Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-19-2017, 12:02 PM | #253 | |
You can run the 18x9.5 all around but with a 235 or smaller tire stretched. Otherwise if you run any bigger of a tire it will hit/rub against your suspension in the front. An option is to get 5-10mm spacers and then you can run the optimal 255 tire. But at that point the wheels will be sticking out from the fenders and not look good at all. Long story short. Anyone wanting to run an 18x9.5 square setup on an FRS/BRZ it is best to have coilovers. |
10-27-2017, 04:02 PM | #254 |
Drives: frs
Perfect fit tires for 18x8.5"
finally had a chance to put 255/35 on my 18x8.5 42 57xtremes and this combination makes the protruding lip totally disappear!
unfortunately i strongly suspect a 255/35 tire will make make the front poke out a lot. will know over the weekend and post pics. pics of michelin pss 255/35/18 on 18x8.5x42 https://gyazo.com/511a1de27064bbd4d26fcd432aa0f65d https://gyazo.com/82d6e4920d32bb3c6681ae6871daa894 pics of front 18x8.5x42 with kumho 235/40/18 tires (note how much the lip sticks out) https://gyazo.com/b958465a3657a8eceb72400d46fb46f0 |
The Following User Says Thank You to godzuki For This Useful Post: | Kami Speed (10-27-2017) |
11-06-2017, 09:40 PM | #255 | |
Drives: frs
I am on Tein coilovers with about a 3/4" drop and no camber in front and there is absolutely no rubbing. Yes, there's a bit of poke on the front but not that big a deal. Last edited by godzuki; 11-06-2017 at 09:56 PM. |
01-04-2018, 08:53 AM | #256 |
GT86PersianClub
Drives: 2014 Crystal Black Silica GT86
Hi guys
Im thinking of getting the 57 xtreme 18x9.5 +40 for my car and i have D2 coilovers installed,my coilover has camber setting in the front,im thinking of 255/35 or 255/40 because our roads arent that good, im scared of the rubbing problem,can anyone help and tell me should i use 35 or 40? Thanks |
01-04-2018, 02:19 PM | #257 | |
Country Boy 4 Life
24.6 stock diameter. 255/40 has a 26" diameter, which is 6% larger. Generally you don't want more than a 3% +/- difference.
I LIKE TIRES! |
01-12-2018, 07:16 AM | #258 |
GT86PersianClub
Hi guys
Where can i buy the 57xtreme for a good price? if you know tell me in PM please And whats size lugnut should i get? Is it M12x1.25 & M12x1.5 ? Last edited by Mehrshad; 01-13-2018 at 06:40 AM. |
03-20-2018, 03:51 AM | #259 | |
03-20-2018, 11:29 AM | #260 |
Yes, it is recommended to get rear LCAs to get your camber back to or close to within OE spec. Since when you lower your car the geometry will be much different and these cars do not have any adjustment from the factory.
04-23-2018, 04:08 AM | #261 |
GT86PersianClub
Hi guys
I finally got my 57xtremes in Matte Graphite, i got the 18x9.5 +40 , im running them on Michelin Pilot Sport 4 , 255/35/18 square fitment and Rays Dura-Nut L42 Straight type lugnuts,with 65/56 hubs,and i have D2 Racing Coilovers,i dont know how much i lowered it ,i think its an inch.i got a little rubbing on full lock these are some photos of my car. https://ibb.co/dWcyWx https://ibb.co/iz85Bx https://ibb.co/kM7bJc https://ibb.co/eCHyWx https://ibb.co/hfWxPH https://ibb.co/n8gaBx https://ibb.co/kqLrjH Last edited by Mehrshad; 04-23-2018 at 05:02 AM. |
Tags |
gramlights 57xtreme, toyo tyres |
Similar Threads | ||||
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 | L8Apex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 71 | 08-05-2023 09:20 PM |
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 | jadewbj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 378 | 06-26-2017 05:57 AM |
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 12-04-2014 10:56 PM |
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 | MVJ1975 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 10-05-2013 02:29 AM |
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-05-2012 12:44 PM |
