go_a_way1
Old 07-08-2015, 03:21 PM   #2577
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by Xiao Li View Post
As for exhaust, would anything pass the headers still be able to safely run the CARB tune? I know changing out the headers will most likely need a retune.
Catback on the car is fine to run with the CARB Calibration.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
CSG Mike (07-08-2015)
Old 07-08-2015, 03:35 PM   #2578
Xiao Li
Xiao Li's Avatar
Drives: '14 BRZ, '01 S2K
I'm just a worry-wart. I spent two days on the SC install just because I kept checking and rechecking as I go. I'm still popping the hood every other day to check the oil and the clamps on the lines/piping lol.
Xiao Li is offline   Reply With Quote
The Following User Says Thank You to Xiao Li For This Useful Post:
Old 07-08-2015, 03:45 PM   #2579
JDMChris
Drives: 2016
Thats good! Make sure everything is right the first time!
Old 07-08-2015, 03:55 PM   #2580
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
What about a front/over pipe and mid-pipe? I'm guessing not having a secondary cat or even having a high-flow one would affect it?
Old 07-08-2015, 03:56 PM   #2581
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
I have an Invidia overpipe and catless resonated front pipe as well as my Q300. I haven't completed my JRSC install yet, but it should be fine on the CARB tune, no?
keithr is offline   Reply With Quote
Old 07-08-2015, 04:07 PM   #2582
JDMChris
Drives: 2016
If you are missing any cat's you cannot run the CARB tune.
Old 07-08-2015, 04:36 PM   #2583
Not having a secondary cat means you would fail visual inspection.
Old 07-09-2015, 12:42 AM   #2584
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by dkstylezz View Post
Thanks Took the trip down and got the tune and the 11psi map sensor. I can already feel the change while i was driving back home.
We would love to hear your full review on our pure speed density tune versus the well proven CARB tune from Jackson.
Cheers,
William Knose
Old 07-09-2015, 11:48 AM   #2585
fasteddy
Cheers,
William Knose
I would love to hear more about this as well!
Pat
fasteddy is offline   Reply With Quote
Old 07-09-2015, 02:04 PM   #2586
Xuningshen
Drives: Subaru BRZ
I just installed my 11psi map sensor and flashed the DT tune on monday. came from the CARB tune. I think the pedal has finally undeadened itself 100%.
Under 3.5k its almost as smooth as the carb tune. Above, especially 5k+ it I feels stronger, like it pulls harder. This is just my initial butt dyno impressions of driving to and from work, and then up and down 10 miles of PCH after work.
If you've read any of my previous posts, I've had fuel trim issues. They're mostly gone. STFT and LTFT is a lot more stable under throttle/load. I must have a vacuum leak somewhere... because it runs hella rich at idle. gahh.. gotta figure it out still...
The Flash and go tune comes with 1 free tweak/revision within 10 days of purchase so I was going to send a log their way and see what happens. Main reason for switching is planning on getting headers + flex fuel kit and retune thru Delicious tuning.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following 3 Users Say Thank You to Xuningshen For This Useful Post:
CSG Mike (07-09-2015), dj2020 (07-09-2015), SPCorBUST (07-09-2015)
Old 07-09-2015, 08:27 PM   #2587
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Getting a leak on the bottom Setrab oil cooler hose connections. Any suggestions here? Is the hose on far enough?
https://m.flickr.com/#/photos/bramick/18942082993/
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 07-10-2015, 09:25 AM   #2588
Bramick
Bramick's Avatar
Tightening it down a bit more did the trick.
The Following User Says Thank You to Bramick For This Useful Post:
CSG Mike (07-10-2015)
Old 07-10-2015, 12:58 PM   #2589
Make sure to check your Rotrex fluid levels.
Old 07-10-2015, 01:33 PM   #2590
Bramick
Bramick's Avatar
They are right on the max line. I considered removing a bit.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
