| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#239 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
My car used to intake backfire during start up during cold starts, hasn't done it in a couple months though... Hmmm
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#240 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | AsianStyle (08-07-2013) |
#241 |
Drives: Whiteout FR-S MT
#242 |
#243 |
Drives: 86 (FR-S)
I think it's funny the people who were blaming aftermarket tunes for the problem... it now being the only real way to solve the problem.
| The Following User Says Thank You to Jeff86 For This Useful Post: | Tim_Asphalt_FRS (08-07-2013) |
#244 |
Tuning your ECU fixes the software issues and prolongs the engine life, but gets engine warranty denied. Blown engine because of "abuse" but can be replicated readily like getting onto the freeway, also denies engine warranty...
#245 |
Drives: 86
Interesting numbers so far. Not very good for Subaru...
TOYOTA 1 out of 18 reported cases denied (5.5% denied) SUBARU 4 of out 6 reported cases denied (66.6% denied) |
#246 | ||
I replaced my seals this week, #1 was gone Never been to a track or even know how to race, just drove the car in its power band. We need to find a tuner who can shorten the closed loop to open loop delay, help with the oil temps, fill in the TIR tables, and do whatever else is necessary to prevent any detonation which destroys these fragile rods/bearings. Until then I will be keeping her under 5k rpm. Anyone who intends to keep their car for more than 30k miles should do the same.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
| The Following User Says Thank You to regal For This Useful Post: | Muaddib (08-08-2013) |
#247 | |
I Love custom Turbo kits
Drives: Limited BRZ
So there's cars running 12K + miles turboed at 400 + whp and you say the motor is stretched to its limits from factory?? Did I misunderstood?
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | SkAsphalt (08-08-2013) |
#248 | |
The rest of the drivetrain is not designed to handle anywhere near that much torque. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Sportsguy83 (08-08-2013) |
#249 | |
Drives: Limited BRZ
So yes it depends on usage, but the claim the motor is stretched to its limits from factory is a bit too much IMHO, maybe I'm wrong.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | lexusb3 (08-08-2013) |
#250 | |
In NA form the factory tune is stretched to its limits with the 12.5 C.R. and pump gas. The factory tune is by no means conservative. The oil temperatures sore under load, the thing has way too many knock events, stays in closed loop too long, etc. A 12k mile aftermarket turbo'd FA20 is a different animal, but since you mention it do note that Subaru has completely dropped the D4-S FA20 in favor of their FA20T, they made that decision before the BRZ was even released. What does that tell you ?
| The Following 2 Users Say Thank You to regal For This Useful Post: | CSG Mike (08-08-2013), Sportsguy83 (08-08-2013) |
#251 | |
Drives: Limited BRZ
#252 | |
Drives: GR86
I agree with your first point. But you are on a slippery slope with the second point. Their decision to not use the D-4S tells me that they probably were not licensed to use it on a different model car. This car is a joint venture project with Toyota. When companies do joint ventures car components are shared for those car models, not other models. So Subaru probably liked the concept of DI and decided to make their own version with the knowledge Toyota shared, but they were not able to use Toyota's system. Also I would predict they would have to pay royalties to Toyota in order to use their system if it transferred to a different model car. |
| The Following 4 Users Say Thank You to Stevo22 For This Useful Post: | MightyMeeple (08-08-2013), NickFRS (09-05-2013), Sportsguy83 (08-08-2013), strat61caster (08-09-2013) |
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 07:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 01:25 PM |
