Southern California SoCal
Old 07-08-2015, 08:17 PM   #239
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Originally Posted by JEDI View Post
I'm sooooo jealous!! Looks like it's coming together quite well. Now ya need a big ass rear view mirror to keep an eye out for the police and peeps trying to keep up!
i like my homelink mirror since it has auto dim. i just cant justify
the price of the frameless mirror w/ auto dim.. too much $$ for its purpose..
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 07-11-2015, 04:36 AM   #240
starron
Drives: FRS 10 Series
I am having some trouble with my rear camera install...
in order for the rear camera to work, I MUST start my car with reverse gear... the head unit doesn't seem to react to the camera when I start my car in neutral.
do you guys have this problem???
starron is offline   Reply With Quote
Old 07-11-2015, 01:55 PM   #241
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
did you make sure all your connections are secure and correct?
Flex Fuel Turbo BRZ
Old 07-11-2015, 02:41 PM   #242
starron
It happens every time. Although my wiring a little bit different from other guides online but that doesn't explain why I can only get it to work when I start the car in reverse gear
For camera power I actuary tap it to the reverse trigger, so it's not getting power when it's not in reverse. I tried to use an external 12v source to test it out and the result is the same.
For trigger I tap it to the 5th slot pink wire in the kick panel harness. It trigger signal should work every time since I can see my reverse light.
My conclusion is the head unit must have the trigger engaged when starting it up in order for it to work properly. Let me try to shoot a video to show you now exactly it looks
Old 07-11-2015, 03:24 PM   #243
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
When's the next diy day? Doesn't need to be a diy day but some help on brake fluid and lines would be great!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 07-11-2015, 04:18 PM   #244
starron
I just read a post about taping the camera power to reverse light, the head unit will not detect the camera if it's not start on reverse gear.
http://www.ft86club.com/forums/showt...ght=Rydeen+duo
but pictures are no longer available and I don't know which camera power i should connect it to...
any suggestion?
Old 07-11-2015, 04:44 PM   #245
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
i can assist you once my turbo is finished LOL ( i been saying that a lot)
but in all jokes aside i should be done this tuesday so i can maybe help you next sunday
Flex Fuel Turbo BRZ
Old 07-11-2015, 04:45 PM   #246
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
any suggestion?
maybe @LXXXV1 can chime in?
Flex Fuel Turbo BRZ
Old 07-11-2015, 04:56 PM   #247
FRS Johnny
FRS Johnny's Avatar
Sounds good, I'm only free in the afternoon on Sunday's if thats okay. I'm free other days during the week at certain times as well.
Old 07-11-2015, 04:57 PM   #248
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
im off every tuesday so i can help you as well.
maybe next tuesday or so.
Flex Fuel Turbo BRZ
Old 07-11-2015, 11:35 PM   #249
FRS Johnny
FRS Johnny's Avatar
I'm free tuesday morning/ early afternoon. I have work at 3, so I'll need to be done by 1:30
Old 07-12-2015, 10:23 AM   #250
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Brake lines shouldnf take too long just come early to.give.us time for chill as well
Flex Fuel Turbo BRZ
Old 07-12-2015, 02:54 PM   #251
FRS Johnny
FRS Johnny's Avatar
Sounds good! How's 10 o'clock?
Old 07-12-2015, 03:04 PM   #252
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
ill pm you once i know I'm free..
Flex Fuel Turbo BRZ
