Old 02-14-2011, 01:22 PM   #253
Terrari
non member
Drives: none
Originally Posted by cyde01 View Post
i don't know how safety features add this much weight either but the numbers don't lie, it's an industry wide trend.
In 1985, the US spec MR2 weighed 2350 lbs, and the Euro spec weighed 2232 lb. All the difference was in safety features such as door beams, heavier bumpers behind the cosmetic bumpers, etc. The US front bumper bar weighed in excess of 50 lbs alone.
Terrari is offline   Reply With Quote
Old 02-14-2011, 03:33 PM   #254
Aki
Drives: '96 beater Corolla
Originally Posted by Snaps View Post
I don't think it's just the safety features that are adding the weight, extra versatility (read: extra boot space, extra leg/head room), along with better/beefier sounds systems, heavier, more comfortable, electrically adjustable seats, etc. all add extra weight. I think the FT could easily pull off it's 2700-2800lb target weight if some of these amenities were reduced or removed. All the extra electronics compared to the early 90's add a heap more weight.
No, amenities are not the main thing that drive up weight. $20k cars don't have electric seats. Beefier sound system doesn't add much weight unless there's a giant amp (and $20k cars don't have those). FR-S's boot space is tiny, and Japanese cars haven't gotten much better in head space over the years.
The main factor driving up weight is safety. Airbags are increasingly standard on seats, that adds maybe 20-30lbs per seat. Side impact crash standards become increasingly stringent. Compare a 90s Civic A-pillar to the new Civic and you'll notice a huge difference in thickness. Ditto for the B-pillar. More reinforcement in the doors. Side curtain airbags. You compare a new car's crash worthiness to something from 20 years back, there's a significant difference. All that adds up.
Aki is offline   Reply With Quote
Old 02-14-2011, 04:20 PM   #255
djohnson
Drives: 1996 RAV4
The 90's civic 4 dr sedan was indeed around 600 lbs lighter than the Si 4 dr sedan is today. I'm not sure about the weight of the newer features, perhaps someone with experience can chime in. 2 Big features that I would think alter the weight greatly are - '95 Civic has 4 sp auto or 5 sp manual, no LSD. '11 Si Civic has 6 sp manual close-ratio trans and Helical LSD standard. Does anyone here know the weight of a LSD and/or difference between 5speed and 6 speed manual trans? I am also guessing that newer transmissions are also built heavier as today's engines typically have more power and torque than those from 10-20 years ago.
djohnson is offline   Reply With Quote
Old 02-14-2011, 04:35 PM   #256
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
i highly doubt that a 6 speed tranny or lsd would add significant weight compared to a 5 speed with standard diff... like aki said it's the huge a and b pillars, chassis reinforcement, additional airbags.
cyde01 is offline   Reply With Quote
Old 02-14-2011, 05:11 PM   #257
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
But really, who are we kidding...
Safety at 120mph doesn't exist, except in driver skill.
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 02-14-2011, 06:20 PM   #258
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That's why it's call Japanese cars...
Old 02-14-2011, 07:03 PM   #259
Matador
hashiryu
Drives: Mk4 Supra
Transmissions and engines are lighter today than ever, the extra weight is not from there.
Matador is offline   Reply With Quote
Old 02-15-2011, 08:20 AM   #260
DantKR
Drives: Subaru BRZ LT
Most cars are much bigger than their early 90's version. I know my 98 2 door accord felt like 2x the size of my 92 2 door accord.
DantKR is offline   Reply With Quote
Old 02-15-2011, 09:37 AM   #261
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
sometimes. three people can easily lift my 3SGTE, add a fourth when it's bolted to the transmission. five of us absolutely could NOT lift a K24 out of a 2009 accord bolted to it's transmission. we could get lift it about an inch off the ground, and that was all.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 02-15-2011, 09:55 AM   #262
Matador
hashiryu
Drives: Mk4 Supra
That is engine and transmission. Try the same with your 3S bolted to an Auto tranny, and see if the result isn't the same.
Either way, Hondas suck . A Toyota UZ V8 is in the same weight range as a 3S.
Old 02-15-2011, 10:49 PM   #263
Chokonen888
Drives: Seibu Shinjuku Line
Yep, auto tranny vs. manual is no comparison.
Chokonen888 is offline   Reply With Quote
Old 02-15-2011, 11:20 PM   #264
NESW20
2.1L 3SGTE
trust me guys, that engine is no joke by itself. it weighs at least as much as my 3SGTE, and the K24 has an aluminum block.
2008 Civic Si Sedan
Old 02-16-2011, 12:06 AM   #265
Dimman
Kuruma Otaku
Dimman's Avatar
K24's longer stroke = more crank material, and cranks are heavy. Plus a bit more block material for the extra height.
Plus there's probably a lot more stuff in the head too for all the VTEC stuff.
I believe it.
Because titanium.
Old 02-16-2011, 03:06 AM   #266
Aki
The difference in the Civic's weight over the years is not mainly due to the engine. A K20 adds maybe 100lbs over a D-series engine. K24 adds 20-ish lbs on top of that. A 3SGTE weighs about 100 lbs less than a K24 w/o tranny.
Swap a K20+six-speed into an older Civic, and it's still a good 300-400 lbs lighter than the new Civics. Side impact door beams, reinforced steel crossmembers are what do it, among lots of other safety additions.
ft-86 concept, ft-86 ii concept, toyota ft-86 ii
Nissan: Juke Unveiled at Geneva vh_supra26 Other Vehicles & General Automotive Discussions 87 12-02-2016 08:51 AM
FT-86 Concept to be unveiled at Toyota Metapolis on 10/23 ahead of Tokyo Motor Show! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 8 12-15-2011 11:19 PM
Citroen SURVOLT Concept Wows Geneva vh_supra26 Other Vehicles & General Automotive Discussions 6 03-06-2010 12:07 AM
Geneva 2010: Peugeot SR1 Concept excites our inner Francophile vh_supra26 Other Vehicles & General Automotive Discussions 1 03-03-2010 12:05 AM
