Old 06-15-2015, 12:36 AM   #2535
STV3
Señor Member
STV3's Avatar
Originally Posted by FRSBRZGT86FAN View Post
I'm guessing you don't know much about the car, because a tune is a surefire way to pass emissions as long as a sniffer is not involved, the tune is for getting rid of the risk of a CEL.....
STV3 is offline
The Following 2 Users Say Thank You to STV3 For This Useful Post:
akahenry (06-15-2015), FRSBRZGT86FAN (06-15-2015)
Old 06-15-2015, 12:29 PM   #2536
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Originally Posted by FT-86 SpeedFactory View Post
We stand behind our product and to date, there has been two cat actual cat failures. Both of those we replaced under our warranty.
Just chiming in. I have been running a TRD intake & catback, FT86SF UEL Catted Header and OFT Stage 1 UEL tune for nearly 14,000 miles. From time to time I would get a P0420 reading and I brought the car into the install shop for a quick safety check. No issue was found. After said point, I simply cleared the code manually each time it popped up.
Lately, I have been getting the CEL P0420 on an almost weekly basis. Out of sheer annoyance I am planning to use ROMRaider to flip that switch off, however I worry that I could miss an actual problem should the cat fail, a sensor go bad, etc. What would you recommend? This is my first "tuner car"...
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline
Old 06-15-2015, 04:23 PM   #2537
chas3wba0
chas3wba0's Avatar
Drives: Yes
Just do it. You'll be able to smell/feel a difference if the cat were to actually fail (worst case, the exhaust would be "clogged", hurting performance)
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
Old 06-15-2015, 05:10 PM   #2538
Re~Mix
Re~Mix's Avatar
Thanks for the vote of confidence. When you say smell, it should be an exhaust smell, appearance or feel and not gasoline? For some reason I have been smelling gas some morning when I start the car, wrote it off as closed quarters (driveway between two adjacent houses).
15' 228i MSport
Re~Mix is offline
Old 06-15-2015, 07:27 PM   #2539
chas3wba0
chas3wba0's Avatar
Drives: Yes
I was smelling a bit more of a "gassy" smell as well after I swapped out the factory cats (still have 2 cats: the FT86SF header and a Berk front pipe), which I presume is normal.
The P0420 code was coming on way too frequently for me (all I had was OFT, exhaust and intake hose), and I hated having to deal with the mushy pedal each time I cleared the code, so I finally went into RomRaider and disabled it... haven't slept better since.
The Following User Says Thank You to chas3wba0 For This Useful Post:
Re~Mix (06-15-2015)
Old 06-15-2015, 10:56 PM   #2540
steve99
Disabling the P0420 cel code does not disable either of the 02 sensors. All it disables is the triggering of the P0420 cel code. The ecu does some weird calculation based on readings from both 02 sensors to determine cat efficiency if it get results outside "normal" it sets the p0420 code.
The front sensor is used for afr by ecu, rear 02 for cat efficiency, cruise fueling
you will still trigger other codes if 02 sensors fail or fueling falls outside predetermined limits
steve99 is offline
The Following 3 Users Say Thank You to steve99 For This Useful Post:
AllStar0419 (07-21-2015), Mr.Impreza (03-20-2016), Re~Mix (06-16-2015)
Old 06-16-2015, 11:11 AM   #2541
DGM86
Drives: 15 BRZ, 07 Tacoma TRD, 01 Miata SE
I'm guessing you don't know much about the car, because a tune is a surefire way to pass emissions as long as a sniffer is not involved, the tune is for getting rid of the risk of a CEL.....sarcasm...
I was under the impression that disabling the CEL would cause the ECU to not run its readiness checks. You would fail the inspection due to that even though you are not throwing a CEL. Tuning them out doesn't turn them off it just tells them to shut up. That was the case for my previous car at least, but I was running megasquirt in parallel, so its a bit different.
