#239 |
Drives: 2005 Toyota Camry
#240 |
Drives: GT86 Cosworth
Well these are might impressive for the level of comfort they offer. Currently on 10 clicks which I preferred to 15 clicks. I noticed that on 10 clicks it is less understeer biased than 15 clicks. I'm running 400lb/in springs on the back though.
Got a track day in February to properly stretch their legs. |
#241 |
Drives: '22 BRZ
I too bumped my stiffness up from 15 clicks. 12/13 f/r. I might go a bit stiffer, too.
My winter tires have almost no sidewall stiffness so when I hit a bump I can feel a hit when the tire hits, then another jolt when it loads the suspension. I noticed the same with the OEM suspension but it was obviously a LOT softer. I've noticed that the car pretty much doesn't understeer anymore. It's really hard to judge much on the winter tires though, they're so mushy. |
#242 |
Drives: Lightning Red
They're quality stuff..can't go wrong with them for all applications....
#243 |
Drives: White 86
Found out from Prospeed here in Aus that the 60/60 N/mm kits with camber tops are no longer available. Instead, they are selling 40/40 (different to the 40/30 reported here previously?) without camber tops.
However you can order springs with custom rates to suit at a very reasonable price, and at a discount when purchased with the coils. Want to pick up a set soon. Any recommendations on what spring rates suit? 60/60 like the old set or maybe stiffer perhaps? |
#244 |
Will the dampers be revalved to match? Otherwise I wouldnt deviate from standard rates more than 25%
Sent from my GT-I9300 using Tapatalk |
#245 | |
Drives: White 86
Would I be right to assume the shock valve specs haven't changed between the old and new kits? If so I may just stick to the old kit's 60/60 |
#246 |
Im pretty sure it will have. Going 50% softer spring rate will mean it will be overdamped if they dont soften the damping
#247 |
Drives: White 86
Mmm I think you are right, but I have reached out to Ohlins to confirm for everyone.
#248 |
Drives: FR-S Whiteout
While you're at it, you can tell them people on forum want the old setup and maybe you can at least get an explanation why they changed them up so drastically.
Intent > Content
cowardice is the mother of cruelty. |
#249 |
MaximT was supposed to get one. Never did. Maybe Ohlins USA will be more forthcoming...
#250 |
I'd love to know thier reasoning behind the softer rates. These dampers have limited stroke as it is and judging by the preload they run on those soft spring rates, the new kit is no better.....
#251 |
Drives: '15 BRZ RA
New specifications in Germany are also : 40N/mm front, 30N/mm rear. Very strange.
By the way, does anyone know how much lighter are they comparing to the OEM suspension? |
#252 |
There is a thread (this one?) Where they got weighed
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 05:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 12:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 04:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 03:27 PM |
