport-i and Tein Mono sport are both in that price range and have had good reviews.
I'm considering both myself for when I add coilovers next spring.
The Following User Says Thank You to jvincent For This Useful Post:
Clipdat (09-16-2015)
Old 09-16-2015, 12:55 PM   #2704
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by LOLS2K View Post
This is definitely something I would like to know. I have personal experience with FA for the S2000 and Evo applications and track use. Is there something different with the FRS/BRZ? Any recommendations for a good damper kit in that price range ($1,500, I'll even stretch it out to $2,000 but not including any suspension arms)? Thanks in advance.
Unfortuanately, I'd have to go do the research again. It may have been they were only rebound adjustable, but it's been a while. That certainly would have taken them off my list.
I also remember reading about some manufacturers that aren't actually building a set of coilovers tuned to the platform - it's just existing parts made to fit physically... I don't recall who was on that list.
Old 09-16-2015, 01:14 PM   #2705
Racecomp Engineering
Wow, that's it?
Thanks I guess?
Well...I'm not one to stand up for CSG Mike (I kid I kid) but I think he was just making a joke. $1500 coilovers are going to be difficult to compare to Ohlins. I wish it were that easy. That said, there are some very good options still in your price range that are quality stuff.
One simple solution would be Bilstein HD shocks. They aren't too expensive and pair nicely with our Yellow springs. Easy way to go if you already like the look and balance of your car...you'll just get better transitions/response and a slightly better ride.
Calum on here just went from our Yellow springs to our Tarmac 0 coilovers which are roughly in your price range. His roads are quite rough, too. You could ask him what he thinks of his new set up.
Either one would make me happy for a daily driver fun BRZ/FRS and I wouldn't miss Ohlins too much. The Ohlins are very good, but still could use a little more travel.
Stretching the budget a little to around $2k would get you some Bilstein PSS10, which are very comfortable coilovers that still perform well. Progressive springs though.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
BigFatFlip (09-16-2015), Calum (09-16-2015), Clipdat (09-16-2015), CSG Mike (09-16-2015)
Old 09-16-2015, 01:16 PM   #2706
I didn't say I wanted Ohlins performance at a $1,500 price, I'm just looking for "somewhat comparable" performance.
Honestly surprised at @CSG Mike's unhelpful reply.
To me, "somewhat comparable" means "similar to" or "almost as good as". There just isn't for $1500.
I apologize if my candid answer is not to your liking; I'm just stating facts.
If the ohlins didn't offer a significant benefit at that higher price point, nobody would purchase, and they wouldn't be in business.
Asking for recommendations at $1500 is different from asking for a $1500 product that performs "somewhat comparably" to a product nearly double the price.
This is coming from a guy who doesn't like the off the shelf Ohlins r&t/dfv.
Based on your original question, my inclination is that you want performance over comfort; I'm not one to make blind recommendations. How exactly are you looking to change the behavior of your car? This will determine my recommendation.
Clipdat (09-16-2015), wparsons (09-17-2015)
Old 09-16-2015, 01:17 PM   #2707
There a LOT of coilovers on that list. Megan/BC did this extensively for Subaru and EVO.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 09-16-2015, 01:20 PM   #2708
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Thanks, been eyeing the Tarmac 0s for a while, just not sure if I need/want adjustable damping.
Originally Posted by humfrz
I'm old and lazy
Old 09-16-2015, 01:28 PM   #2709
Clipdat
Proud of BOXER
Clipdat's Avatar
I generally like the way that the car handles with my only suspension mods being the RCE Yellows and also switching to 17x9 +45 wheels on 245/40 tires.
What I don't like is the fact that I had to run a 3mm spacer in front to fit these without hitting the oem spring perch. I'm hoping that with a coilover I can actually get a performance alignment and get some beneficial negative camber in front. Additionally, even though I want to only keep my drop around 20mm, I will be also picking up the SPC LCAs to adjust rear camber.
Regarding handling & damper performance, I don't like how "unsettled" the car feels over rough road conditions at high speeds or through mid corner bumps. If I only drove my car on the track I'd keep the Yellows with the oem dampers as they're great on perfectly smooth surfaces.
There's a few canyon roads that I drive on that I will bottom out/scrape the front of the car every time because the dampers can't rebound quickly enough to the changing road condition. So that's primarily what I'm looking to address.
And yes, I will take performance over comfort any day.
I'm old and lazy
Old 09-16-2015, 01:49 PM   #2710
OkieSnuffBox
Drives: '23 BRZ Limited
- Andrew
Yep, completely ignores motion ratios, weight distribution, etc. And the kids wonder why that junk gets poo-poo'd.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 09-16-2015, 01:54 PM   #2711
sachu
Drives: rocketship
so, here's a question i have for both
@Racecomp Engineering and @CSG Mike.
I recently ended up buying a used Ground Control fully adjustable coilover system with the following spring rates. It came off the car after about 7000 miles.
Here's the invoice to give you an idea of what the system contains and what sort of car and handling type it was set up for.
My build is basically as shown in the signature.
For the track I plan to use the 720form wheels with RE-71R 245/45-17s
For the street, stock wheels and michelin PSS in 225/45-17s.
I definitely want it to be stiffer for the track but not so stiff that it would be a major pain to daily drive, which I do since she is my daily.
Here are my questions:
I would like to keep the car at stock height if possible but if not, no more than a inch drop. Any issues with running with no drop ?
Would you recommend getting different spring rates? softer from the ones on the kit right now? Or run them as is.
My first track day is this coming Monday and plan to run the stock suspension and collect data around the track, sector times etc and then compare to the ground control suspension on the next track day.
What alignment settings would you recommend also by the way for a compromise setting that would work well on the track and also for DD?
sachu is offline   Reply With Quote
Old 09-16-2015, 02:00 PM   #2712
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I was also considering the zero's when I was shopping around, just decided to bite the bullet and went with the ohlins since I passed on going FI. I believe the zero's are only height adjustable. I also like Andrew's recommendation of getting the Bilstein B8 sport dampers since you already have the springs (also non adjustable).
Either way, since we both practically drive the same roads, I would recommend you get something with single adjustablility. I know its out of your budget, but I was also looking at the Bilstein B16's as an option. Keep in mind, for bumpy roads like Redwood & Pinehurst, we are mostly looking for good bump travel, which is one drawback I found with the Ohlins.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 09-16-2015, 02:00 PM   #2713
Yes you're at the point that you do need better dampers, especially with the wider wheels and tires and should probably skip the Bilstein HD shocks. I would look into the coilovers I mentioned. Also feel free to PM or call on the phone if you have any questions.
- Andrew
Old 09-16-2015, 03:09 PM   #2714
OkieSnuffBox
What I'm getting from that is you're running 475/500 f/r?
If I remember my Eibach stuff right, 0600.250.500 is a 6" long spring, 2.5" diameter, 500lbs per inch
Old 09-16-2015, 04:32 PM   #2715
sachu
Drives: rocketship
it is 500 front and a 475 rear. heavier spring to account for the added weight of the supercharger I was told.
Will I be able to keep stock height with this spring setup or close to it?
I was told it is 64$ for each new spring if I wanted different spring rates.
Old 09-16-2015, 05:04 PM   #2716
DerHauptDigga
DerHauptDigga's Avatar
Drives: 2016 FRS
I am looking for a good coilover setup around 2k or under.
I daily my FRS, and have a 100 mile round trip commute for work everyday.
Am I a damn fool for even thinking about buying coilovers?
Or is there a well balanced comfort/performance based coilover someone could recommend to me?
Thanks guys, really appreciate it.
DerHauptDigga is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
