#253 |
Drives: 2013 Asphalt FRS
sorry for bring back this old thread up, is it necessary to put back the boot linkage? I tear my up.
#254 |
Drives: 2015 BRZ
Id say yes since it protects from the elements.
#255 | |
Drives: 14 BRZ Red premium
In cold day it will definite be harder to pull the reverse lock up and since is used on the ball joint it will make it a bit sticky too. do keep that in mind |
#257 |
Do anyone of you know what the 2 oring is for? I couldn't figure it by searching her. @tom@kartboy
#258 | |
I think is there to minimize left and right play. But i could only put 1 of the oring on. I try to put 2 but have no success of putting the locking pin back on to the linkage bolt with 2. |
#259 | |
#260 |
Drives: 2014 BRZ Limited 6MT
I just installed mine last night and I have the rattle about 4k on WOT. Doesnt bother me cause its not my daily... cause racecar i guess
#261 |
i don't mind rattle, i just like to install everything what they come with.
#262 | |
Drives: 2015 86 GTS + Mitsi Lancer GSR
I've been running my Kartboy since about the start of the year and absolutely love it! Could be a little higher but other than that, it's perfectooooo. No slop, little rattle but racecarlyfe, shifts perfectly. |
#263 | |
#264 |
Drives: 2013 BRZ Limited
Just installed the Kartboy yesterday. The 2 O-rings are there to help with the rattle, but I can only put one. Couldn't get the locking pin/clip back on when I put both on. So far, no rattles.
As for the shifter itself, I love it.
#265 | |
I think the o ring wil help with the rattle and side to side play of the shifter. Ya i try to put the 2nd one in after i install it for 5 month, and there is just not enough space. Unless some one was able to compress it and put the pin back on. ( maybe from the bottom of the car) |
| The Following User Says Thank You to j_motion For This Useful Post: | MechOps (06-22-2016) |
#266 |
meh the first few miles it was a rattle monster for me, but it went away after a few miles. Still rattles mildly now but thats ok cause racecar. I didnt install either or the 2 rubber o rings
| STI Short Shifter Kit | Hanakuso | Engine, Exhaust, Transmission | 37 | 01-18-2016 08:19 PM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Transmission and Driveline | 16 | 04-18-2013 01:18 PM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Announcements, Contests, Giveaways | 34 | 03-18-2013 02:18 PM |
