Old 06-19-2013, 02:22 AM   #253
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
AEM Wideband Failsafe (AFR/Boost)
I already alluded to my desire to add a gauge. I as all on the boost gauge bandwagon but @Chris@Phastek and @Do Boy convinced me to install a wideband AFR sensor.
I also did not want gauges on my steering column and A-Pillar. I am a big fan of using the ATI vent pod mount because it keeps everything discrete from wandering eyes.
I still did want to have boost so I had to look for combo gauges. I decided to buy like one out of the two combo AFR/Boost gauges on the market: AEM Wideband Failsafe
With this lack of choice, I did feel good that AEM is a reputable company, it was a mechanical boost gauge (i prefer this), comes with the bosch Wideband UEGO sensor, and has a datalogger. Even has a failsafe signal that can kill the engine in case your car leans out..
My only concerns were how to wire this to the car. Being a universal gauge we are on our own. A good thread below inspired confidence in me.
http://www.ft86club.com/forums/showp...5&postcount=77
I didn't have too much time to install and take pictures of everything. Here are some quick thoughts and photos I did take.
Quick feedback:
+ The ATI vent pod is a 60mm pod. This gauge is 52mm in size which I believe is common. Lucky for me ATI makes a 60 to 52mm pod adapter!
+ I didn't connect the dimmer wire. The gauge is easily read in all conditions so I don't plan to connect the wires.
+ the screen is OLED and has a fast refresh rate.
+ I ended up drilling three holes in my AC vent to run all the wiring to the gauge (I don't have a picture of this yet)
+ The 7/64" ID vacuum hose supplied is too short to run to the engine bay. I had to buy hose from O'Reilly's auto parts.
+ the data logging feature does work without the RPM signal wire connected to the car. I'm going to connect it later.
+ You can configure the gauge using only USB power. No need to hook the gauge to the car's power, or turn on the ignition to use the USB configuration function.
+ you can show boost in several units of meaures, show AFR, lamda, etc. Pretty much whatever to your choosing. THey provide face plates for the different modes.
+ Data output is very quick. Torque was mostly consistent with the gauge except it was slightly slower even though I had the Scantool OBDLink MX. One glaring difference was that the reading is different when the car cuts fuel because the drivetrain is spinning the crank under momentun. Torque read 14.7 AFR and this read 18. I think the UEGO sensor wins here.
+ Air can still go out around the pod. You cannot freely rotate the pod like you could the OEM vents. You cannot aim the airflow out this vent anymore nor close the airflow. It is more noisier when you have the fan on 2 or higher.
I hope you guys like pictures. Let's have at it
Here is the entire AEM kit laid out. I don't show the ATI vent pod or the adapter. Comes with everything you need. I'll go through stuff in more detail.
20130615-AEMWidebandGaugePics-017 by VictorN07, on Flickr
Danbo showing off the gauge. The gauge has a center display and a digital meter along its perimeter.
20130615-AEMWidebandGaugePics-013 by VictorN07, on Flickr
The Bosch Wideband LSU4.2 UEGO sensor
20130615-AEMWidebandGaugePics-015 by VictorN07, on Flickr
The UEGO sensor harness, USB extension cord, and gauge harness
20130615-AEMWidebandGaugePics-022 by VictorN07, on Flickr
O2 Sensor bung. I did not use this as one was provided by my welder in my previous post
20130615-AEMWidebandGaugePics-027 by VictorN07, on Flickr
This is the gauge harness separated and wrapped in loom. I split out the
harness into three sections
+USB,
+Ignition power and ground,
+Sensor wires (pretty much the rest
I got all of that through one grommet
20130615-AEMWidebandGaugePics-038 by VictorN07, on Flickr
20130615-AEMWidebandGaugePics-037 by VictorN07, on Flickr
You can see me start to drill holes in the AC duct work. I ended up drilling three holes.
+ For the harness above
+ The UEGO Harness
+ and the vacuum hose
20130615-AEMWidebandGaugePics-040 by VictorN07, on Flickr
For the boost portion I had to tap into a vacuum source. The brake booster line was perfect. I already tapped into it once, and didn't want to do it again....so I decided to copy what @Do Boy did and install a vacuum manifold into my engine bay. I can drive many vacuum accessories off of this block, but I am only using it to drive the boost gauge and Vortech Bypass valve.
20130616-AEMWidebandGaugePics-057 by VictorN07, on Flickr
The finished engine bay
20130616-AEMWidebandGaugePics-068 by VictorN07, on Flickr
I have some plans for a diagonal brace and strut tower bar. Since I knew I was changing them out I temporary mounted my vacuum manifold on top of an extra set of the vibration dampeners from the u-bolts i had for the catch cans. (see previous post).
The side of the manifold is my input from the brake booster line.
20130616-AEMWidebandGaugePics-073 by VictorN07, on Flickr
To the bottom right of the catch can you can see the plug for the UEGO sensor. It's zipped tied there for easy access. This is another clear view of the vibration dampened U bolts used on the catch can.
20130616-AEMWidebandGaugePics-077 by VictorN07, on Flickr
A clear shot from above of the UEGO sensor in the newly welded bung
20130616-AEMWidebandGaugePics-081 by VictorN07, on Flickr
Finished! You can clearly see the ATI 60mm vend pod, and the 60 to 52mm adapter (rubber ring). I did have to cut the gauge plastic securing brace down so it would fit properly to the 60 to 52mm adapter.
