Old 06-12-2013, 04:57 AM   #239
rx3
What you mean by you can hear it detonate?
Detonation usually makes a pinging sound (sort of like a small ringing bell) which you can hear when you step on the throttle (not lift the throttle).
rx3 is offline   Reply With Quote
Old 06-12-2013, 08:30 AM   #240
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
You are confusing Pre-Ignition with Detonation. Pre-Ignition (a/k/a Knocking) occurs when there are hot spots in the combustion chamber from either carbon deposits or too hot a sparkplug range. It is annoying but largely non-distructive. It's sounds like pinging.
Detonation is erratic combustion that occurs in the compression stroke. It is destructive. A "mild" case will cause head gasket or sparkplug failure. A severe case will bend connecting rods or destroy pistons. It too sounds like pinging, but it also feels like the power has been cut in half...like someone has tied a 2,000 pound weight to the bumper.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 06-12-2013, 08:41 AM   #241
2forme
Originally Posted by 2forme View Post
I don't think this is directly related to shifting. I've seen this problem first hand on a friends BRZ, and he has never shifted aggressively. Never tracked the car, either. He has a stick, though.
Originally Posted by Tainen View Post
it is related to shifting. After I put my headers on, I can hear the car detonate when I lift throttle over 6k rpm or so. Couldn't hear it before.
Not necessarily. Your case, perhaps. But not always.
Old 06-12-2013, 10:31 AM   #242
OrbitalEllipses
Drives: Attitude
>:[ no more power mods til this crap is figured out.
Old 06-12-2013, 10:47 AM   #243
ft_sjo
Drives: GT86
It is figured out. What's wrong with you people? Desperate for something to chat shit about?
The Following User Says Thank You to ft_sjo For This Useful Post:
whitefrs (06-12-2013)
Old 06-12-2013, 10:49 AM   #244
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Im not sure if u are being sarcastic or serious
The Following User Says Thank You to whitefrs For This Useful Post:
vgi (06-12-2013)
Old 06-12-2013, 11:42 AM   #245
OrbitalEllipses
Drives: Attitude
What's your deal, dipstick?
Let me amend my statement: no more power mods until SUBARU acknowledges there is a problem and INSTATES a fix for vehicles that have been out in the wild that do not have a fix from the factory.
Thank, please GFY.
Old 06-12-2013, 11:49 AM   #246
ft_sjo
Drives: GT86
@OrbitalEllipses Please explain to us all what relevance engine power has to do with a transient det problem?
Old 06-12-2013, 12:55 PM   #247
rx3
If I remember correctly, someone also mentioned bad fuel as his cause for seal failure (which usually would be taken care of by a knock sensor and should not cause any parts to melt away).
Anyway, I guess one question would be if there was a single case of seal failure after they installed this ROM revision?
http://www.ft86club.com/forums/showthread.php?t=37411
However, since most people have this ROM revision not installed, the probability of finding one with a seal failure would be very slim, even if there was still a chance of dealing with detonation after installing this ROM revision (since so far much less than 1% of all cars seem to be affected by this problem).
Btw, how would one get to this ROM revision anyway? Does one need to go to a dealer and specifically ask for it? Do they even know about this problem on a global level?
PS: Increasing power requires an increase of pressure in the combustion chamber and since p*V = n*R*T, going FI does at least increase the risk of detonation.
The Following User Says Thank You to rx3 For This Useful Post:
Jeff86 (06-12-2013)
Old 06-12-2013, 12:55 PM   #248
TemeCal
Drives: 86
While this most likely has nothing to do with power mods, I tend to agree with @OrbitalEllipses . It is a major pain, having to fight Toyota (in my case) because I have exhaust, or intake, or tune. The first thing they want to do, is blame the mods.
Having to remove these mods before taking it to a dealer, becomes painful too. I am looking to go FI, but am holding off as well. Not because I think these mods will accelerate the issue. I just don't want to deal with warranty work being denied because they don't know what's going on. I personally would rather Toyota/Subaru get things fixed/corrected, before I continue with my power mods.
EDIT: And just to be clear, I have had this issue. The dealer blamed my intake tube, and denied warranty. I had to fight them, and they eventually got the okay from Toyota to rip into it further. They quickly found 2 bad injectors/collars which were replaced under warranty. Had I known it would be such a fight with them over the intake, I would have removed the stupid thing before taking it in.
TemeCal is offline   Reply With Quote
The Following 2 Users Say Thank You to TemeCal For This Useful Post:
OrbitalEllipses (06-12-2013), vgi (06-13-2013)
Old 06-12-2013, 01:10 PM   #249
OrbitalEllipses
Drives: Attitude
Exactly what @TemeCal said...warranty consideration. TSB don't mean squat to an unfriendly dealership. Given the chance to deny warranty claims, they will deny the claim as it's their favorite thing to do.
Old 06-12-2013, 01:45 PM   #250
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I don't believe "it is figured out" can honestly be said yet. A culprit has been identified, yes, but the failing part in question I don't believe is a particularly good design. Seal failure for a variety of reasons is entirely possible.
Jeff86 is offline   Reply With Quote
Old 06-12-2013, 01:51 PM   #251
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
My check engine light has come up a few times, and from time to time I can smell gas fumes from the engine compartment.
So I called my dealer, theres no TSB on there system for this. But the SM told me to bring it in Monday to have it checked and get it fixed right away so I guess well see what happens/
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 06-12-2013, 01:57 PM   #252
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
in for a good read later.
TouchMyHonda is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 01:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 04:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
