#239 |
Drives: 2013 Scion FR-S-Asphalt
Sorry if this has been asked before but is the Whiteline diff cradle bushings allowed in STX?
#240 |
Drives: Subaru BRZ Limited WRB Manual
| The Following User Says Thank You to enjoyminutemaid For This Useful Post: | Auto-Hauss (03-01-2013) |
#241 |
AutoX-10/10ths every run
I've got it on order, but it hasn't shown yet.
@Auto-Hauss http://www.scca.com/assets/2013%20Solo%20Rules.pdf 14.8.D - "Differential mount bushings may be replaced but must attach in the factory location(s) without additional modification or changes. Dif- ferential position may not be changed. The amount of metal in a replacement bushing may not be increased relative to the amount of metal found in a standard bushing for the particular application. Solid metal bushings are specifically prohibited."
| The Following User Says Thank You to whataboutbob For This Useful Post: | Auto-Hauss (03-01-2013) |
#242 | |
![]() My comprehension of the rule would make these illegal. The metal in the bushing increases and you can potentially change the mount point depending on which slot you use. Last edited by Auto-Hauss; 03-01-2013 at 11:06 AM. |
#243 | |
The other Whiteline bushings I've put on the front LCA and steering rack didn't increase the amount of metal and that's why I am hesitant to say/agree that these will as well. I suspect that Whiteline is aware of the rules in SCCA as well and probably wants to provide upgrades that are legal to get sales. :happy0180:
#244 |
Oh yeah I'm sure they want the autoX sales. I believe this is why they are the only company making RCA with bushings instead of ball joints. Its just a risk right now to install them without knowing if they are illegal. I don't want to buy another set of stock bushings. IMO it should be ruled as adding more metal. The stock bushing is nothing but rubber except the outside ring. But we'll see.
Cheers aswell! :happy0180: |
| The Following User Says Thank You to Auto-Hauss For This Useful Post: | whataboutbob (03-01-2013) |
#245 | |
#246 |
They do have a sleeve. I guess one could argue in favor of the Whiteline bushings to be legal based on that. Please post up a picture when you get them. The high res picture of them might over state how big the metal puck is on the inside of the bushing.
Also when you installed the subframe collars, did the subframe shift down(away from the car body) 5mm after everything was tightened? |
#247 |
Drives: '13 BRZ in WRB--let's mod!!!
Okay, ran into an issue with rear camber--which, evidently, is not adjustable...
LR 1.79 RR 2.55 (!) Any one else having this issue? What LC arms do I need (it seems)?
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
#248 |
Drives: '87 Corolla GTS, '13 FR-S 6MT
I went with the SPC lca. Does the job well, and it's affordable!
Here's a pic installed.
| The Following User Says Thank You to RiskyTrousers For This Useful Post: | EN2_Squirrel (03-07-2013) |
#249 |
Conedancer
Drives: 2013 Subaru BRZ SWP
I will be going with Whitelines... But for now.. I adjusted it with Ride height..
![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#250 | |
Well, considering this was after corner bal/alignment--that would throw that out the window. Lol. I'm really scratching my head trying to figure out why such a disparity when ride height is very close. Bought car brand new & it's never been damaged. Strange & frustrating!
#251 |
Drives: 2021 Supra / 2022 Tundra
At stock height mine is symmetrical (-1.7) but when lowered to corner balance I was off by .3.
TomR
#252 |
So, if I don't get LC arms by event, should I chuck corner weight in favor of even rear camber?
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
