Old 07-21-2015, 06:40 PM   #253
DarkSunrise
DarkSunrise's Avatar
Originally Posted by sw20kosh View Post
My buddies and I take spare coil packs to the track with us at all times. They tend to foul at the track.
We have tried heat shielding them. No difference.
Damn, I was hoping that might solve it. Appreciate the heads-up though, saved me from ordering gold foil.
2022 BRZ Build
2013 FR-S Build
Old 08-17-2015, 09:02 AM   #254
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Update: After replacing the coil pack on Cyl #2 TWICE now, I received a P0302 and P0300 multiple times throughout the day at Sebring this past weekend (Cyl # 2 and random misfire code). No noticeable hesitation, stumbling or performance decrease though.
Before the CEL came on with those two codes and stayed on, I had the CEL flashing for the first few laps in only a few spots on the track - just before the braking zones at Turn 17, Turn 7 and Turn 10, where I had sustained higher RPMs in a higher gear.
For those of you who are receiving the same code after replacing the coil pack, have you checked/replaced the spark plug in that cylinder? I think that will be my next step, as I was talking to a top notch Subaru engine builder and tuner about the issue, and he informed me that a bad plug in that cylinder could possibly be creating high resistance under heavy temps, causing the coil pack to fail (and then ultimately a misfire code).
That's going to be my next step, I'll report back with updates.
Cylinder #2 is probably in the coolest spot in terms of proximity to the header, so I can't imagine it's heat killing the Cyl #2 coil pack. I'll probably end up wrapping the header and then putting DEI cool tape on the coil packs to help with longevity.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
ATL BRZ (08-17-2015)
Old 08-17-2015, 09:05 AM   #255
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@raul
Old 08-17-2015, 09:57 AM   #256
BRZ-One
Drives: 2013 Subaru BRZ
I had the same issue at Sebring several times. I ended up getting a vented hood to try to get some of the heat out of there. I also wrapped the header and I also placed a heat blanked above the header where it comes below the right side of the engine. (DEI Heat Shield)
At the same time I changed all 4 spark plugs and the coil that pulled a code.
That was the beginning of this year and I have not had any misfires in 3 or 4 track events at Sebring. My current assumption is that the stock plugs are the weak link in the ignition system for heavy track use. I've read a few people have upgraded the coil packs but are still suffering from the same symptoms.
I'm currently looking at upgrading the plugs to something more appropriate for the track use.. Looking at the HKS set and looking at some Denso Racing applications, waiting for Denso to get back to me with the info for our application.
BRZ-One is offline   Reply With Quote
The Following User Says Thank You to BRZ-One For This Useful Post:
smbstyle (08-17-2015)
Old 08-18-2015, 07:31 PM   #257
Turdinator
Señor Member
Turdinator's Avatar
Has any one tried reducing the spark plug gap a little so the coils aren't working as hard?
1974 TA22 Celica
2013 86 GT
Old 08-31-2015, 08:25 PM   #258
DarkSunrise
Changed the passenger front coil today after getting a recurring P0351 code at the track. Was annoying because of how little space there is, but after a couple of cuts on my knuckles, it's done. Took me a little time to find the release tab on the connector (it's at the back towards the wire). Redlined a few gears and no more code. Always a good feeling when the car is running strong.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Apoc (08-31-2015)
Old 09-03-2015, 05:48 AM   #259
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Where do I get new ignition coils? My cay car started getting P0351 code. I feel like I forgot how to use the Internet, because I haven't been able to find them online.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 09-03-2015, 09:04 AM   #260
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Any dealership will have them. The part number ends in 652 and is posted on this thread.
The Following User Says Thank You to ATL BRZ For This Useful Post:
FLIPs_FR-S (09-03-2015)
Old 09-03-2015, 09:42 PM   #261
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
https://secure.revolutionparts.com/g...=ignition-coil
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
Old 09-03-2015, 10:31 PM   #262
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Awesome thanks @Vracer111
Old 09-03-2015, 10:51 PM   #263
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
There are two earlier part numbers ending in 650 then 651 so something had to have been changed. I'm wondering if running the typical exhaust and tune mods, specifically the timing advance warrant a colder rated plug.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 09-04-2015, 12:16 PM   #264
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
What about the possibility of bad fule? I ran it damn near dry. Refueled at another station and no more CEL.
Old 09-10-2015, 05:28 PM   #265
mario17623
Drives: FRS 2014
BTW tracked the car in hotter weather both days this weekend, no CELs
Might have just been a bad coil afterall.
Did you buy oem ones? Or did you buy some aftermarket ones
mario17623 is offline   Reply With Quote
Old 09-12-2015, 03:03 PM   #266
SocalBurt
Just read through the entire thread, lots of good info. I have a 2013 FR-S 40,000 miles and i just got the CEL
and my bluetooth OBDII scanner indicates Ignition Coil A. I have no mods but its about 115 degrees where i live.
My dealer is charging a lot for the install. Do you guys have any good suggestions where i can buy a coil online for a 2013?
For some reason i'm not finding it searching. I'm concerned if i buy a 2015 part the design may have changed. Well i'm gonna try
to tackle this project soon seems simple enough. Just my observations...i have this problem on hot days at WOT otherwise the car behaves normal.
SocalBurt is offline   Reply With Quote
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
