Old 04-02-2014, 11:45 AM   #253
Originally Posted by ultra View Post
Curious: will the JR CARB tune work on a de-catted car as-is then? Or would a catless car require a custom tune?
It'll throw off the VE enough that you'll probably end up in limp mode (the car will think something is severely wrong).
Old 04-02-2014, 12:44 PM   #254
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Wow, check this out! A Vortech SC was able to hit 300WHP at the wheels.
http://www.ft86club.com/forums/showthread.php?t=62270
You think we can get these numbers with JRSC?
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 04-02-2014, 12:54 PM   #255
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
^this
Doesn't look like he had any fuel mods either. Just exhaust mods...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 04-02-2014, 01:15 PM   #256
enivid
enivid's Avatar
Drives: WRB JR BRZED
He had to go to 8000 rpm to do it
enivid is offline   Reply With Quote
Old 04-02-2014, 01:40 PM   #257
That Vortech car did 266 with Just the kit. I'm curious as to his baseline NA.
Old 04-02-2014, 07:50 PM   #258
Bl1tzkr1eg
Drives: Toyota 86
Hi Mike, yup. Started with 266whp with the kit. Bseline of my car bone stock is 147whp when it was dynoed (1,500kms milage)
Bl1tzkr1eg is offline   Reply With Quote
Old 04-02-2014, 08:12 PM   #259
Xerious
Xerious's Avatar
Nice setup! Congrats on hitting 300 whp.
Sent from my SAMSUNG-SM-N900A using Tapatalk
My Build
Old 04-02-2014, 08:41 PM   #260
O.o
That's over 400 at the crank based on the baseline.... that's some serious power!
What kind of fueling mods did you have to do?
Old 04-03-2014, 12:58 AM   #261
Bl1tzkr1eg
Drives: Toyota 86
On stock injectors and pump, afr was leaning out past 7000 rpms. So, my rev limitter had to have a 6800 cutt off.
Im now on 700cc DW injectors and 265 l/hr fuel pump.
O.o
Old 04-03-2014, 01:32 AM   #262
jamesm
I maxed the maf with only a catback (both cats in place) on the jrsc kit I tuned. It was hitting 5v almost exactly at redline on the first run.
Old 04-03-2014, 09:35 AM   #263
Venator
Venator's Avatar
Drives: Asphalt FR-S
So this may be a silly question but when I get this kit will I need an better maf? If so where or what should I be getting?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 04-03-2014, 10:14 AM   #264
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Calum View Post
These guys aren't the first to mention having issues with the supplied maf housing being too small. Would you consider offering a kit with an optional larger maf housing? You would open up your kit to a much bigger market of guys looking to tune with the basic ecutek software aswell as anyone using a different tuning platform that doesn't allow hybrid maf/map tuning.
Sent from my samstone
Ya not going to lie, I don't fully understand why I repeadiately read cases of "running out of room" MAF wise with the Rotrex kits. I'd like to know and understand what can be done or changed to make everything run with headroom. As well possibly what design changes need to take place for tuners to not have to do SD hybrid tunes etc....
Obviously these kits work, there are some work arounds to but... Was this just an oversight by both Rotrex kit makers or ...?
Old 04-03-2014, 10:33 AM   #265
Venator
Venator's Avatar
Yeah, I am super confused now... What's the BEST way to get this done the first time? I am looking to pick this kit up in the next few months and now I'm not sure what I'll need.
Old 04-03-2014, 11:27 AM   #266
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'll attempt this, but with the caveat that my knowledge on this is limited.
The reason for the issue is the size of the MAF housing. The MAF sensor, to my knowledge, doesn't actually measure the total mass of the air but the air's velocity. The size of the tube the MAF sensor is in allows the mass of the air to be extrapolated from that velocity.Using a larger housing allows for a larger maximum mass air flow because the flow velocity is lower for the same volume or mass of air per unit time, thanit would be for a smaller housing.
The only change that would be required to fix this is a larger MAF housing, and ensure the air doesn't become too turbulent as it enter and exits the new sized housing. One of the work arounds for the time being is to limit air velocity so the sensor doesn't go out of range. (you should never be at the limit of a sensor as A you don't know if the actual system has exceeded the maximum output of the sensor, and B most sensors lose a lot of accuracy in the last 10%ish of their range) The other work around is to use a mass air flow/manifold absolute pressure hybrid tune. Basically the system uses both systems, but relies on one or the other in the air flow ranges where those systems work best, in this setup.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
