Old 08-02-2015, 04:43 PM   #2689
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Originally Posted by themajesticone View Post
Anyone feel like donating me a JRSC kit? PM Me for serious offers.
Wait is that a thing we can do? Hey if anyone needs some more money towards their charitable donations...
Old 08-03-2015, 03:33 PM   #2690
Originally Posted by dkstylezz View Post
I understand that could be the first question to ask. Although I don't understand how i could have done it wrong. Followed directions carefully. Made sure to unscrew the IN banjo bolt a little to let air and oil seep out. Blew air through the reservoir until i saw blue oil leaking out the banjo and tightened it to torque spec. Made sure the oil levels NEVER dropped low and checked the oil levels after letting the car idle to make sure of proper oil circulation. I also did check inside the reservoir to see if there is actually oil flowing and it was flowing.
Due to the fact of understanding the importance of the priming stage during installation, I kept myself paranoid checking oil levels and checking for leaks every opportunity i had. Even after the installation i managed to check the system before/after drives and during gas fill-ups.
Just went out side to double check the lines to see if there were any kinks or awkward bends that could cause restriction and couldn't find any. The oil was flowing well through the reservoir.
PM me your rotrex serial number.
-Mike
bumppinKota (08-03-2015), dkstylezz (08-03-2015)
Old 08-03-2015, 03:34 PM   #2691
bumppinKota
Drives: FRS!!!
That's great service there
bumppinKota is offline   Reply With Quote
Old 08-03-2015, 04:29 PM   #2692
CSG does their best to support all enthusiasts
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
bumppinKota (08-03-2015), funwheeldrive (08-08-2015), Phantobe (08-04-2015), superleggera (08-03-2015)
Old 08-05-2015, 12:20 AM   #2693
BRZ'13
BRZ'13's Avatar
Drives: subaru
Need thoughts on this. Got my jrsc tuned today and it made 256hp/190tq on 94 with 9psi. Baseline was 150hp
Mods are: pt tuning catless header, jrsc kit, jr oil cooler, nameless downpipe/overpipe with cat.
Same tuner did 295/235 with kraftwerks kit on 12psi. Very similar mods except this car has catback as well.
Are my numbers a little low? I know its over 100whp gain but for some reason they seem a little low to me. Dont see myself getting an extra 40whp with 3psi
BRZ'13 is offline   Reply With Quote
Old 08-05-2015, 12:58 AM   #2694
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
12psi FI kits usually see around 300hp so those numbers seem reasonable for the KW kit. I agree with you that 256hp seems a little low for this kit + headers though. Maybe your tuner was afraid to push the stock fuel pump/injectors? The 300hp mark is around the point where you'd upgrade those.
Also, 295 is really on the top-end for a rotrex SC kit. I'm guessing that was a pretty aggressive tune on the KW car.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
The Following User Says Thank You to campy For This Useful Post:
BRZ'13 (08-05-2015)
Old 08-05-2015, 01:27 AM   #2695
SPCorBUST
SPCorBUST's Avatar
40hp with 3psi seems within normal to me, and I say that because it's roughly the same difference between the KW C30's pushing 12psi and the C38's pushing 15psi with the stock, non-high-boost pulleys.
Actually, I'd say that those KW numbers seem higher than the vast majority of owners self-report, so if anything, your 9psi when compared to a "normal" KW owner's kit at 12psi pushing 260-275whp is actually quite good...
(caveat emptor due to dyno differences)
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
BRZ'13 (08-05-2015)
Old 08-05-2015, 01:39 AM   #2696
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The rotrex is spun higher on the KW setup as well, no?
Old 08-05-2015, 01:47 AM   #2697
SPCorBUST
SPCorBUST's Avatar
Can't say for certain, but I believe so - I think it has to be spun higher to produce higher psi. I actually tried digging up the numbers these kits spin at for a few minutes the other day, but couldn't find them anywhere. Either my forum-fu or my Google-fu was failing me at the time, so I moved on to drooling in the wheel thread.
CSG Mike (08-05-2015)
Old 08-06-2015, 12:57 PM   #2698
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Can anyone recommend a Los Angeles area shop that can install the JR supercharger?
Avo1789 is offline   Reply With Quote
Old 08-06-2015, 01:04 PM   #2699
LucidMomentum
Counter Space Garage, or so I've heard.
Old 08-06-2015, 01:46 PM   #2700
I would think we're a strong candidate
Porcupint (08-06-2015)
Old 08-06-2015, 01:57 PM   #2701
Avo1789
Avo1789's Avatar
Pmed!
Old 08-06-2015, 05:15 PM   #2702
Porcupint
Drives: 13 GBS BRZ
Would certainly be my first choice if I was anywhere nearby and couldn't DIY based off of what I've seen and heard.
Porcupint is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
