#2535 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Who has successfully moved their thermostat/ outside thermometer sensor with this kit and oil cooler? To where and pictures please? Yes I would like mine to work and be close to accurately having the correct temperature outside. Sorry but it was not 119 in Salem today, 100 but not 119. Thanks in advance. We did attempt to move it as for to the passenger side as possible
#2536 |
Drives: 13 GBS BRZ
#2538 | |
Drives: 13 GBS BRZ
http://www.ft86club.com/forums/showthread.php?t=59253 |
#2540 | |
http://www.ft86club.com/forums/showp...postcount=2136 I have no idea why my picture attachments are not showing up though but I think my description describes exactly what I did fairly decently. I'm typically reading within 3 degrees of what my geolocation weather app says even in 110 degree Vegas heat after the temp sensor relocation and techstream temp adjustment. |
| The Following User Says Thank You to dj2020 For This Useful Post: | Jmonty (07-04-2015) |
#2541 |
Drives: '14 BRZ, '01 S2K
Just finished installing my kit today and I cannot get the driver side tabs under the headlights to pop in all the way. The foglamp housing is the culprit for sure and I tried moving the piping around. I got it to be okay but it's not perfect. Is this a common issue?
#2542 |
Drives: 2013 BRZ Limited M/T
I hear the EcuTek carb tune is supposed to come with 2 pages of install instructions. Anyone know where to find it? I'm searching but not luck so far.
My instructions where not included. |
#2543 | |
Drives: 2015 Series.Blue BRZ
#2544 | |
Bumper re-installation alone is one of the major reasons why professional installation can be cheaper than a DIY installation; replacing that front bumper and clips due to damage caused during bumper removal can be expensive. |
#2545 |
You should have 2 pages stapled together that is included, but separate, with EcuTek instructions. If you can't find it I can scan it for you when I get back from the track tonight.
#2546 |
Yep wasn't included. Thank you.
#2547 |
Hook everything up, install software.
Go through the menus, and select "apply license update" and select the default file, then hit ok. Then auto-detect ECU, and then select Program ECU. On the next screen, select your CARB tune (appropriate for year and transmission), and hit program ECU. Follow on-screen prompts, and you should be good to go. -Mike |
#2548 |
Under Help/Features and License info should it say Remaining Flashes 0?
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