20130616-AEMWidebandFailsafeFinished-007 by VictorN07, on Flickr
20130616-AEMWidebandFailsafeFinished-019 by VictorN07, on Flickr
20130615-AEMWidebandGaugePics-055 by VictorN07, on Flickr
I'll take some more clear pictures of how i wired up the RPM sensor and what the fully drilled out AC ducting looks like soon.
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
JEFFSTYLE (11-24-2017)
Old 06-19-2013, 12:22 PM   #254
Do Boy
Turbo FR-S
Do Boy's Avatar
Send a message via ICQ to Do Boy Send a message via AIM to Do Boy Send a message via MSN to Do Boy Send a message via Yahoo to Do Boy
Looks great!
Do Boy is offline   Reply With Quote
The Following User Says Thank You to Do Boy For This Useful Post:
F1point4 (06-19-2013)
Old 06-20-2013, 04:01 PM   #255
xskydivingdudex
Drives: lifted 4runner on 35s
Wow, great work on all the installs and love the pics with Danbo...
xskydivingdudex is offline   Reply With Quote
The Following User Says Thank You to xskydivingdudex For This Useful Post:
F1point4 (06-20-2013)
Old 06-21-2013, 12:43 PM   #256
F1point4
Photo Specialist
F1point4's Avatar
Driveshaft Shop (DSS) Carbon Fibre Driveshaft DIY!
http://www.ft86club.com/forums/showthread.php?p=1016103
20130615-DriveshaftShop86-001 by VictorN07, on Flickr
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
JDKane527 (06-22-2013), swift996 (06-21-2013)
Old 06-23-2013, 12:58 AM   #257
F1point4
Photo Specialist
F1point4's Avatar
Working On The Cars
Caught @Chris@Phastek working on his car this morning. I was doing some fun stuff to mine. More to come.
He was replacing his fogs with the Outback fogs. He also put in an HID kit but I forgot the details. Maybe he will answer
20130622-ChrisFogs-001 by VictorN07, on Flickr
20130622-ChrisFogs-005 by VictorN07, on Flickr
Old 06-23-2013, 01:43 AM   #258
F1point4
Photo Specialist
F1point4's Avatar
More Carbon Fibre (Driveshaft)
Got @Chris@Phastek's car back on the lift to take some more pictures upon the community's request. Enjoy
http://www.ft86club.com/forums/showp...0&postcount=13
20130622-DSS-CFDriveshaft-After-046 by VictorN07, on Flickr
Old 06-23-2013, 07:51 AM   #259
Juvenile
Juvenile's Avatar
Drives: 86 GTS
Firstly, lovin your build thread,well done, secondly, you have a friend in Japan
The Following User Says Thank You to Juvenile For This Useful Post:
F1point4 (06-23-2013)
Old 06-24-2013, 01:14 AM   #260
F1point4
Photo Specialist
F1point4's Avatar
Password JDM Ultimate Strut Tower Brace Review
http://www.ft86club.com/forums/showthread.php?p=1020750
20130621-PasswordJDMUltimateStrutTowerBracePackage-001 by VictorN07, on Flickr
20130621-PasswordJDMUltimateStrutTowerBracePackage-007 by VictorN07, on Flickr
20130623-PasswordJDMUltimateStrutTowerBracePackage-026 by VictorN07, on Flickr
SkAsphalt (06-24-2013)
Old 06-24-2013, 02:05 AM   #261
F1point4
Photo Specialist
F1point4's Avatar
Inspection!
Went through the car to fix some random things that were bugging me and inspect prior to the track day next weekend.
Sometimes I do this in my parking garage. I get weird looks sometimes but I know working on the car makes them ladies blush. hahaha
20130623-JuneInspection-004 by VictorN07, on Flickr
20130623-JuneInspection-006 by VictorN07, on Flickr
Well Shit. At least it wasn't leaking. Going to have to go get it plugged.
20130623-JuneInspection-010 by VictorN07, on Flickr
I have no idea what this fluid is. Thought it was coolant but I am pretty sure all the panels prevent that from coming down here. Its too far forward I think for it to be a leaky damper. I didn't see any buildup of fluid around the brake line connections so I don't know. Car still drives fine
20130623-JuneInspection-012 by VictorN07, on Flickr
Old 06-24-2013, 12:58 PM   #262
DarkCard
Drives: Asphalt Scion Frs 6MT
pm'd
DarkCard is offline   Reply With Quote
Old 06-24-2013, 02:46 PM   #263
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
That stuff on the control arm is hopefully just something from the road that got spashed on there. There's a surprising amount of grease on the road!
PERRIN_Chris is offline   Reply With Quote
Old 06-24-2013, 04:13 PM   #264
M1K3
M1K3's Avatar
Drives: vrooom...
Could it possibly be from the catch can, either valve left open or from emptying it?
M1K3 is offline   Reply With Quote
Old 06-24-2013, 10:33 PM   #265
Asphalt TG
Captain Stabbin
Asphalt TG's Avatar
Drives: 2013 FRS Asphault
Awesome journal man, Just picked up my FRS Asphalt last week excited to get started doing some things! Thanks for sharing and keep it up!
Asphalt TG is offline   Reply With Quote
The Following User Says Thank You to Asphalt TG For This Useful Post:
F1point4 (06-24-2013)
Old 06-24-2013, 10:34 PM   #266
F1point4
Photo Specialist
F1point4's Avatar
I hope so too Chris!
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 02:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 06:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 02:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 08:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 05:16 PM
