Old 07-31-2017, 09:43 PM   #2591
Jahris
Drives: 2013 Scion FRS
Originally Posted by phrosty View Post
Did you let the battery charge all the way before you flashed?
It is a brand new battery
Jahris is offline   Reply With Quote
Old 07-31-2017, 10:25 PM   #2592
steve99
Originally Posted by Jahris View Post
Wut up! I just replaced my dead battery with new and reglashed my EL E85 tune on the OFT.Now my a/c don't work and my ABS/Traction Control light is on...any thoughts would be kindly appreciated!
oft only flashes engine control module ECM , if the car starts flash is fine.
The other issues may be due to the body control or auto trans modules loising comns with engine ecm durung flash.
Oft onlt reads engine codes so it wont see or rest codes from other modules.
Remove a battery terminal for a few minutes, thus will reset all modules in car and you should be fine
Loss of battery power does not erase tunes
Old 07-31-2017, 10:28 PM   #2593
Jahris
oft knly flashes engine control module ECM , if the car starts flash is fine.
Thanks, but for some reason I turned off the the car for an hour then started back up and now lights off and a/c on! Yay for me! Thanks agaien fellas your time, thoughts and efforts! Much appreciated, BIG UPS TO YALL!
Old 07-31-2017, 10:37 PM   #2594
steve99
Yeah the other modules in car likely had a hissy fit, abd have now calmed down and are talking, hapoens somtimes when reflashing as ecm goes offline during flash, other modules get upset
Jahris (07-31-2017)
Old 08-01-2017, 01:03 AM   #2595
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
That happened to me too once. But I was fiddling with the OFT trying to plug it in the OBDII port while I just started my car. I think it caused it to go into some kind of safe mode or something. My A/C wasn't working although everything else seemed like it was working just fine. I drove for like 2 min realizing I wasn't blowing any cold air, turned it off for 30 sec or so, turned it back on and the a/c was working again. *sigh of relief* it was a hot day in Arizona and I was glad it was just some little quirk.
chazmuska is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
