Old 02-12-2013, 03:38 PM   #253
Mitch
form follows function
Drives: RIP '13 BRZ
Here's my Strömung axle-back.
[ame="http://www.youtube.com/watch?v=poFK2GolTJY"]Strömung Axle-Back Exhaust for the BRZ / FRS - Startup - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=yD4TraiwRrE"]Strömung Axle-Back Exhaust for the BRZ / FRS - Driving Around - YouTube[/ame]
Mitch is offline   Reply With Quote
Old 02-12-2013, 06:28 PM   #254
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Originally Posted by Cajun View Post
Invidia (in my opinion) has that ricey sound. Nameless sounds awesome though
Is there a noticeable difference in sound compared to stock on the nameless? Since I don't want to pay couple hundred for it to be just abit louder :/..
Minovsky is offline   Reply With Quote
Old 02-12-2013, 07:19 PM   #255
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
Yes- look for sound clips on YouTube. It has that deep growl. Love it
Cajun is offline   Reply With Quote
Old 02-14-2013, 08:41 PM   #256
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Heres mine
[ame="https://www.youtube.com/watch?v=TZn6PZYVXE4"]FT-86 SpeedFactory V1 Catback Exhaust With Invidia Catless Front Pipe - YouTube[/ame]
Darryljr11 is offline   Reply With Quote
Old 02-19-2013, 04:48 PM   #257
b$m1th91
b$m1th91's Avatar
Drives: 2013 Asphalt Scion FR-S
OD, ID Size
Anybody know the stock mid pipe OD ID size? I am planning on making my own axle-back exhaust system and need the size for the y-adaptor.
b$m1th91 is offline   Reply With Quote
Old 02-21-2013, 01:46 PM   #258
Teo
Teo's Avatar
Originally Posted by illmatic View Post
Fujitsubo Super EX Basic Exhaust Manifold
OEM Manifold = 25.35lbs
Fujitsubo Manifold = 18lbs
http://www.fujitsubo.co.jp/prods/det...04773/00001473
Anyone has installed this?
I always use Fujitsubo on past Scooby and I want to install this on next BRZ
Teo is offline   Reply With Quote
Old 02-21-2013, 02:28 PM   #259
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Originally Posted by Itssrayyxd View Post
I have a tsudo exhaust with a straight pipe but I was never able to install it perfectly. Like the connection with the muffle and straight pipe is not perfect match. If we match and screw them perfectly, then the exhaust tips aren't aligned and even. If I try to align the exhaust tips the connection between the muffler and straight pipe won't be a perfect match. I took it to a muffler shop and they ended up evening out the exhaust tips best they can so the connection isn't even. Anybody else have this problem? Ill post some picks when I get a chance. Really busy with school, finals, work, night class, and studying lol.
Im having the same problem but with ft86soeedfactory v1 with invidia front pipe. Taking it to an exhaust shop next week.
Old 03-07-2013, 04:49 PM   #260
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Need a question answered. I want to buy the least restrictive exhaust, single or duel. I would prefer one resonator and no mufflers. Atm I have only found the buddy club ll.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-07-2013, 05:11 PM   #261
Itssrayyxd
Drives: Scion frs.
Debating between the J2 quad exhaust and a ABM works exhaust. Read the threads but I'm still stuck >.< anyone have any ideas?
Itssrayyxd is offline   Reply With Quote
Old 03-07-2013, 05:14 PM   #262
Cameronghanson
Drives: n/a
mach v
Cameronghanson is offline   Reply With Quote
Old 03-09-2013, 04:01 PM   #263
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
personally im looking for that "sleeper" exhaust. One thats quiet, and easy to DD but great and noticible sound WOT. Q300, and perrin seem to be the two best for that.
m.wood0213 is offline   Reply With Quote
Old 03-14-2013, 12:41 PM   #264
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Well, this is nothing great but I figured I'd tack in on here for lack of a better thread just in case a non-motorsport person is looking for more examples:
Originally Posted by jdrxb9 View Post
I'm not really into exhausts so to speak, but I did want to drop some weight with minimal hassle. So, with the Borla cat-back system for 'inspiration', I had a local shop fab up a system.
First, they removed everything starting from just forward of the small box resonator. Total weight removed according to my scale was 42.7 lb (3.8 box res + 12.5 mid/resonator assy + 26.4 axle back assy). They replaced that with 16 ga 2.5" OD SS tubing, a centrally-located Borla 40942 muffler, and more 16 ga 2.5" OD SS tubing. That's it - single exit, no tip, just functional. Total weight added back was ~20.6 lb (8.0 muffler, 11.6 pipe, ~1 for unmeasured hangers and welding), so the total savings is approximately the same as a muffler delete.
I don't put a lot of stock in exhaust videos, but I put this together just to see how it would turn out and compare to other videos:
https://vimeo.com/61769432
I tried some inside shots with the gopro mounted to the side window, but at moderate revs you can't really hear the exhaust at all over the wind, road, and mounting/housing noises. In person, there are a couple interesting resonances in the 2k-3k range, but nothing bothersome and overall I'm satisfied with it.
As far as any power increase, I have no idea. I have no plans to dyno it and the axle-back part is 'crush bent', which probably compromised the benefit of the 2.5" a bit.
cheers!
jdrxb9 is offline   Reply With Quote
Old 03-15-2013, 04:08 PM   #265
GT 86 Brah
u aware?
GT 86 Brah's Avatar
Drives: it like a turtle.
[ame="http://www.youtube.com/watch?v=fmXL6PBU0Fo"]FR-S/BRZ/86 WORKS AB-M delete acceleration from far away + fly by - YouTube[/ame]
GT 86 Brah is offline   Reply With Quote
Old 03-15-2013, 04:09 PM   #266
GT 86 Brah
u aware?
GT 86 Brah's Avatar
id suggest Q300. my friend has its just as quiet as stock even when you push it
LIGHTNING RED BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 409 03-01-2025 11:28 AM
FIRESTORM FR-S Compilation DarrenDriven FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1294 10-23-2023 03:57 PM
ARGENTO FR-S Compilation DarrenDriven FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 565 09-28-2022 11:42 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
