Old 10-29-2015, 10:17 AM   #239
JarredH
JarredH's Avatar
Drives: Scion frs
Picked up a set of +45 17x9s.
Stock brakes
Stock suspension
I will be buying coilovers and LCAs
I wish to run max -0.5 camber. I want to stay in spec
What do you suggest I run for tires with a mild 1.5 inch drop so I do not rub at all?
JarredH is offline   Reply With Quote
Old 10-29-2015, 07:31 PM   #240
learnerspermit
learnerspermit's Avatar
Drives: C-17A
Originally Posted by BlaineWasHere View Post
You'll need coilovers for spring clearance. Lower offset will help like 35-40
So this will clear stock with a +35 and that tire? So its the barrel that is the issue on the 17's not the tire I get it now Thanks
learnerspermit is offline   Reply With Quote
Old 10-29-2015, 09:41 PM   #241
icybrzzz
Drives: 2015 Scion frz
I'm running 17x9 +35 offset with 245/40/17 Michelin Pilot super sport on my 2015 brz with no rubbing issues at all.
Fitment is good but I need to lower it now. Wheel gap is killing me inside
icybrzzz is offline   Reply With Quote
Old 11-13-2015, 08:35 PM   #242
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Originally Posted by bryan767 View Post
Some tires are wider then others, even if they are the same spec.
Mine were touching the spring perch on eibach pro springs.
Since I went with coilovers I have 0 need for any spacers, however I am running a 3mm spacer in the rear just because I like the look.
Wow, your car is beautiful! Very tastefully put together.
BTW what did you use for center caps?
smg1138 is offline   Reply With Quote
Old 11-14-2015, 06:45 PM   #243
carlovestela
Drives: 2015 Firestorm FRS
Why you guys like 245/40? You cant buy 215/40 or 225/40?
carlovestela is offline   Reply With Quote
Old 11-14-2015, 07:25 PM   #244
Mr_Hann
Mr_Hann's Avatar
Drives: 2015 Steel FR-S
You can certainly buy tires in those sizes, but 245/40 is the size closest to the OEM rolling diameter. Changing tire size changes gearing, and both 215/40 and 225/40 would be smaller than stock, lowering (I believe) your gear ratio.
End result is the car would accelerate quicker, but at the expense of higher RPMs for any given speed and selected gear, and a lower overall top speed.
Say you're crushing at 2k rpm in 6th at 55 mph. With a smaller tire, 6th gear 55 mph may be 2300 rpm instead. Just an example, I pulled the numbers out of the air.
Mr_Hann is offline   Reply With Quote
Old 11-14-2015, 08:14 PM   #245
churchx
churchx's Avatar
Drives: 2014 GT86
I might be wrong, but IIRC only 275/35 is equal to stock 215/45. 245/40R17 is +0.4% diameter.
But as another stock size for lower trims of toyobarus at some markets with 16" of 205/55R16 differs from stock 17" tire circumference of +1.22%, imho such slight difference isn't THAT important. Even more so that some willingly install different gearing ratio FD to enhance acceleration on these cars.
-2% 225/40R17 = 24.1x8.9R17
-1.2% 205/45R17 = 24.3x8.1R17 +
-0.8% 235/40R17 = 24.4x9.3R17
275/35R17 = 24.6x10.8R17 215/45R17 = 24.6X8.46R17 Diameter = 24.6" Width = 8.46" Wheel = 17" Sidewall = 3.81" Circumference = 77.3" Revs/Mile = 819.7
+0.4% 245/40R17 = 24.7x9.7R17
+1.6% 225/45R17 = 25x8.9R17
+2% 205/50R17 = 25.1x8.1R17
205/55R16 = 24.9X8.07R16 Diameter = 24.9" Width = 8.07" Wheel = 16" Sidewall = 4.44" Circumference = 78.1" Revs/Mile = 811.1
I wouldn't go for too wide for different reasons though, like not wishing to change character of handling while still not forced induction power levels, not requiring to invest much in suspension, cheaper tires, no need to buy wide rims, not having extra rotational unsprung weight added from those wide rims & wide tires, and in such light 215 or 225 looks more reasonable then 245 or even wider ones.
Old 11-14-2015, 10:00 PM   #246
carlovestela
What if i dont change my wheels and suspension at all. Like stock. Can i go 245/40 or 215/40?
Btw what is wheel offset?
Old 11-15-2015, 05:14 AM   #247
churchx
churchx's Avatar
Drives: 2014 GT86
Offset is how far wheel hub is in mm from centerline of wheel. Bigger - hub is further from center = wheel is more sunked in arches. Smaller - closer to centerline = wheel more pokes out.
Old 11-15-2015, 09:44 AM   #248
carlovestela
Whats the ideal offset for stock suspension
Old 11-17-2015, 02:22 PM   #249
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Thanks, I have since sold the car - I was turboed too =]
2" hvac knock out seals then I plastidipped them. Make sure you bend the prongs out slightly and wrap them in a few layers of tape so they don't scratch your hub on the wheels.
http://www.mazdaspeedforums.org/foru...er-caps-87750/
bryan767 is offline   Reply With Quote
The Following 2 Users Say Thank You to bryan767 For This Useful Post:
DustinS (02-02-2016), smg1138 (11-17-2015)
Old 02-01-2016, 02:50 AM   #250
Bach415
Bach415's Avatar
Drives: Whiteout FRS
For those who are on coilovers, how much more clearance do you guys end up having between the wheel and the coilover? I know it varies between coilovers but I just want to get an estimate on how much.
Bach415 is offline   Reply With Quote
Old 02-02-2016, 10:29 PM   #251
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
On tarmac 2s dropped ~1 inch, enough to run -2.5 degrees of camber without a problem using camber bolts.
Mad_Mike is offline   Reply With Quote
The Following User Says Thank You to Mad_Mike For This Useful Post:
Bach415 (02-02-2016)
Old 02-03-2016, 02:07 PM   #252
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
Decimus (08-02-2016)
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 05:18 PM