If you can tune out CELs with OFT on these cars and not hinder the ECU readiness checks, i'm going to be thrilled.
DGM86 is offline
Old 06-16-2015, 01:23 PM   #2542
Courier6
Courier6's Avatar
Drives: 2015 FR-S Release 1.0
Originally Posted by DGM86 View Post
You are forgetting, some of us live in states where you will not pass inspection with most any CEL being thrown. Suppressing the CEL makes the ECU show a forced readiness situation and it wont pass. Throwing the guy inspecting your car a 50 doesn't work either because the computer they use to check your ECU is owned by the state. It sucks. If anyone knows a way around it that doesn't involve swapping parts back and forth, I would love to hear it. THAT is the market for these headers... why would you get a catted header otherwise?
I got my catted header and headerback to kill the torque dip (which it does quite well) and replace the uninspiring noises made by the stock car, while not needing a tune whatsoever. I never expected big gains, but the low and midrange gains were noticeable, more so than I thought they would at least. Truth is, even with a tune the gains you will see won't really be worth the money unless you can run E85, which I can't get near me.
Are you still running the header without a tune? I would like to know if you've seen a CEL yet.
thanks!
Courier6 is offline
Old 06-18-2015, 04:46 PM   #2543
DGM86
thanks!
Been running the header-back for about 2 months now with no CEL and no tune. That's about 4-5k miles with how much I drive (mostly highway). Its the full daily rage package on FT86SF's website. My intake is stock though and I suspect most of the people getting the intermittent highway CEL's with this header are running full aftermarket intakes.
Might want to stay with the stock intake or just run a drop in filter if you are worried about a CEL. Trying to decide if I want to test my luck with the Grimmspeed intake, which supposedly doesn't require a tune, but the more mods you have the higher the chances of a CEL.
DGM86 is offline
Old 06-23-2015, 04:05 PM   #2544
FTemplar
Drives: BRZ Sport-tech 2013
Hey guys, just installed it and thought I should share the video we made this week-end. I didn't launch WOT because I wanted to see how it sounded like driving normally.
FT86 UEL catted header + Lachute Performance catback
https://www.facebook.com/715671437/v...8/?pnref=story
FTemplar is offline
Old 06-24-2015, 10:01 PM   #2545
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
You're just lucky, I had the cel with the stock intake.
Cartman is offline
Old 07-13-2015, 05:24 PM   #2546
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Getting ready for Ultimate Track Car challenge at VIR later this week!
We have these in stock at the moment too!
FT-86 SpeedFactory is offline
Old 07-14-2015, 12:03 AM   #2547
Thehermdawg
Just Some Dude
Thehermdawg's Avatar
Drives: 14 FR-S Raven A/T
From all the videos I've seen, I haven't heard all that much rumble from this header. Maybe a little, but it's almost like an EL to me. Of course, videos don't really do justice. So how is the rumble?
2014 Scion FR-S Raven A/T (AKA the Sex Panther)
MODS: Berk Muffler Delete Track Pipe, HKS Drop-in Filter, Yospeed Center Console Plaque, Raceseng Shift Knob, Enkei Kojin wheels.
And stickers. Lots of them.
Originally Posted by Rocket.BRZ View Post
But the party has just begun.
Thehermdawg is offline
Old 07-14-2015, 11:24 AM   #2548
FTemplar
The rumble is at its best when WOT between 2000 and 3000 (for me) particularly in 2nd, 3rd and 4th gear, but you kind of lose it in 5th and 6th (in the driver's seat, not from another car's perspective... if you ask someone to drive next to your car in 6th on the highway, it's definitely noticable)
CEL disapeared as fast as it showed up for me, within 24 hours it was gone. I have a an aftermarket catback and K&N Drop-In air filter. It's UEL is 6 inches difference, not the most UEL there is, but I like it.
FTemplar is offline
The Following User Says Thank You to FTemplar For This Useful Post:
Thehermdawg (07-14-2015)
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
