Old 05-14-2017, 03:01 PM   #2605
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
I've emailed FBM a couple times about the downpipe fitment. It's been over a week since my last email to them, and I haven't heard anything since they requested more pictures.
Estimates from a couple shops are $200+ to remove the pipe and dent or bend it. I'd probably need to have them re-wrap it as well since I can't really do it myself when it's back on the car =/
I'll probably call FBM soon and check in. I wonder if I did something wrong since no one else seems to have this issue.
I'm also curious about recirc pipes. I don't see them on FBM's site, and I don't really care for the sound of the open dump.
TheBRZsKnees is offline   Reply With Quote
Old 06-18-2017, 11:05 AM   #2606
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
I just ordered mine after waiting 3 years! Any FBM owners in the Omaha Nebraska area?
Kerber23 is offline   Reply With Quote
Old 06-19-2017, 06:50 PM   #2607
DHitHim
Drives: 2015 CWP Limited BRZ
Originally Posted by ph4zon View Post
Regarding the OFT, Shiv offered to sell me a new one at a lower price than msrp if I sent my my tablet in to them. This really isn't what I need right now, unfortunately.
wow, that is such BS LOL
DHitHim is offline   Reply With Quote
Old 06-30-2017, 03:27 AM   #2608
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Add me to the list of FBM Turbo kit owners
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 07-08-2017, 04:10 PM   #2609
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Ive had mine for nearly 2 years and my 4bar map only failed. HRI saved my ass on diagnostics.
Love my kit! Tires only last 10k
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-04-2017, 03:42 PM   #2610
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
My install is almost done! The most mechanic thing I ever did was replace a throttle body on my Jetta, and I decided it was a great idea to install this turbo kit by my self. I just finished up the injectors and fuel pump. I still need to connect the oil line to the return spout, finish connecting vacuum line, tighten all the fittings, and put everything back! Im pretty excited!
Old 08-05-2017, 05:36 AM   #2611
Eazy-V
What kind of dyno numbers are people getting, mine seems to be on the low side?
I have the base kit with GTX2867, Walbro 485 Fuel Pump, Omni 3Bar Map Sensor, 3" over/front pipe, Greddy EVO3 catback, Greddy Profec Boost Controller, ACT Heavyduty 6puck sprung Clutch with Prolight Flywheel.
My dyno numbers are the following:
E15 @ 11PSI = 275WHP, 215FT/LB
E75 @ 11PSI = 325WHP, 260FT/LB
E55 @ 14PSI = 325WHP, 270FT/LB
E55 @ 16PSI = 365WHP, 300FT/LB
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 08-19-2017, 01:25 AM   #2612
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Finished up my install. I am at 260whp and 210FT/LB on 93 @ 7psi. Ran into some issues with the fuel pump o-ring that i bought so we couldn't push it much further as the fuel pressure dropped in the top end. I ended up getting it fixed so I am doing some e-tune adjustments. Ill be looking for more power later, but right now I am looking for some safe fun
Old 08-19-2017, 10:45 PM   #2613
Eazy-V
Your issue is pretty much what I have, so I'll take a look at my o-ring.
Also, did/do you have an stalling issues shortly after startup which goes away once you get the car moving a bit?
Old 08-22-2017, 12:32 AM   #2614
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
I had some issues where unless my car was moving it would stall -sometimes- but otherwise ran great while moving. I am unsure if the issue was resolved via the dyno tune or the O-Ring however. As of now I am having zero issues. If you have any questions or what not feel free to shoot me a message. I am not an expert but I did manage to get all of it together and running my self.
As for the O-Ring, Originally I didnt get a 2nd one with the kit so i couldn't get it started. I ran across a youtube video where it showed the fuel pump having 2 O-rings so I bought one. I was able to get it started but it was a little too loose so I lost pressure on the top end. After getting a more snug fitting fuel pump I can happily say the issue is gone and I have not had to pull the fuel pump out in over a week. Thank God.
Old 08-24-2017, 01:26 PM   #2615
TheBRZsKnees
Drives: 2014 BRZ
I'm thinking of getting a Fumoto valve for my FBM oil pan. Does anyone know if the drain plug is the same size as stock?
Old 08-24-2017, 02:30 PM   #2616
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Same size. I had one on my stock oil pan and just moved it over to the FBM pan when I installed the turbo.
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 08-31-2017, 02:43 PM   #2617
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
In that case, may I have the honor to be added to the owners list? I've had the kit and other upgrades since last year xD
Marcoscrdo is offline   Reply With Quote
Old 09-25-2017, 05:18 PM   #2618
Randoman5
This kit looks awesome. It seems like the best FI option for the twins, but i have a question.
What do you guys do when it's time to pass emissions tests? I assume a lot of people live in places where they don't have to, but there seem to be a lot of people running turbos in cities and California.
I always assumed a tuner could rig the ECU to tell and OBDII scan that all the emissions equipment was functioning. i live in Ohio and all they do is a visual inspection for a catalyst (I'd keep the second one) and plug in a scanner.
It's now my understanding that tuners don't do this. In hindsight the legal implications are worrisome so I can't blame them. The only alternative I can see is removing the turbo, bolting up the stock exhaust manifold and returning the tune to stock. This seems inconvenient enough until you think about what you're going to do with the oil and water lines that go to the turbo.
My long term plan was to get this kit, but after a great deal of thought it seems like it might be a major ordeal to keep plates on the thing if I did.
Randoman5 is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
