01-22-2016, 05:37 PM | #253 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Alright, I have a couple questions. I'm interested in the Stage I or II fronts with the STI rotors and the Sport Performance rears:
1) Do the Sport Performance rear calipers have the Yellow option that the other calipers have? And 2) How well are these kits working in conjunction with the Traction/Stability control and ABS systems for daily driving and in non-dry conditions? |
01-23-2016, 08:37 AM | #254 | |
Drives: Toyota GT86
Yes, we can do yellow calipers for the Sport Performance kits... not a problem. We can absolutely assure you full compatibility with OEM stability/ABS systems in the dry or the wet. One of the motivations for the SP kits was to offer 86 owners a reasonably priced BUT fully ABS compatable alternative to the popular STi caliper retrofit -- which we know does not work well on 86 cars due to the change in bias. Rafi |
01-25-2016, 09:39 AM | #255 |
Drives: GT86-ACE-JRZ-RPF1-Essex
Does someone know if the stage 4 fits inside ? :
TE37SL 17*8,5 +45 CE28N 17*9 +40 Thanks.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
01-25-2016, 01:13 PM | #256 |
Drives: 2014 Ultramarine FR-S
Has anyone installed any of these kits themselves? what does the install procedure look like? Are there any instructions or anything like that included?
please post pictures of the install in progress if anyone has them. Thanks!! |
01-25-2016, 02:39 PM | #257 |
Just drive it
Drives: 13' FR-S
Install procedure is pretty much the same as replacing a caliper. 17mm to remove OEM caliper, remove brake lines, reinstall with new bolt. There is really good DIY on how to change brake pad/rotor in DIY section. Bleeding is a bit different since there are 2 valves on each caliper. Bleed from outside, then inside.
01-25-2016, 11:59 PM | #259 |
Drives: FRS
Nope don't need cutting. Make sure you have a flare wrench!
The Following User Says Thank You to double0seven For This Useful Post: | ハチロク (01-26-2016) |
01-27-2016, 12:46 AM | #260 |
01-27-2016, 06:40 AM | #262 |
Thanks, that's what I thought. Especially the te37sl.
01-27-2016, 10:14 AM | #263 |
Just drive it
Drives: 13' FR-S
Let me correct this a bit. There's 4 bleeders on each caliper (at least for mine) but you'll only be using the top 2. Then bleed from outside, then inside.
[ame="https://www.youtube.com/watch?v=RD017fGqmJs"]Wilwood Brakes - Brake Bleed - YouTube[/ame] |
01-27-2016, 01:45 PM | #264 | |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
01-28-2016, 06:26 AM | #265 | |
Drives: Toyota GT86
I do inside first, then outside, but I also alternate a few times, and I tap the calipers with a plastic mallet to make sure all the bubbles rise to the top. You never bleed the lower bleed screws. Rafi |
02-01-2016, 01:03 PM | #266 |
Drives: 2014 BRZ Limited
@Alan,
I'm also located in DE and wanting to jump up to the RR-Racing setup this year. Would be awesome to meet up with you and pick you brain on it! -Carlos |
Tags |
big brake kit, competition, track |
Similar Threads | ||||
AP Racing brake systems in development | track_warrior | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 872 | 09-17-2017 07:43 PM |
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 05:53 PM |
AP Racing Factory Big Brake Kit, NOT Competition | Lonergt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-25-2013 04:51 PM |
Official street racing thread. All street racing goes here! | bkblitzed | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 07-19-2013 11:31 AM |
Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 01:32 PM |
