Old 04-14-2017, 07:06 PM   #239
KiP40
Drives: Subaru BRZ Limited
Originally Posted by reeves View Post
Yes, I ran into an unexpected problem when I re-used my washer.
No, it didn't leak (the bottom of my transmission is completely dry). But the washer got crushed/squished to the point where I couldn't take it off drain plug anymore. Basically, the inside diameter of the washer became smaller than the diameter of the threads on the drain plug. The outside diameter of the washer expanded out, while the inside diameter expanded inward from being crushed too much. Hope this makes sense.
Not a big deal, but I went ahead and ordered a new drain plug for next time. I had to put the old drain plug back on (along with the previously twice-crushed washer) since it was gonna take a few days for the new drain plug to arrive. I've checked it a few times after driving around for a few weeks now, its not leaking.. even with the thrice-used washer.
Thank you, I really appreciate your response. I will order a new drain plug next time I switch the fluids to play it safe.
KiP40 is offline   Reply With Quote
Old 05-01-2017, 11:25 PM   #240
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Did the swap this weekend.
When I was filling the transmission I was surprised to find that I put in ~2.5L before the oil started leaking out. It did leak a good amount (because I didn't notice it at first, since it follows the lines of the transmission and a good amount was on the little grid fins on the side of the transmission. Still, I think this happened because my garage floor is not as level as I thought it was. Car was at an angle so I could get under it easier such that the rear right was the lowest point. All of the jackstands were at equal heights though.
The shifter seems to be what I would call notchier (not sure what people mean when they say notchy), I can feel a little of resistance going into each gear before it pops into gear. No grinding or anything like that. Other times though it is really smooth. This is with Motul 300.
Is there any harm to the transmission to have ~0.3 L too much oil? If so what's the best way to leak out a small amount to get it back closer to 2.2L? I feel like I should have just tried to put 2.2L in and stopped even if it didn't leak, but I'm not even sure if the bottles have exactly 1 L in each bottle. Was thinking about getting a pump and syphoning out ~0.2 to 0.25 L to make sure that its not underfilled. I've heard that you can just level the car and let it leak out the top hole, but I'm not sure what the best way to level the car on both axes is.
I'm really shocked I could get 2.5 L in it, I would have thought there would be less tolerance for error when filling it up. I really wish this car just had a dipstick like the WRX so I could know for sure.
BR-ZED is offline   Reply With Quote
Old 05-02-2017, 01:14 AM   #241
mr_squirrel
mr_squirrel's Avatar
Drives: 2017 86 Halo
I kept filling and waiting spill over. When it didnt happen past 2.5, I got suspicious and stopped filling. I was definitely closer to 2.75L. Didn't have a way to get it out without opening the drain plug so I left it in because I didn't want to over drain it. After driving , so far so good, but I worry that maybe thermal expansion will cause the tranny to explode. I have no actual evidence this would happen, but I think about the one time I put a beer in the freezer. Opposite temps but same idea.
Sent from my ONEPLUS A3000 using Tapatalk
mr_squirrel is offline   Reply With Quote
Old 05-07-2017, 07:21 AM   #242
BR-ZED
BR-ZED's Avatar
Here is an update.
After reassessing the situation, I think I had about 2.45L in the transmission. Ended up jacking up the car again. This time didn't angle the car in the garage. Took the fill plug out and immediately some oil dripped out.
I used a bubble level app on my Android phone to see how level the car was front to rear. Found a good place to place the level was on the main ridge of the transmission (going front to rear). Kept jacking up the rear of the car until it was level to within 0.1 degree. Can't believe how unlevel the floor was. Also, am wondering if the transmission is even level to the cars frame. When I did this, more fluid came out. Let it drip till it stopped, and measured what I took out as ~200mL. Pretty close now to the spec (~2.25L). Plugged it back up and took it for a drive... Much less notchy and much smoother. Still, in my judgement, about the same as stock. However my car is used, so not sure if the previous owner had stock fluid in it or not. So I can't say I'd recommend Motul, but I'm just glad my car is feeling better again. It is still slightly notchier occasionally, especially when cold, but draining the excess fluid made a huge difference. Highly recommended!
Wanted to share my experience. I think this is a pretty common issue as I've read about it on the internet and this forum a few times. Hopefully this helps someone.
Old 05-07-2017, 05:02 PM   #243
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Have a look at this. I caught some grief for being too anal about it but the CAR being level matters when doing the tranny fluid fill.
http://www.ft86club.com/forums/showthread.php?t=110736
BirdTRD is offline   Reply With Quote
Old 05-08-2017, 11:01 PM   #244
BR-ZED
BR-ZED's Avatar
Nice, no harm in being too careful!
Old 05-15-2017, 04:38 PM   #245
dattran86
Driver
Drives: 2013 Whiteout FRS
going to tackle this job tomorrow.
last time I change the diff and tran fluid i bough new gasket for all of the drain/fill bolts.
Can i just switch them over this time around and save some money?
dattran86 is offline   Reply With Quote
Old 08-10-2017, 11:54 AM   #246
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Originally Posted by zc06_kisstherain View Post
just reposting so people get correct washer
Differential fill plug gasket: SU00300122 @$2.30 each- part no.11126jb000
Differential drain plug gasket: TOY1215710010 @$1.50 each - 1215710010
Transmission fill/drain plug gasket: SU00303626 @>$11 each
SU003-03626 for the transmission drain and fill washer gasket is the same exact size as hondas transmission drain plug and it costs 2.27 instead of 11 bucks.
save some money. hondas part number is 90471-px4-000
I went to Honda and got their washer (
90471-px4-000) and worked perfectly
can anyone confirm the dill/drain gasket is parts number 17008AA050. i looked it up at my local dealer and it says thats the parts number.
Breadman is offline   Reply With Quote
Old 08-16-2017, 01:37 PM   #247
allowe
allowe's Avatar
Is 2.3 ok? For the trAnny? That's when it started to drip for me. Also, I did it when the car was cold overnight , is that ok too?
allowe is offline   Reply With Quote
Old 08-16-2017, 02:34 PM   #248
Was the car perfectly level? If so that should be about right. The temperature doesn't matter at that small of a volume.
Old 08-16-2017, 03:20 PM   #249
allowe
allowe's Avatar
Yea very level actually haha. I used a leveller and spent a solid hour trying to get it perfectly level. Also, my differential took 1.2 then started to drip. I hope that's fine.
Thanks for your answer !
Old 08-16-2017, 03:25 PM   #250
Sounds like you are bang on for both then.
Old 08-16-2017, 03:39 PM   #251
allowe
allowe's Avatar
DIY - Transmission / Diff Fluid Change Reference Guide
Thanks a lot man! shifting feel has changed, it feels like butter, I like it!
Also, the diff fluid came out a bit red ish but the transmission fluid came out pitch black. The diff magnet had so much gunk.
Ps. Am I the only one who really likes the smell of transmission oil.
Old 08-26-2017, 02:21 PM   #252
Breadman
Breadman's Avatar
to answer my own question, i yes these parts were right.
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
