, dpfarr
Old 02-21-2018, 03:31 AM   #2675
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
Nevermind, I found it haha! Got it off of 86speeds website.
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 02-21-2018, 03:36 AM   #2676
Originally Posted by ThatAsianBradah View Post
Do you have the part # on hand for the 3.00" pulley and other related parts necessary?
I've checked out the Edelbrock website and Summit Racing website but no solid on the 3.00 pulley that's the specific fit for the frs/brz/86 model
Their pulleys are universal; in stock and ready to ship.
Don't need anything else to run the pulley alone, except perhaps an updated tune. You'll get a little more power.
ThatAsianBradah (02-21-2018)
Old 02-21-2018, 03:47 AM   #2677
ThatAsianBradah
Gotcha. Saw that the P#15822 is the one. Also noted on the Delicious Tuning Website that bigger injectors are "required"... For e85 definitely, but 12psi on 92 octane with the setup I'll be working with still seems to be on the conservative side of things.
I'll keep posted on how it ends up come mid-March when I finally get this stuff all sorted out.
Old 02-21-2018, 12:48 PM   #2678
B T
So, just to reiterate, the 3.00" pulley is good on stock engine? The first I've heard of that. I track and daily my car but would be interested in this upgrade. Stock injectors can handle this? I haven't done the calculation.
B T is offline   Reply With Quote
Old 02-21-2018, 03:29 PM   #2679
With a good tune and good gas, you'll be okay, but getting diminishing returns.
I personally wouldn't do it unless there were no other options for more power.
You'd get better returns leaving the boost alone and finding other ways to increase efficiency, such as an Ace header, front pipe, dbox, and tune.
Old 02-21-2018, 03:34 PM   #2680
ThatAsianBradah
That's good to know I'd be daring to say that with better exhaust scavenging, running 92/93 octane and properly tuned with the 12psi pulley wouldn't be an issue at all if not tracking or autox-ing, which is exactly what I'm going for - whenever I want to pound the supercharger past 300whp / ~240wtq I'll be able to do so without any worries at all assuming stock motor and stock injectors/pump.
The Following User Says Thank You to ThatAsianBradah For This Useful Post:
CSG Mike (02-21-2018)
Old 02-21-2018, 05:33 PM   #2681
Another option is to get two maps on your tune; a second race gas map designed for say... 97 octane, would get you north of that 300whp mark.
I say 97, because if you have your gas light on with 92/93, and fill up on 100, you won't quite be at 100, and 97 gives you a good amount of leeway.
LMK when you're ready and I can make this all happen for you.
ThatAsianBradah (02-22-2018)
Old 02-22-2018, 10:53 AM   #2682
B T
I've already done all those things :-)
The Following User Says Thank You to B T For This Useful Post:
CSG Mike (02-22-2018)
Old 02-22-2018, 06:27 PM   #2683
Ethanol available to you?
Old 02-22-2018, 06:36 PM   #2684
ThatAsianBradah
That's definitely something I'm thinking about.. I'm just being so conservative right now with doing the bolt ons and 12psi pulley as with quality tuning and the right support mods I'll be reaching the power level I need without having to resort to higher threshold fuels.
I ordered the Deatschwerks 700cc injectors so I'd have more reliability running the 12psi pulley too.
Old 02-23-2018, 03:39 PM   #2685
B T
Unfortunately there's no ethanol available in southern Alabama yet. We're always the last in line for new things in the US, haha.
Old 02-23-2018, 03:41 PM   #2686
B T
Has anyone tried a nitrous cooling plate on the heat exchanger? I'm not sure if it would be worth it or not, but I've got this DynoTune nitrous kit just sitting around.
Old 02-23-2018, 04:27 PM   #2687
To cool it below ambient? It can work, but you'd be better off with a water spray.
Old 02-23-2018, 06:13 PM   #2688
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
That's what my hood vents do when it rains
shiumai is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
