Old 04-21-2014, 05:40 PM   #239
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Mine finally shipped, ~6AM April 20th Hong Kong time, order placed on April 11th. Looks like they're taking a bit longer to ship out now. Good news is it's in Ohio already.
Prog is offline   Reply With Quote
Old 04-21-2014, 08:28 PM   #240
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by milhouse View Post
Is anyone using this with an OEM AudioPlus system? And in a BRZ? I'm considering it but I want to make sure it works together...
I don't have the oem audio plus - but it will work, I looked through their guide and its nothing this wouldn't handle.
probably would sound better too.
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 04-21-2014, 08:30 PM   #241
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by DC2R View Post
Just pulled trigger. Hopefully all plug and play for 2014 FR-Swith bespoke unit. Didn't order anything other than radio. Don't mind losing radio, aux. I may install a usb hub so stock port would not be used either
Sent from my GT-N5110 using Tapatalk
Honestly speaking - i'd get the antenna adapter at bare minimum. That said it'll be fantastic without any of that stuff anyways.
Pulled mine this weekend to re-route the USB and iPod a bit cleaner. Also ran my OBD2 extension cable over to the glovebox so that the bluetooth reader can be left in all the time without having to worry about it sticking out of the dash. Cool!
Andrew
The Following User Says Thank You to SHIFTER For This Useful Post:
DC2R (04-22-2014)
Old 04-21-2014, 09:09 PM   #242
DC2R
Drives: 2014 Scion FR-S
Originally Posted by Prog View Post
I know jack shit about audio and was just gonna use the single out with a splitter. Didn't realize there was another possible option.
I mean you could use the left and right audio out but then the sub amp would be responsible for filtering out the highs. I'm currently tapping into the rear stock amp for signal so I know anything I do will be an improvement.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 04-22-2014, 08:09 AM   #243
xjohnx
Grip>Slip
xjohnx's Avatar
What is everyone doing for subwoofers? Don't know if I should use the single out and split it via an adapter or use two of the regular rca outs and utilize my powered subwoofers built-in crossover....
OEM Audio Plus here
Old 04-22-2014, 08:10 AM   #244
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Deathalo View Post
The fact that it only works with phones wouldn't be an issue for tethering anyway, that's where we want the tethering from....
It is though, currently the head unit only supports the A2DP (Calls, audio streaming), AVRCP profiles (remote control) and OBD2 adapters (probably a SPP or serial port profile) over bluetooth. It does not support the tethering profile. You're stuck with wifi as you only choice there. It would need the DUN or LAP profiles to handle tethering via bluetooth.
Old 04-22-2014, 11:36 AM   #245
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Can that be fixed through root though.
Deathalo is offline   Reply With Quote
Old 04-22-2014, 11:55 AM   #246
DC2R
Good idea. I should use this opportunity to reroute my obd2 extension to glove. Should be perfect for dongle and Open Flash Tablet when needed. Not sure how I want to use usb but from what it sounds like we can only use it for storage.
Old 04-22-2014, 12:11 PM   #247
xjohnx
Grip>Slip
xjohnx's Avatar
Possibly, however it could be a hardware limitation as the guys on xda-devs mentioned with the generic 4.1.1 android unit with almost identical specs to the CaFi. The first step to finding out would be to gaining root access.
Old 04-22-2014, 02:10 PM   #248
mid_life_crisis
Drives: FR-S 10 #103 AT
I wouldn't buy this because it doesn't play CDs.
I started out with an 8-track player in my car, then cassettes, then CDs, now those are becoming obsolete.
Feels like if I were just a little older I could have talked God out of making the mosquitoes.
Old 04-22-2014, 02:28 PM   #249
xjohnx
Grip>Slip
xjohnx's Avatar
You just dated yourself, and I'm going to have to call BS on the "Mid_life" portion of your username.
The Following User Says Thank You to xjohnx For This Useful Post:
Prog (04-22-2014)
Old 04-22-2014, 02:34 PM   #250
Prog
Prog's Avatar
People still use CDs in their car?
When you can - with the click of a button - rip a CD, then put that CD, as well as hundreds of your other favorite albums on a thumb drive, why would you ever limit yourself to a medium that can't even hold over 80 minutes of audio?
Old 04-22-2014, 02:53 PM   #251
mid_life_crisis
I did my first car stereo upgrade when I was 17. Cassettes were well established, but I had an 8-track collection I got from older siblings and everything I put in the car had to come from a discount rack, so 8-tracks it was.
A Craig (remember them?) under dash unit with a whopping 15 watts per channel in simulated quadraphonic sound with an FM tuner built in (lots of cars then had just an AM tuner from the factory) and I forget what the speakers were. Probably Craig or Jensen, which by today's standards were crap but were so far beyond anything you could get from the factory at the time that they sounded amazing.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
xjohnx (04-22-2014)
Old 04-22-2014, 02:57 PM   #252
mid_life_crisis
Because if you rip them for max sound quality, they fill up a thumbdrive in a hurry.
It's easier to just grab a few disks on my way out the door.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
