| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#253 |
Drives: 2018 BRZ
#254 |
Drives: 2013 Scion FR-S Series 10
TL;DR
He is using math to show that the "real wheel torque" in the BRZ is only about 20% less than the Ascent, despite the Ascent having 50% more torque, assuming you are in 2nd at 60 mph with 18" tires. Additionally, due to a much lower mass in the BRZ, the feel of acceleration in the BRZ will be closer to that of the Ascent despite having lower real wheel torque. |
| The Following User Says Thank You to mazeroni For This Useful Post: | Ohio Enthusiast (01-13-2021) |
#255 | ||
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Not trying to detract from the video; just pointing out that there is a bit of speculation in the math that may not match up with the production car. It would be great if the car hit 60mph in second at redline - but that remains to be seen.
#257 | |
Drives: '23 BRZ
Posted this a while back, here it is again, rear wheel torque for the current car with 4.3 diff in black, '22 with 4.3 in blue, 4.1 in red, and 3.9 in green, based on someone's very good (IMO) scaling of the '22's power curve from the dash display calibrated to official torque@rpm and power@rpm specs. Either way it's gonna accelerate quicker overall. Again, with a 3.9 diff it'll hit 60 in 2nd gear. Personally I'd be happy with any of these ratios... Last edited by ZDan; 01-13-2021 at 09:27 PM. |
#258 |
LMGTFY
Drives: 13 FRS, 91 Miata
Everything under "Why no turbo" and "Throttle Response"
Cost/Complexity - Ascent already has turbo. Is not complex. Nearly same MSRP. (Less than the cost of an aftermarket kit) All the parts are there already. Keep the compression the same if not drop it half a point and run a turbo. Higher CG Because of bottom mount turbo. - Assumption 100% Who is to say they couldn't mount it in front of the engine like so many kits do already. Even if they did bottom mount, I doubt the change would be drastic. Weight gain - 100lbs??? What kind of giant ass turbo is he thinking of? 50-70 maybe, even at his overestimated 100 that is still minuscule in the big picture. Most of that weight could easily be offset by losing heated seats and stuff like that. Throttle Response - Maybe with that big ass turbo he's thinking about. But with a small responsive modern turbo all of those arguments don't hold up. His engine/wtq analysis - Beside being assumption again and the arbitrary use of 60mph in 2nd gear. There is zero reason the Ascent engine couldn't be made to rev to the same redline as the BRZ. With those numbers made equal the BRZ makes 2,555 lb-ft, the difference is 20% in the other direction. (Real numbers are closer to 18.5% for his numbers and 22.222222 for mine.) Even if I drop the peak Tq down to a more reasonable 250 considering the high comp and reliability, the BRZ still has 12% more. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Ohio Enthusiast (01-14-2021) |
#259 |
Drives: ‘16 4Runner, ‘19 Corolla HB
That engine though. Where will it sit among the great 4cyl NA's?
The estimated 100lb weight gain isn’t just the turbo. Intercooler, piping, oil supply, water cooling, etc. With the relatively shallow engine bay, there would be some re-engineering. Just because the aftermarket fits something under the hood, that doesn’t mean an OEM can use the same placement. There are regulations about how a hood has to crumple in the event of a collision with a pedestrian. He did exaggerate a couple things, but I don’t think he’s completely off base.
If the business case were there, Subaru and Toyota engineers would have figured it out. There is just enough cost and just small enough volume that there wouldn’t be a ROI, so those relatively minor hurdles are enough to derail a turbo BRZ/86. Sent from my iPhone using Tapatalk |
#260 | |
LMGTFY
The turbo is usually the heaviest part next to the manifold. Then manifold will almost certainly not be much of a difference between the turbo vs non turbo versions. Spent an hour googling hood crumple zones and pedestrians. Could not find anything to support that comment. Even then, everything about that is well within the ability to engineer. IF they had designed it like that in the first place. The business/cost/ROI case is the only thing that I'd agree with. Mainly for the part about the low volume thing. But that isn't what was talked about in the video. He insinuates that it would be too hard and expensive to do.' That is just stupid going by the fact that this is a car made by large car companies and the MSRP of the Ascent. |
#261 |
A friend, who was a powertrain engineer for Honda, told me the thing about crush zones.
Looking for an apples to apples comparison, I remembered that the Outback offered both the FB25 and the FA24DIT. In touring trim, the turbo version is 3937lbs. The N/A version is 3772lbs. Now, I’m sure the XT comes with a beefier transmission and some equipment differences, but it is getting an extra 165lbs from somewhere. It also might be an air to water intercooler which are heavier than air to air. I’m not sure. Sent from my iPhone using Tapatalk Last edited by Quentin; 01-14-2021 at 07:41 AM. |
#262 |
Drives: VW GLI 6MT
I thought the video was spot on. Jason only provided the comparative wheel torque/gearing/rpm calcs to make the point that the stock Ascent engine may not be THAT much faster than the 2022 BRZ engine given gearing that maximizes both torque curves. It served as a good mental exercise, nothing more.
But he made one comment that resonated with me. Referring to the WRX, “You get in that car, you give it 50% throttle and get 100% of the acceleration. You get full boost. That’s not what I asked for.” As someone who currently drives a turbocharged car, that is true and very irritating at times. As much as I’d like to be a racecar driver like many on this forum, I’m not and 98% of the time I drive at 50% throttle or less. Particularly with a MT, having a more precise power delivery is a huge plus for the NA 2.4 to me, even if it is slower than a turbo. |
#263 | |
Drives: '23 BRZ
#264 |
Drives: 22 BRZ limited MT
Pwr/Wt
Ascent 0.059 hp/Lb (lightest Ascent weighs 4430 per Subaru USA) 2022 BRZ 0.081 hp/Lb (Using Jason's whiteboard weight of 2815) |
#265 |
Drives: 2016 Scion FR-S
My vote for one of the best 4 bangers of all time.....
![]() The Toyota 22R/RE. Sure, it doesn't have a ton of horsepower, but it's literally a brick shit house. Had one in my 95 Toyota pick-up 4x4. That little truck ran forever and took plenty of abuse off road. Sent from my iPhone using Tapatalk |
| The Following 4 Users Say Thank You to Silviacrazed For This Useful Post: |
#266 |
Classic!
| The Following User Says Thank You to scuzzy For This Useful Post: | Silviacrazed (01-14-2021) |
| How to get that classic high-pitch 4cyl sound from brz? | yEEt42069 | Engine, Exhaust, Transmission | 45 | 04-08-2020 11:51 AM |
| i just realized... 2016 turbo 4cyl CAMARO vs FRS/BRZ | Shinchu | FR-S / BRZ vs.... | 98 | 09-28-2015 03:18 PM |
| COMPLETE OEM engine harness! Great for tuck | Nizz300Ft86 | Audio/Visual, Electronics, Infotainment, NAV | 2 | 03-13-2014 12:23 PM |
| COMPLETE OEM engine harness! Great for tuck | Nizz300Ft86 | Engine, Exhaust, Bolt-Ons | 0 | 11-25-2013 05:19 PM |
| MPG of a 600hp 4cyl. Engine | chuttney1 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 03-15-2012 09:06 PM |
