go_a_way1
Old 12-28-2012, 01:48 PM   #253
ayau
Drives: Some rust bucket
It's not an issue that we've run into since we're currently on coilovers that are fully height adjustable (for camber in the rear) and have a camber plate + crash bolt in the front...
what would you recommend for the rear on stock height?
Old 12-28-2012, 02:09 PM   #254
We got about -1.1 out of the rear by playing with tolerances...
Old 12-28-2012, 02:13 PM   #255
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
How's the engine holding up? Reliable?
iLuveKetchup is offline   Reply With Quote
Old 12-28-2012, 02:14 PM   #256
well... we're on a 2nd engine on the BRZ...
My s2k is at 114k and counting.
Old 12-28-2012, 02:16 PM   #257
ayau
did you guys figure out what caused it?
Old 12-28-2012, 02:35 PM   #258
Direct injector seal failure.
Old 12-28-2012, 03:25 PM   #259
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
kind of off topic, but i'm interested in @CSG Mike's opinion.
what "solution" would you recommend to achieve some negative camber on the BRZ? i'm pretty set on some SPC camber bolts at the front, but i'm unsure about the rear. possibly the stock lower control arm with an adjustable one? i figured these parts will get me about -1.5 degrees of camber.
i suppose you could also get some lowering springs for additional camber, but they'd have to be pretty similar to the stock springs, otherwise you're going to need to upgrade to some aftermarket dampers.
On the front the lowering springs won't change the camber much. I gained .1 negative camber with 1.4" lowering springs.
Up front camber using OEM control arms = crash bolts and camber plates.
Rear will have more than enough with a reasonable lowering, and the solutions there are obvious. Personally I want to see some adjustable UCAs instead of the LCA solutions.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ayau (12-28-2012)
Old 12-28-2012, 03:27 PM   #260
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
What happened to the engine? Lean and popped?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-28-2012, 03:42 PM   #261
ayau
how much camber did you gain in the rear from your lowering springs?
what's the advantage of an ajdustable upper control arm vs lower control arm?
Old 12-28-2012, 03:47 PM   #262
It was actually misfiring (losing charge through the failed seal under load, into the intake manifold...), but we caught it really early, so there was no permanent damage.
However, FHI wanted the engine for teardown, and replaced ours...
Only happens when the engine is FULLY heated up (not just the temp gauge in the "normal" spot), and only under 3500 RPM or so.
Old 12-28-2012, 04:12 PM   #263
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
^ well said. I am also thinking of selling the s2k CR and have the BRZ to do it all - daily, auto-x, and track.
My 01 S2000 was recently totaled by a deer. So I am considering doing this as well. I can't decide if I want to get another S2000 or go BRZ. I have a Subaru RS for the winter, so that isn't an issue.
My S2000 was supercharged though, so a SC/turbo would definitely be in the BRZ's future, assuming one is extensively tested on the track.
Lots to think about, just need to make up my mind.
goldenfri is offline   Reply With Quote
Old 12-28-2012, 04:50 PM   #264
iLuveKetchup
Drives: EFF JAY
If I didn't have my s2k and was buying a car now, I'd get the BRZ. It doesn't make sense for me to move to a BRZ, but this would be a good opportunity in your situation.
The Following User Says Thank You to iLuveKetchup For This Useful Post:
goldenfri (12-28-2012)
Old 12-28-2012, 11:26 PM   #265
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
-2.3 on one side and -2.7 on the other.
LCAs will change the track by pulling the wheel inward (slightly, but still), UCAs can just push the top of the wheel back out.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
ayau (12-28-2012)
Old 12-29-2012, 12:56 AM   #266
Hmmm our car was uneven from the factory as well... by 0.4 too. Did you end up evening it out by tolerances or arms?
FR-S vs S2000 vang FR-S / BRZ vs.... 436 09-19-2012 05:52 PM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 11:46 PM
S2000 or MX-5 balance Other Vehicles & General Automotive Discussions 10 11-01-2011 03:01 AM
S2000 from hell CyberFormula Other Vehicles & General Automotive Discussions 13 07-09-2010 10:05 PM
