Old 01-11-2014, 10:54 AM   #2605
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
It's certainly got the better of me over the last 4 months.
I am doing R&D with the agent in SA, whom is liaising with Sprintex. We were one of the first to get the new kit unfortunately.
I've had 2 specialist install the kit and check it out, both failed.
Since I've taken it off And understand how it works what to look for and what each component does,I and able to sort myself out. so as the saying goes, if you dot know how to fix your mods you don't know how to mod.
I am a little concerned with the Blue Gates belt on the 75mm pulley it might be too tight, so I'm going to go back to the standard belt, to ensure kit runs properly.
Also fair warning don't over tighten the Allen key bolts on the charger as those bolts are very thin and strip easy..
Ryan86 is offline   Reply With Quote
Old 01-11-2014, 11:21 AM   #2606
wrxgoose
WUB WUB
Drives: 2013 Firestorm
how tight is the blue gates belt? i had issues with the standard belt because my tensioner moved too much, so a tighter belt may be good, depending on how much your tensioner moves when you get on the gas.
and my friend who's gonna give me a hand wanted to know what kind of threading on that screw on the back.
wrxgoose is offline   Reply With Quote
Old 01-11-2014, 11:48 AM   #2607
Ryan86
Road Warrior
Ryan86's Avatar
What size pulley comes with your Innovate kits.
Sprintex standard 80mm pulley 65 mm idle pulley ( I must double check the idle pulley size)
IC add on 75 mm pulley 70mm idle pulley.
So with the IC pulleys the blue gates is a huge effort to get on compared to the standard belt. I went BG as I heard it does not slip, however it may not be good for the 75mm set up and more suited with a 70mm.
The above is my opinion whether accurate, I'm sure someone with more knowledge could advise.
Old 01-11-2014, 05:04 PM   #2608
xxscaxx
Drives: 2013 SWP BRZ
You need to teach me how to be patient like you.. lol.
This is why I ALWAYS do things myself. Now that you have pulled it apart, you know what you are doing and can take the time to do it yourself and not have to wait for a shop to figure it out, and on your dime.
xxscaxx is offline   Reply With Quote
Old 01-12-2014, 12:12 AM   #2609
whataboutbob
AutoX-10/10ths every run
Here's a photo of the brass fittings I referenced earlier from McMaster-Carr installed. The initial tube length is 2.5 inches. Should have the car on the road tomorrow.
Build thread:Here
Old 01-12-2014, 02:20 AM   #2610
TemeCal
Drives: 86
Originally Posted by whataboutbob View Post
I just wanted to provide some comment on the pulley stuff I posted.
I've been in contact with Innovate throughout the period of time when the pulley started making noise. In every case when I contacted them they were looking to solve the problem. Once we determined that a repack of the bearings wasn't the solution, they overnighted me a new pulley. I know of one other person who has had issues with the pulley and I suspect that given the type of driving that he and I do with our cars that we're pushing the pulley pretty hard. I am confident that Innovate will be working on figuring out what caused the failures and come up with a good solution to the problem.
FWIW, here's the bearing that comes in the pulley: Ntn 6203LU Single Row Ball Bearing: Amazon.com: Industrial & Scientific
At $7.21 each that's not to bad of a cost.
I recently developed a squeak when the car is cold. It sounds like it's coming from one of the pullies, so I'm assuming it's the idler pulley considering the issues some have had.
Mine squeaks only on the initial startup, when the car is cold. It squeaks for about 30sec, then it goes away. If I drive the car throughout the day, it won't squeak. If I leave it in the garage overnight, it'll squeak again on startup for 30sec. If it might be the pulley, would you chance it next weekend at the track?
What do you guys think? Idler pulley? I have a track event a week from Sunday, and am thinking of buying the bearing you mention above.
TemeCal is offline   Reply With Quote
Old 01-12-2014, 06:54 AM   #2611
Calum
That Guy
Drives: 2013 asphalt FRS MT
Are you sure its not the belt slipping?
Old 01-12-2014, 09:31 AM   #2612
whataboutbob
When my idler pulley started to go it did the same thing. You might order a new bearing.
Build thread:Here
Old 01-12-2014, 10:23 AM   #2613
TemeCal
Drives: 86
I don't think the belt is slipping, but I could be wrong. It's squealing at idle, then eventually silences.
Old 01-12-2014, 10:23 AM   #2614
TemeCal
Drives: 86
Thanks! I'll just get a bearing ordered, and have it installed prior to the track day.
Edit: Here is a video of what I'm talking about:
[ame="http://www.youtube.com/watch?v=tZ9uhi9G5ZU"]Idler pulley bearing? - YouTube[/ame]
Old 01-12-2014, 11:18 AM   #2615
Calum
That Guy
That's the bearing.
Old 01-12-2014, 12:44 PM   #2616
Ryan86
Road Warrior
Ryan86's Avatar
I wonder if the BG belt has not caused the bearing to go, as there is not much movement on the tension with the BG compared to the standard belt.
Mine sounds very simular with the BG on, change the belt and it's quiet. I'll try post a video clip.
Try change your belt back and check if the noise goes. Also if the bearing has gone you should be able to feel it if you wiggle the pulley with belt off.
Old 01-12-2014, 01:41 PM   #2617
TemeCal
Drives: 86
Thanks everyone. I've ordered 2 bearings. Hopefully they'll arrive in time for my track event. For now, I'll try swapping to the standard belt to see if that helps for now.
Appreciate all your input!
@mines13 @Innovate Motorsports - Is this a common issue? Sounds like many are having this problem. I certainly don't want to replace this bearing every few thousand miles. Are you guys working on a solution???
Old 01-12-2014, 02:41 PM   #2618
Calum
That Guy
A bearing is done long before you can feel play in it. The noise is a happy coincidence but it works perfectly as an indication that a bearing race or rolling element has started to flake off bits of metal. At the point that you can hear increased noise or vibration from a bearing, it's time to change it.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
