Old 01-18-2021, 09:52 PM   #239
Lantanafrs2
Drives: 2013 frs red
They were trying to design something that would work with an existing ots tune. They did. Maybe some tuning will improve the results. It sounds like we're about to find out.
Old 03-01-2021, 10:10 AM   #240
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I'm going to post this here and everyone can tear the data to shreds in whichever fashion you see fit.
EDIT: Also to be clear, I ran about 4 pulls and shut the car down to heat soak. 4 more pulls and this is the best run out of the 8. All were consistent in power. I then swapped back to the stock intake while still strapped to the dyno, flashed the tune, and proceeded to run 8 more pulls just like we did with the Racer X. We tried to remove as many variables as possible.
First the facts:
Racer X setup:
e62 fuel
penguin tech racing flex fuel sensor
ace a350 header
1320 dual resonated front pipe
stock exhaust
factory airbox/filter with modified joiner pipe
Factory manifold:
e62 fuel
ace a350 header
stock exhaust
factory airbox/filter sound tube delete
Both tunes were done by tomm.brz and he has done a phenomenal job getting things done all the way from Italy. I can't speak highly enough about his ability to send revisions so quickly, and the car feels great. If you need a tune, consider giving Tommaso a shout.
racer x dyno_1 by hatchethairy, on Flickr
Unfortunately the intake isn't ideal for my plans, so I will be putting it up for sale with ALL of the parts needed to install. They don't provide a few items that are needed to get it bolted in, so hit me up if you are interested. I think a boosted setup may be the most ideal purpose for this intake, but I could be wrong.
captain awesome is offline   Reply With Quote
The Following 10 Users Say Thank You to captain awesome For This Useful Post:
Calum (03-02-2021), jflogerzi (03-03-2021), Lantanafrs2 (03-01-2021), Mike_ZN6 (03-01-2021), new2subaru (03-04-2021), NoHaveMSG (03-01-2021), PulsarBeeerz (03-01-2021), RToyo86 (03-01-2021), tomm.brz (03-01-2021), ZDan (03-02-2021)
Old 03-01-2021, 10:25 AM   #241
Joveen
Joveen's Avatar
Drives: Bone stock
Seems stock is better. Maybe FI get something out of it.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 03-01-2021, 11:23 AM   #242
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Second on Tommaso delivering a quality tune.
He got me dialed in with a Petro 94 tune with gruppe-s headers, and the car pulls strong through the entire rev range.
As far as I'm concerned he also went above and beyond as far as revisions to get it perfect.
Old 03-01-2021, 11:41 AM   #243
Lantanafrs2
Sheesh that's a significant loss up top
Old 03-01-2021, 12:54 PM   #244
PulsarBeeerz
Drives: JRSC BRZ SOLD
Knowing is better than not knowing. No one can complain of non 3rd party results now.
PulsarBeeerz is offline   Reply With Quote
The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post:
Lantanafrs2 (03-01-2021), NoHaveMSG (03-01-2021)
Old 03-01-2021, 01:05 PM   #245
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
First the facts:
Racer X setup:
e62 fuel
ace a350 header
stock exhaust
Factory manifold:
Racer X setup:
e62 fuel
ace a350 header
stock exhaust
Big thanks for actually putting the money up and making the results public for everyone on here to see!
Are these tunes on EcuTek or OFT?
Old 03-01-2021, 01:11 PM   #246
Mike_ZN6
Mike_ZN6's Avatar
I just don't think there is much to gain from changing the intake system on the FA20. From what I have read, the stock intake system already flows more air than the heads/valves can push. So unless you build the engine with higher flowing heads/bigger valves (or add boost to compress the air), it does not matter how much more air you can get the intake system to move.
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Joveen (03-01-2021)
Old 03-01-2021, 01:20 PM   #247
captain awesome
Wears Pants
ECUTEK
The Following User Says Thank You to captain awesome For This Useful Post:
Old 03-01-2021, 01:29 PM   #248
captain awesome
Wears Pants
Adding this to the original post from the dyno, but our method of testing was as follows:
I ran 4 pulls and shut the car down to heat soak. 4 more pulls and this is the best run out of the 8. All were consistent in power however.
The Following 2 Users Say Thank You to captain awesome For This Useful Post:
Mike_ZN6 (03-01-2021), NoHaveMSG (03-01-2021)
Old 03-01-2021, 01:46 PM   #249
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They can put up or shut up. Still a good test, unless someone is super picky and wants to see something in particular the end result is pretty clear. The only thing I am curious on based on a couple other threads is IAT's on each pull.
Old 03-01-2021, 01:48 PM   #250
captain awesome
Wears Pants
Yeah I wish I would have run logs for the pulls, but it was my first time using a dyno and trying to swap the intake without adding a ton of cost was on my mind most.
Old 03-01-2021, 04:03 PM   #251
Lantanafrs2
At least you didn't pay 4 grand for it (jun). Thx for your effort and honesty
Old 03-01-2021, 04:18 PM   #252
Mike_ZN6
Mike_ZN6's Avatar
@captain awesome is the hero the forums need!
Racer X Fabrication air intake design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 45 08-01-2019 01:29 PM
FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox FT-86 SpeedFactory Engine, Exhaust, Transmission 733 12-11-2018 11:13 PM
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 11:40 AM
Project BRZ Intake Manifold Development TurboBRZ Engine, Exhaust, Transmission 27 08-05-2015 08:44 PM
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 12:10 PM
