Old 07-25-2015, 01:25 PM   #2633
DeaconRoc
Drives: GT86
Originally Posted by FISHBURGLAR View Post
I have kwv3 and will be installing them soon. i will be using gruppe N front top hats with camber bolts for camber adjustment. but for the rears i bought the whiteline adjustable bushing. i will be doing all the install myself besides the bushing. problem is no one is willing to put them in and align the rear camber. and the only ones who are willing are charging me way too much and i must leave my car for a day or two.
my car is a DD with alot of spirited driving. im looking for a 1.25-1.5 inch drop. im thinking of around 2 degree camber in the front and 1.7 in the rear. will SPC lower control arms give me what im looking for? or will i throw out my rear geometry and better i pay for the bushing install?
i want to do everything right the first time around. THank you!
I have the whiteline camber bushes - took the shop about 2 hours to install. They said it wasn't too hard at all.
DeaconRoc is offline   Reply With Quote
Old 08-10-2015, 02:06 AM   #2634
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I have RCE yellows with Koni Yellow shocks. Would I see any benefit to putting on the Whiteline Roll Center / Bump Steer correction Kit. I'm not sure what bump steer feels like so I'm not sure if I have any.
stockysnail is offline   Reply With Quote
Old 08-11-2015, 06:54 PM   #2635
rick s
rick s's Avatar
Drives: 2013 FR-S Ultramarine 6MT
Question
Installing TRD springs with bilstein B8s. Question, what is the orientation of the tab on the rear top mounting assembly, front or back? In the DIY section there is a comment saying front and then a little later another post saying rear. After that the subject falls off the face of the earth
Even the Dealer wasn't quite sure, not very comforting!
Any info would be greatly appreciated.
rick s is offline   Reply With Quote
Old 08-11-2015, 08:03 PM   #2636
ZionsWrath
Thanks
ZionsWrath's Avatar
Yes I go to AZP when I don't DIY, I'd recommend them as well
Old 08-11-2015, 08:44 PM   #2637
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1 on this question in general. It seems to be axiomatic that a slight drop is of great benefit. Are there any adverse effects requiring correction?
Old 08-11-2015, 11:05 PM   #2638
stockysnail
Just the tip
+ my original unanswered question:
Thoughts @CSG Mike or @Racecomp Engineering or any suspension gurus?
Old 08-18-2015, 08:43 AM   #2639
Alita
Alita's Avatar
Drives: 2015 Subaru BRZ Series.Blue
I did something stupid, and hopped a curb. I had my car taken to a shop, and the caster is off, but not by much.
Factory is 5.92 and there is no way to adjust outside of messing with your frame but your driver’s side is 5.14 and your passenger’s side is 5.89.
The car drives straight and doesn’t feel bad, but i'm not sure if i should go to a frame shop and have the strut knuckle looked at, however the car is visually fine.
i'm planning to install coilovers soon, and i'm not 100% if i should replace the strut knuckle.
^ Click for build thread ^
Alita is offline   Reply With Quote
Old 08-18-2015, 08:54 AM   #2640
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Originally Posted by Alita View Post
I did something stupid, and hopped a curb. I had my car taken to a shop, and the camber is off, but not by much.
i'm planning to install coilovers soon, and i'm not 100% if i should replace the strut knuckle, or if planned camber adjustment will negate that need.
You mean "caster" ? 6° of camber is à lot.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-18-2015, 09:12 AM   #2641
Alita
Alita's Avatar
that's kind of what i was thinking... that's probably right. this is the info that i was sent by the friend that took it to the shop (i'm out of town).
EDIT: yeah, i just chatted with my friend, the shop told him caster, but he send me camber.
Old 08-18-2015, 09:26 AM   #2642
MaximeT
MaximeT's Avatar
I guess you can set it back to spec with Raceseng cascam. You can do it at the same time than coilovers. I don't think OEM setting is that accurate either.
Old 08-18-2015, 11:38 AM   #2643
The Whiteline roll center kit is NOT primarily for bumpsteer. It is a roll center adjustment kit that includes tie rod extenders. With just the roll center adjustment part of the kit (the ball joints), you induce some bumpsteer by moving the tie rods out of plane. The tie rod extenders minimize that change.
Anyway, yes there is a small benefit to the WL kit. It is not very dramatic, but it helps.
- andrew
Old 08-18-2015, 11:54 AM   #2644
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Will adding the parts below make the car DD more harshly?
Thinking of swapping a few parts out when the rear SPL LCA's go in. Currently on Tein Street Flexes dropped to Tein spec.
SPL Titanium Rear Traction Arms FR-S/BRZ
SPL TITANIUM Rear Toe Arms FR-S/BRZ/WRX
SPL PRO Rear Endlinks FR-S/BRZ/WRX
Thanks!
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 08-20-2015, 01:28 AM   #2645
Pabloc
Drives: BRZ Ltd WRB, MT6; '91 M5; '89 911
Bilstein B6 or B8 with RCE Yellows?
Question: B6 or B8? Is the reduced travel of B8 described in other links a problem with RCW yellows? An advantage? Does it matter with such a small drop? Is the valving the same?
In place now - RCE yellows, HVT camber plates, SPC rear LCAs, stock power.
Street (bad pavement at all times) and track use (track tires - track pads, etc)
Great thread - Thanks
Pabloc is offline   Reply With Quote
Old 08-20-2015, 04:46 PM   #2646
Go with the B6 shocks.
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
