Old 05-23-2018, 04:47 AM   #2689
MINI_Bkk
Drives: Evo X. Mini R56
Originally Posted by Sergeb96 View Post
J1210CA301- Front Red/Cherry Stripe tS Molding
J1210CA401- Rear Red/Cherry Stripe tS Molding
thank you very much
so the dealership is still selling these items then.
I went to the dealership a week ago, and they were available. The cost for these pieces is insanely high.
Front Bumper Mouldings - $380 Canadian
Rear Bumper Stripe - $96 (it is literally a strip of vinyl)
I was really tempted to get the front moulding, but for $400, that’s crazy expensive.
totally agree with you. they are crazy expensive.
I am living in Thailand so there is an extra international shipping cost for me.
these items cannot be purchased anywhere else so there really is no other choice for me.
MINI_Bkk is offline   Reply With Quote
Old 05-28-2018, 06:22 PM   #2690
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I just looked at my spare STI sports clutch and clutch cover today and the engraving has both STI and Exedy logos on the metal.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
nikitopo (05-29-2018)
Old 05-30-2018, 02:45 AM   #2691
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
I heard people were curious how the USDM tS uses the flexible draw stiffeners. Hope these pictures help.
Elliotw is offline   Reply With Quote
The Following 6 Users Say Thank You to Elliotw For This Useful Post:
Jordan Silveira (05-30-2018), krayzie (05-30-2018), norcalpb (05-31-2018), tehShirt (05-30-2018), weederr33 (06-01-2018), yurikaze (05-30-2018)
Old 05-30-2018, 04:11 AM   #2692
johan
Drives: '14 981CS, '99 NB1
Thanks so much for this!
It looks like the part I ordered is the right part for a tS. The problem is, the subframe is different on the non-tS car!!! None of those four bolt locations have corresponding holes to bolt to on a non-tS subframe.
So either USDM folks have to swap subframes or just buy the JDM ones. At this point, the JDM ones are way cheaper than doing a subframe swap.
It'd also be interesting to get someone with a 2018 non-tS to check their subframe to see if it has all the holes in place to install the tS stiffener. But I can confirm that 13-17 subframes do not have them.
johan is offline   Reply With Quote
Old 05-30-2018, 04:22 AM   #2693
Elliotw
Elliotw's Avatar
interesting that Subaru went this way. You think for cost savings they share as many parts as possible between the two tS(usdm & JDM). Maybe it didn't matter. I assume the tS is a high margin car for Subaru.
Old 05-30-2018, 04:32 AM   #2694
krayzie
Drive From Home
krayzie's Avatar
Is it me or those new draw stiffeners look shorter than my old set.
Also when I bought my set from Japanparts, it came with a bracket and longer screws for the subframe, and the other end have wing bracket pieces. See how the rods have to be oriented like the pic above as written on the JDM instructions, not symmetrical like on the US BRZ tS car. The rods themselves are also polished stainless steel (not sure if the rod finish is the same on the new car, doesn't look that way on the pics).
Old 05-30-2018, 04:36 AM   #2695
johan
Originally Posted by krayzie View Post
Is it me or those draw stiffeners look a lot shorter than my old set.
Also when I bought my set from Japanparts, it came with a bracket and longer screws for the subframe, and the other end have wing bracket pieces. See how the rods have to be oriented like the pic above, not symmetrical like on the US BRZ tS car.
They are way shorter. Like I said, I had a set of the new ones in my hands. It didn't line up with anything on my '17's subframe. The JDM ones look like they would bolt right up to my car.
Old 05-30-2018, 04:39 AM   #2696
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Also when I bought my set from Japanparts, it came with a bracket and longer screws for the subframe, and the other end have wing bracket pieces. See how the rods have to be oriented like the pic above as written on the JDM instructions, not symmetrical like on the US BRZ tS car. The rods themselves are also polished stainless steel (not sure if the polish is the same on the new car).
Yes, the draw stiffeners in the US tS car seem to be totally different.
Old 05-30-2018, 04:49 AM   #2697
krayzie
Drive From Home
krayzie's Avatar
I would go with the JDM ones if you drive in winter salted roads (not sure if you guys get snow out west like we do in the east). Mine have no rusts on them after almost 5 years. I'm sure the transmission cover underneath helps a lot.
But at this point it seems like you can't even bolt on the US ones.
Old 05-30-2018, 05:04 AM   #2698
krayzie
Drive From Home
krayzie's Avatar
Looks like they needed to simplify the assembly as well in order to have it integrated into the factory production line. The JDM tS cars are all upgraded at STI for two weeks from the standard car after coming off the line.
It seems like they also have to keep the cost in line to even bring it over to North America and use more cost effective parts compare to the 2015 JDM BRZ tS while maintaining similar performance. This keeps the MSRP at an attractive level which is great for us.
I've read from someone in Japan here at the forum that Subaru couldn't even get fill 300 orders (lack of demand) for the first BRZ tS back in 2013.
Old 06-01-2018, 12:01 AM   #2699
norcalpb
norcalpb's Avatar
Thanks for that info!
So looks like that new crossmember is maybe: 20101CA010
$215
https://www.subarupartsdeal.com/part...0101ca010.html
Considering the 13-18 show 20101CA000, this must prove that the tS does indeed get its own unique crossmember!
I’ll probably end up buying this crossmember as I stripped one of the holes in the oem one.
Old 06-01-2018, 12:15 AM   #2700
norcalpb
norcalpb's Avatar
Also Japanparts is showing me $537 shipped for the JDM DS
A Subaru warehouse is showing me $696 shipped for the USDM DS and crossmember.
So $160 overall to go USDM, probably worth it to some people. Less length in the bar means less flexing in itself.
Old 06-03-2018, 12:28 PM   #2701
krayzie
Drive From Home
krayzie's Avatar
I start to think it was done to pass safety in the US.
nikitopo (06-03-2018)
Old 06-09-2018, 02:44 AM   #2702
yurikaze
yurikaze's Avatar
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
Originally Posted by yurikaze View Post
The 18” STI Enkeis on my tS have “made in Japan” cast on the back of one of the spokes.
https://imgur.com/a/H8NXdNY
Sorry for the link instead of an embedded image, but imgur doesn’t play nice with my phone. The Enkei STI Wheels on the tS are still made in Japan.
yurikaze is offline   Reply With Quote
The Following User Says Thank You to yurikaze For This Useful Post:
krayzie (06-09-2018)
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 06:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 11:30 AM
