#239 |
My VTEC fluid is full
Drives: EFF JAY
No longer selling. I figured that I can always get a BRZ down the road. It would be hard to find another CR & wouldn't want to start over with the track s2k. I'll get a BRZ down the line.
Just to add... The dealerships have quite a few BRZs in the NYC area. Selling for MSRP. Last edited by iLuveKetchup; 12-28-2012 at 10:20 AM. |
#240 | |
Drives: Some rust bucket
#241 |
Drives: Attitude
#242 |
Drives: 1991 Acura NSX, 2013 Scion FRS
Probably Tein super racing coiler overs?
#243 |
#244 |
Drives: 2005 S2000
#245 |
well the kit was less weight than some of the stock parts and some of this helps too
Engine Modifications Mugen carbon-fiber intake system, header, exhaust system, oil cap & rad cap; J's Racing carbon-fiber radiator plate & oil catch can Drivetrain J's Racing 4.4 final drive, ATS carbon 2-way LSD, AP1 flywheel Engine Management Hondata Flash Pro Wheels, Tires & Brakes Volk Racing CE28N 18x10.5" (f/r) wheels, Yokohama Advan A048R 265/35R18 (f/r) tires, Rays aluminum lug nuts, Spoon monoblock calipers (f), Mugen active gate brake rotors, Endless CC RG brake pads, Endless brake lines Suspension & Chassis KW Variant 3 coilovers, S2000 CR sway bars, ASM GT strut tower bar (f) & floor brace; J's Racing strut tower bar (r), bumpsteer kit, roll center adjusters, camber ball joints & rear diff spacer; Spoon Sport lower tie bar & X-brace; aluminum diff bushings Also the body kit is 10cm wider in the front and back to hide the wider track and 10.5 inch wide wheels =) |
#246 | |
![]() In "full" trim (I've never actually run it in this state...): BYS cooling plate Tein SRC, custom valved (note my "almost stock" ride height) J's racing front offset ball joint SPC rear offset ball joint BBS RG-R 17x8.5 with 255 RS3 J's Racing 70RR FlashPro Everything else is otherwise stock with no additional weight reduction, unless an aftermarket clutch and bucket seat count. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ayau (12-28-2012) |
#247 | |
I had Custom Tein SRC at one point. You should look into KW Clubsports. |
#248 | |
Alas, the SRCs are a loaner set that I won't have much longer ![]() If I were to purchase my own set, at this point, the only two options I'd consider are SRCs valved to the spec of my loaner set (~4150 retail) or JRZ RS (~5700 retail). While the KW work, IMO, they're not really suited for track duty with modern tire compounds; KW's stubbornness and refusal to update their product for modern tire compounds really shows. Their products for strut fronts are a great value, but not the V3/CS for the s2k. The problem here is similar to the brake problems that S2ks have: the car was designed 15 years ago for compounds available 15 years ago, not today's stuff. A 255 RS3 is easily sticker than the 205/225 R-comps that were run on s2ks when the car first came out.You can read the woes of trying to get custom valved V3/CS on S2ki's R&C subforum... KW swears that their shocks are perfect and that we can't possibly improve them. |
#249 | |
#251 |
kind of off topic, but i'm interested in @CSG Mike's opinion.
what "solution" would you recommend to achieve some negative camber on the BRZ? i'm pretty set on some SPC camber bolts at the front, but i'm unsure about the rear. possibly the stock lower control arm with an adjustable one? i figured these parts will get me about -1.5 degrees of camber. i suppose you could also get some lowering springs for additional camber, but they'd have to be pretty similar to the stock springs, otherwise you're going to need to upgrade to some aftermarket dampers. |
#252 | |
| FR-S vs S2000 | vang | FR-S / BRZ vs.... | 436 | 09-19-2012 04:52 PM |
| E36 M3 vs FR-S vs S2000 (for me) | RearDrive | FR-S / BRZ vs.... | 48 | 07-02-2012 10:46 PM |
| S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 02:01 AM |
| S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 09:05 PM |
