#253 | |
What ride height are you set to? |
#254 | |
Drives: 2013 FR-S, 2007 Acura TL 5AT
The endlink clearance issue is fairly common on our cars when running a lot of camber through camber plates. I had this issue with my stock endlinks. With the strut pushed all the way in for camber, there's little room with the inner fender for the endlink to move. The contact looks somewhat minor, so just about any lower profile endlink will fix it. I use RacerX as of recently when I replaced my Megan endlinks(replaced while troubleshooting a separate issue). I have plenty of clearance with camber maxed to -3.2*.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build YouTube: Angel Christov |
| The Following User Says Thank You to AngelGT86Racer For This Useful Post: | strat61caster (01-31-2020) |
#255 | |
Drives: 2022 GR86
See the photo, I'd say about two fingers between the tire and the arches in the front. The wheel/tires are 17x9 +37 Titan 7 T-S5 and 245/40R17 GT Radial SX2s.
#256 |
What's the minimum drop with these installed? I'm very interested, but my apartment complex also has some gnarly speed bumps. How close can you get to stock ride height?
Also, ^ Those Titan7 wheels look amazing. I'm glad I found out about those. |
#257 | |
Drives: 2017 BRZ w/PP
there is quite a bit of threadding on it im willing to bet you can actually run higher than stock |
#258 | |
Drives: 2022 GR86
Base Ride Height Drop: Front -1.2 inches, Rear -1.2 inches Max Low / Hi: Front -2.3 inches to 0 inches, -3.0 inches to 0.6 inches Recommended Low / Hi: Front -1.6 inches to -0.8 inches, Rear -1.6 inches to -0.8 inches I believe CSG Spec only differs in the valving of the dampers, not the springs? Thanks, I could say exactly the same when I found about them myself! It was hard to find any fitment info on those at the time, glad I was able to spread the word. |
#259 | |
Drives: 2022 GR86
Thanks to @AngelGT86Racer for sanity-checking my ideas before I implemented them! What I did was I jacked the front of the car, measured the distance between the top of the tire and the top of the fender arch. On the front right it was 75mm, and on the front left it was something like 82mm. I then took off the wheels and measured the A and B lengths of the assemblies and compared them to the values recommended in the installation instructions. The "B" measurement (distance between the top of the damper body and the bottom collar) on the front left was ~2.5mm longer than recommended — so clearly I was running into the HBS more frequently than intended. I've added 3 turns of preload (6mm, assuming 2mm thread pitch) and then shortened the damper body by 3 turns as well. As a result, now my droop travel is the same left vs right (75mm or 3"), without changing the ride height under load. Assuming equal total suspension travel, I now also have the same amount of compression travel left vs right. To the best of my knowledge, this is really what damper body length adjustments are about — fine-tuning the compression/droop travel. Then I went to test drive it, and confirmed that the ride feels a lot less harsh on the highway. Haven't noticed any rubbing while spirited driving in the mountains, but will also monitor that at my next autoX or track day. Will also check the amount of droop in the rear some day. Last edited by timurrrr; 04-16-2020 at 08:23 PM. |
| The Following 5 Users Say Thank You to timurrrr For This Useful Post: | AngelGT86Racer (04-01-2020), CSG Mike (04-02-2020), MrSkubi (03-13-2021), Randoman5 (03-31-2020), strat61caster (03-31-2020) |
#260 | |
It was a little odd that they initially sold them only in a size that doesn't really fit on the car, but I'm going to go with the 17x9s too. |
#261 | |
Drives: Subaru BRZ / Toyota 86 Experts
#262 | |
Drives: 2022 GR86
You're saying I remove them? |
#263 |
Drives: 2017 Subaru BRZ
Installing mine now and wondering the same. Are the brown plastic bits supposed to be removed while in use?
#264 | |
#265 |
#266 |
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | BRZ FTW (04-20-2020) |
| WTB Tein Flex Z | HachiRo | Want-To-Buy Requests | 1 | 09-19-2016 02:13 PM |
| tein flex z | mclovin85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-14-2016 07:27 PM |
| TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day | CounterSpace Garage | Groupbuys | 47 | 02-18-2016 01:33 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 10:33 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
