Old 06-22-2013, 08:00 AM   #239
smokd
So it's been awhile since I installed the perrin inlet tube with the K&N drop in. I also plugged the whole in the passenger footwell to really complete the job. What i noticed right after installing everything was that the edu definitely needed about 30 miles to "learn" the new airflow patterns and adapt. After this 30 mile period, the car felt smoother and was so much more quiet. I can't recommend this setup enough for those wanting to eliminate the sound tube and gain a couple hp in the process. I'm confident that with the full complement of bolt ons and a tune, this intake setup will make as much hp as any intake on the market.
smokd is offline   Reply With Quote
Old 02-17-2014, 05:28 AM   #240
Astroboy
Astroboy's Avatar
Drives: None
We need an fa20club intake
Astroboy is offline   Reply With Quote
Old 02-17-2014, 06:55 AM   #241
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Oh stop it. Just mod the stock intake behind the bumper and be done with it.
skye67 is offline   Reply With Quote
Old 02-17-2014, 07:47 AM   #242
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
im really curious for a comparison between injen and perrin as well. that would help greatly in my decision.
BoxRZ_86 is offline   Reply With Quote
Old 02-17-2014, 01:24 PM   #243
CajunFRS
Drives: Challenger R/T, CRX SI,
I don't think we need anything to do with fa20club period.
CajunFRS is offline   Reply With Quote
Old 02-17-2014, 02:25 PM   #244
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
This thread is full of fail......
The whole premise of using the stock tune with an intake is wrong.
It's obvious that the Afr changes are what affected the power curve.
I expected better from Drift office.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-17-2014, 02:31 PM   #245
BoxRZ_86
BoxRZ_86's Avatar
I think they are showing what the average person can expect when they upgrade the intake. I think your right with a tune most would perform better. But someone like me I would love to know what intake without a tune will I get the best results out of.
The Following User Says Thank You to BoxRZ_86 For This Useful Post:
Fast_Freddy (06-28-2014)
Old 02-17-2014, 02:56 PM   #246
Victor Draken
Drives: Toyota Gt86
It's not true, most with a tune will perform worse because tuner will not make it run leaner anymore as much as it happens with stock tune and new intake.
Victor Draken is offline   Reply With Quote
Old 02-17-2014, 04:14 PM   #247
mad_sb
Drives: 2013 Asphalt FR-S
I don't understand... leaner is leaner period. Does not matter if the tuner makes it leaner by taking fuel out of the fuel map or the intake throws off the afr.. if there is power to be gained on a particular car by going leaner it will make power either way (tuner or filter).
However, if the intake messes with the calculated load (and it certainly will if it changes the afr, in fact that is why the afr changes, because the flow around the sensor causes a deviation from stock maf scaling) then the tuner will need to take that into account because load affects all of the control systems, not just the fuel but also timing, avcs angle, etc.
Old 02-17-2014, 05:25 PM   #248
Victor Draken
Drives: Toyota Gt86
I was not able to explain myself correctly. Most of the intake looks like they are providing an increase in power on stock tune, just because it makes the car run leaner.
If the car is tuned with the intake, the tuner has hopefully take in account it and tuned the car properly so mostly the increase will not be as strong as before when the car was not tuned and was running much leaner.
Old 02-17-2014, 06:10 PM   #249
StormTrooper
Meaning if you tune the stock intake you'll make the same power and it'll be smoother.
If that is really the case then just buy a sticker
GR86 MT premium
Old 02-17-2014, 07:23 PM   #250
Victor Draken
Drives: Toyota Gt86
the stock intake is more or less already tuned on stock map.
maybe i'm completely blabbering. i'm no expert at all
Old 02-17-2014, 11:29 PM   #251
Astroboy
Astroboy's Avatar
Drives: None
Why do you say that?
Old 02-18-2014, 12:18 AM   #252
StormTrooper
Do some searching on frs300's and Nelsmar' cars.
Search for Toni and Antonio brown.
GR86 MT premium
FRS Event, FR shootout, and FF shootout at Willow Springs Raceway Pekingduck FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 01-19-2013 12:17 AM
INJEN and aFe Intake System, In stock and ready to ship!! 10k Redline Engine, Exhaust, Bolt-Ons 5 10-03-2012 05:05 PM
Intake Shootout! Free Baseline? :) Drift-Office Northwest 16 10-03-2012 12:28 AM
Airaid Intake System Official GB - The pre-order AJUSA.com Engine, Exhaust, Bolt-Ons 212 09-19-2012 07:36 PM
Injen Intake IN STOCK! Mach V Dan Engine, Exhaust, Bolt-Ons 0 08-14-2012 02:04 PM
